Canon Support for imageCLASS MF5960dn | Canon U.S.A., Inc.
imageCLASS MF5960dn
Technical support for this product is provided exclusively through our FAQs and Knowledge Base.
Please click FAQs or Knowledge Base and enter your search term to find a resolution to your inquiry.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
SELECT ERROR CODE
WINDOWS
macOS X
| Products | Windows 7 | Windows 8 | Windows 10 | Windows 10s | Windows 11 |
| Products | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 | Tahoe 26 |
Printer
| Printing Method | Monochrome Laser |
| Print Speed (up to) | Default Print Mode: 2-sided Black: Up to 17 ppm (2-sided, plain paper letter)10 Black: Up to 35 ppm (1-sided, plain paper letter)10 First Print Time 6 seconds or less (letter) |
| Print Resolution (Up to) | Up to 600 x 600 dpi 1200 x 600 dpi quality |
| Toner Compatibility (for Laser MFP) | Canon Cartridge 119 (Yield: 2,100 pages*) Canon Cartridge 119 II Hi-Capacity (Yield: 6,400 pages*) *Yield is based on ISO/IEC Standard |
| Paper Sizes | Letter, Legal, A4, A5, B5, Statement, Executive |
| Paper Compatibility | Plain Paper, Heavy Paper, Bond Paper, Label, Index Card, Envelopes (up to 5 via MP tray - Com 10, Monarch, DL, C5, B5) |
| Printer Features | Printer Language UFR II LT (Host-based), PCL5/XL (45 Fonts), PS 3 Emulation (45 Fonts) Print Modes Poster, Booklet, Watermark, Toner Save, Page Composer Print Memory 256MB (shared) |
| Paper Weights | 16 to 32 lb. bond (cassette) 16 to 51 lb. bond (multipurpose tray) |
| Output Tray Capacity | 150 sheets (face down) |
Copier
| Copy Resolution (up to) | Up to 600 x 600 dpi |
| Copy Speed (up to) | Black: Up to 35 cpm (letter) Duplex Black: Up to 17 cpm (letter) |
| Type | Monochrome Laser |
| Zoom | 25 - 400% in 1% increments |
| Halftones | 256 Levels |
| First Copy Time | Less than 8 seconds1 Warmup Time: Less than 17 seconds Recovery Time: 5 seconds or less |
| Reduction / Enlargement | 25%, 50%, 64%, 78% / 129%, 200%, 400% |
| Document Feeder | 50-sheet duplex5 |
| Copy Size | Platen: Up to Letter ADF: 5.5" x 5" to Legal |
| Copy Features | Memory Sort, 2 on 1, 4 on 1, ID Card Copy |
Scanner
| Scanner Type | Color Contact Image Sensor (CIS) Scanner Compatibility: TWAIN, WIA |
| Max. Resolutions | Up to 600 x 600 dpi (optical) Up to 9600 x 9600 dpi (interpolated) |
| Scanner Features | Scan to USB Host 1.1 (Hi-Compression PDF, PDF, JPEG, TIFF), Rotate Image, Pull Scan, Push Scan, Scan to Email, Scan to SMB |
| Color Depth | 24-bit |
| Max. Document Size | Platen: Up to Letter ADF: 5.5" x 5" to Legal |
| File Format | Hi-Compression PDF, Searchable PDF, PDF, JPEG, TIFF, BMP, PNG4 |
Fax
| Modem Speed | Up to 33.6 Kbps (Super G3)2 |
| Transmission Speed (approx.) | JBIG (approx. 3 seconds) |
| Memory Capacity | Up to 512 sheets3 |
| Fax Resolution | Up to 400 x 400 dpi (ultra fine) |
| Speed Dialing | 19 one-touch speed dials; 181 coded dials |
| Group Dialing | Group Dialing: 199 destinations Sequential Broadcasting: 210 destinations |
| Receive Mode | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
| Fax Features | Remote RX, Dual Access, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial, Collate, Auto Fax Reduction, PC fax (sending only), Fax forwarding, Memory backup (5 minutes) |
General
| Other Features | Embedded Web Server (Remote UI) w/ IE 6.0 or later, Safari 1.3.2 or later Department Counter (print, copy, scan) 5-row backlit LCD w/ animation (fax installation, toner installation, paper jam) Print Protocols: LPD, RAW, WSD Supported Network Protocols: TCP/IP v4, TCP/IP v6 (print only) TCP/IP Set of Application Services: DHCP, BOOTP, RARP, ARP+PING, Auto IP, Bonjour, HTTP, SHTTP, NetBIOS Network Management Protocols: SNMPv1, SNMPv38 MIB: RFC1213 (MIB-II), RFC1514 (Host Resources MIB), RFC1759 (Printer MIB), Canon MIB Languages: English, French, Spanish, Portuguese Security: IP Filtering, MAC Address Filtering, Secure Print |
| OS Compatibility | Windows® 8, Windows 7, Windows Server® 2008, Windows Vista®, Windows Server 2003, Windows XP/2000, Mac® OS X 10.4.9 & up |
| Standard Interface | USB Device 2.0 Hi-Speed6, 10/100 Base-T Ethernet |
| Software Included | Canon Drivers, MF Toolbox, Document Management & OCR Software |
| Power Consumption (approx.) | 1,000W (Max), 9W (Standby), 2.1W (Energy Saver Mode) Typical Energy Consumption (TEC): 1.4k Wh |
| Dimension (W x D x H) | 15.4" (W) x 18.6" (D) x 17.0" (H) |
| Weight | 40.4 lbs. (without Cartridge); 42.2 lbs. (with Cartridge) |
| Warranty | 1 year limited exchange/carry-in warranty9 (Extended Warranty available) |
CANON imageCLASS SERIES EXCHANGE/CARRY-IN PRODUCT LIMITED WARRANTY
CARTRIDGES FOR THE PRODUCT (EXCEPT THE CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
NEITHER CANON USA NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, INCLUDING, WITHOUT LIMITATION, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON USA OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCAHSE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
Click Here to download the imageCLASS MF5950dw/MF5960dn Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
next to your download
