Canon Support for imageCLASS MF4570dw | Canon U.S.A., Inc.
imageCLASS MF4570dw
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 11.04.11
File Size 7.11 MB
Date 11.04.11
File Size 8.46 MB
Date 11.04.11
File Size 3.79 MB
Date 11.04.11
File Size 919.17 KB
Date 09.22.17
File Size 2.92 MB
Date 12.24.20
File Size 2.92 MB
Date 04.07.25
File Size 1.32 MB
Date 09.17.24
File Size 2.27 MB
Date 12.22.17
File Size 809.44 KB
Date 09.25.23
File Size 1.20 MB
Date 04.24.19
File Size 815.66 KB
Date 04.24.19
File Size 647.96 KB
Date 01.31.23
File Size 2.92 MB
Date 04.20.22
File Size 1.50 MB
Date 10.04.19
File Size 815.82 KB
Date 09.17.24
File Size 1.20 MB
Date 02.04.20
File Size 652.13 KB
Date 03.24.23
File Size 1.60 MB
Date 09.25.23
File Size 2.27 MB
Date 10.04.19
File Size 2.92 MB
Date 12.20.23
File Size 1.32 MB
Date 04.24.19
File Size 2.92 MB
Date 04.27.23
File Size 2.27 MB
Date 09.17.24
File Size 1.32 MB
Date 12.24.20
File Size 819.56 KB
Date 07.13.21
File Size 652.14 KB
Date 01.31.23
File Size 1.63 MB
Date 12.22.17
File Size 647.92 KB
Date 04.27.23
File Size 1.72 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Initial Setup
Setting up additional computers
Finding your Network Key/Password
Re-establishing Printer Connection After A Network Change?
Need additional information or assistance?
imageCLASS MF4570dw
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15
imageCLASS MF4570dw
Printer
Printing Method Monochrome Laser
Print Speed (up to) Default Print Mode: 2-sided
Black: Up to 16 ppm (2-sided, plain paper letter)10
Black: Up to 26 ppm (1-sided, plain paper letter)10
First Print Time:
6 seconds or less
Print Resolution (Up to) Black:Up to 600 x 600 dpi
1200 x 600 dpi quality
Toner Compatibility (for Laser MFP) Cartridge 128 (Yield: 2,100*)
*Yield based on ISO/IEC Standard
Paper Sizes Letter, Legal, A4, A5, B5, Statement, Executive
Automatic Sheet Feeder 35-sheet5
Paper Weights 16 to 43 lb. bond (cassette)
16 to 43 lb. bond (multipurpose tray)
Output Tray Capacity Approx. 100 sheets (face-down)
Copier
Copy Resolution (up to) Up to 600 x 600 dpi
Copy Speed (up to) Up to 26 cpm (letter)
Zoom 25-400% in 1% increments
Halftones 256 levels
First Copy Time Approx. 9 seconds1
Warmup Time: Approx. 13.5 seconds
Reduction / Enlargement 25%, 50%, 64%, 78% , 129%, 200%, 400%
Copy Size Platen: Up to Letter
ADF: Up to Legal
Copy Features ID Card Copy, 2 on 1, 4 on 1, Collate, Memory Sort, Auto Background Control
Scanner
Scanner Type Color Contact Image Sensor (CIS)
Max. Resolutions Optical:Up to 600 x 600 dpi
Interpolated:9600 x 9600 dpi
Scanner Features Rotate, Push Scan (Scan to PC), Pull Scan
Color Depth 24-bit
File Format Hi-Compression PDF, Searchable PDF, PDF, JPEG, TIFF, BMP, PNG4
Fax
Modem Speed Up to 33.6 Kbps (Super G3)2
Fax Resolution Up to 203 x 391 dpi (super fine)
Memory Capacity Up to 256 pages3
Speed Dialing 4 one-touch speed dials
100 coded dials
Fax Features Distinctive Ring Pattern Detection, Remote RX, Dual Access Fax, Auto Redial, Auto Fax Reduction
Other Features Memory Backup
PC Fax (sending only)
General
Other Features USB Device 2.0 Hi-Speed6, 10/100 Base-T Ethernet (Network), IEEE802.11b/g/n (wireless)9
WiFi Access
Infrastructure Mode
WiFi Authentication Method
Open System, Shared Key, WPA-PSK, WPA2-PSK
WiFi Encryption Mode
WEP (64/128 bit), TKIP, AES
WPS Easy Setup Support Methods
Push-button mode, PIN code mode
OS Compatibility Windows&reg; 8, Windows 7, Windows Server&reg; 2008, Windows Vista&reg;, Windows Server 20038, Windows XP/2000, Mac&reg; OS X 10.4.9 & up
Software Included Canon Drivers, Document Management & OCR Software
Drivers available for download from www.usa.canon.com
Power Consumption (approx.) 1090W (Max)
3.5W (wired), 4W (wireless) (Energy Saver Mode)
Dimension (W x D x H) 15.4" (W) x 16.6" (D) x 14.6" (H)
Weight 25.8 lbs. (w/o cartridge)
27.4 lbs. (w/cartridge)
Warranty 1 year limited exchange/trade-in warranty9
(Extended warranty available)
Canon imageCLASS MF3010/MF4570dw LIMITED WARRANTY
CARTRIDGES FOR THE PRODUCT (EXCEPT THE CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
Click Here to download the imageCLASS MF3010/MF4570dw Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Service Notice: Windows Scanning for imageCLASS
Advisory Type
Date 07.11.16
Title Canon Support | Service Notice: Canon Laser Printer & Small Office Multifunctional Printer IP Stack protocol
Advisory Type
Date 09.29.20
Title Canon Support | Service Notice: Laser Printer & Small Office Multifunctional Printer cross-site scripting
Advisory Type
Date 12.30.21
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
