Canon Support for imagePROGRAF iPF670E | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.31.17
File Size 1.16 MB
Date 03.31.17
File Size 6.04 MB
Date 01.15.15
File Size 5.16 MB
Date 03.31.17
File Size 34.18 MB
Date 09.04.19
File Size 3.53 MB
Date 01.15.20
File Size 2.28 MB
Date 05.26.25
File Size 5.20 MB
Printer Type 5-Color 24-inch Printer
Number of Nozzles Total: 15,360
MBK: 5,120 nozzles
C, M, Y, BK: 2,560 nozzles each
Nozzle Pitch 1,200 dpi
Non-firing nozzle detection and compensation
Print Resolution (Up to) 2,400 x 1,200 dpi (Max)
OS Compatibility Windows® (Vista/7/8.1/10)
Macintosh® (OSX 10.7.5-10.11X)A
Standard Interfaces USB 2.0 High-Speed 10/100/1000 Base-T/TX
Ink Droplet Size Maximum 4 picoliter
Ink Capacity 90ml per tank
Ink Type Dye/Pigment Reactive Ink
Color Set Dye: Cyan, Magenta, Yellow, Black
Pigment: Matte Black
Buffer Ram 256MB
Media Width Roll Feed 10" - 24" (254mm - 610mm)
Media Thickness 0.07-0.8mm (2.8-31.4mil)
Maximum Roll Print Length 59' (18 meters) B
Maximum Media Roll Diameter 5.9" (150mm)
Borderless Printing Width 10", B4, A3, 14", A2, 17", B2 (20.28/515 mm), A1 (23.38/594mm), 24"
Paper Feed Method Roll Feed: One Roll, Top-loading, Front output
Languages GARO (Canon Proprietary)
Noise Level Approx Operation: 47 dB (A)
Standby:35 dB (A) or less
Acoustic Power: Approx. 6.4 Bels
Physical Dimensions 42" (H) x 39" (W) x 34" (D) (When basket is open)
20" (H) x 39" (W) x 27" (D) (Without stand)
Weight Approximately 92 lb. without stand
Approximately 113 lb. with optional stand
Power Source AC-100-240V (50-60Hz)
Power Consumption Maximum: 140W or less
Standby 5W or less
Power Off: .5W or less (Compliant with Executive Order)
Operating Environment Temperature: 59°-86° F (15°-30° C)
Relative Humidity: 10-80% (No Condensation)
User-replaceable items Print Head: PF-04
Maintenance Cartridge: MC-10
Ink Tanks: PFI-007 (90ml: C, M, Y, BK, MBK, MBK)
Software Available Canon Printer Driver3, Printer Driver Extra Kit (Free Layout, Color imageRUNNER Enlargement Copy, Advanced Preview), Direct Print & Share, PosterArtist Lite (PC Only), Print Plug-in for Microsoft® Word/Excel/PowerPoint (PC only), Status Monitor, Media Configuration Tool, Optimized Module for AutoCAD
SUPPLIES & ACCESSORIES
