Canon Support for imagePROGRAF iPF840 | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.31.17
File Size 1.16 MB
Date 06.26.15
File Size 34.35 MB
Date 06.26.15
File Size 6.69 MB
Date 09.04.19
File Size 3.53 MB
Date 01.15.20
File Size 2.28 MB
Date 05.26.25
File Size 5.20 MB
Printer Type 5-Color 44-inch Printer
Number of Nozzles Total: 15,360
MBK: 5,120 nozzles
C, M, Y, BK: 2,560 nozzles each
Nozzle Pitch 1,200 dpi Non-firing nozzle detection and compensation
OS Compatibility Windows® (XP 32bit/Vista/7/8/8.1)
Macintosh® (OSX 10.6.8 - 10.10)
Standard Interfaces USB 2.0 High-Speed
10/100/1000 Base-T/TX
Ink Droplet Size 4 picoliter
Ink Capacity 330ml , 700ml per color2
Ink Droplet Size Dye/Pigment Reactive Ink
Color Set Dye: Cyan, Magenta, Yellow, Black
Pigment: Matte Black
Hard Drive 320 GB
Media Width Cut Sheet - 8"- 44"
Roll Feed-10" - 44"
Media Thickness 0.07-0.8mm
Maximum Roll Print Length Roll Feed - 59'3 Cut Sheet-63"
Maximum Media Roll Diameter 5.9"
Borderless Printing Width 10", 14", 17", 24", 36", 42"
Paper Feed Method Roll Feed: Dual Roll, Front loading, Front output
Cut Sheet: One sheet, Front loading, Front output
Languages Language: GARO (Canon Proprietary) HP-GL/2, HP-RTL
Noise Level Approx Operation: 52 dB (A) or less
Standby: 35 dB (A) or less
Acoustic Power: Approx. 6.8 Bels or less
Physical Dimensions 75"(W)x 51"(D)x 45"(H)
Weight Approximately 417lbs
Power Source AC-100-240V (50-60Hz)
Power Consumption Maximum: 190W or less
Standby 5W or less
Power Off: .5W or less (Compliant with Executive Order)
Operating Environment Temperature: 59°-86° F (15°-30° C)
Relative Humidity: 10-80% (No Condensation)
Direct Print Built In Card Reader Functions
Software Canon Printer Driver, Printer Driver Extra Kit (Free Layout, Color imageRUNNER Enlargement Copy, Advanced Preview), Direct Print & Share, imagePROGRAF Print Utility4, PosterArtist Lite (PC Only), Print Plug-in for Microsoft® Word/Excel/PowerPoint (PC only), Status Monitor, Media Configuration Tool, Optimized Module for AutoCAD
Print Resolution 2,400 x 1,200 dpi (Max)
SUPPLIES & ACCESSORIES
