Canon Support for imagePROGRAF TC-20M | Canon U.S.A., Inc.
imagePROGRAF TC-20M
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
Print and scan wirelessly from any Wi-Fi® enabled computer from your local network connection. Wireless printing requires a working network with wireless 802.11b/g/n capability. You will need a Wi-Fi enabled Computer, a wireless router and a wireless printer. All three devices must be connected to the same wireless network connection. Click on the specific topic below to get detail information.
Initial Setup
- Wireless Setup on Windows Computers
- Wireless Setup on Mac Computers
- Wireless Setup on iOS Devices (iPad, iPhone)
- Wireless Setup on Android Tablets and Smartphones
Need additional information or assistance
SELECT ERROR CODE
WINDOWS
macOS X
ChromeOS
| Products | Null |
| Products | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 | Tahoe 26 | Golden Gate 27 |
| Products | Null |
| Printer Type | 4-Color 24-inch Printer |
| Printing Technology | FINE: Full-Photolithography Inkjet Nozzle Engineering |
| Head Configuration | 4-Color Integrated Type x 1 print head |
| Number of Nozzles | Total: 4,352 nozzlesBK 1,280 nozzles, C/M/Y 1,024 nozzles each |
| Nozzle Pitch | 1200 dpi |
| Print Resolution (Up to) | 2400×1200dpi (Max) |
| OS Compatibility | Computer Operating Systems: 32-bit: Windows® 7/8.1/10 64-bit: Windows 7/8.1/10/11, Windows Server 2008 R2, 2012, 2012 R2, 2016, 2019, 2022 Mac: mac0S v10.14.6 - macOS v12.x |
| Print Software | imagePROGRAF Printer Driver for TC-20M Windows/Mac Apple Air Print Mopria® Print ServiceFootnote5 Canon PRINT Inkjet/SELPHY PIXMA Cloud Link PosterArtist Online Free Layout Plus Direct Print Plus Media Configuration Tool Quick Utility Toolbox WiFi Connection Assistant Printer Update UtilityFootnote2 |
| Scan Software | imagePROGRAF Printer Driver for TC-20M Windows/Mac Scan Utility Lite PIXUS/PIXMA Cloud Link Printer Update UtilityFootnote2 |
| Printer Language | SGRaster |
| Standard Interfaces | Hi-Speed USB Wi-Fi® IEEE802.11n/IEEE802.11g/IEEE802.11b Wired LAN IEEE802.3u (100BASE-TX)/IEEE802.3(10BASE-T) |
| Ink Capacity | 70 ml per color |
| Ink Types | Pigment Ink |
| Color Set | Pigment: Black, Cyan, Magenta, Yellow |
| Scanner Type | Flatbed |
| Scanning Method | Contact Image Sensors |
| Maximum Scan Resolution | Up to 2400 x 1200 dpi |
| Maximum Scan Document Size | A4/Letter |
| Media Handling | Roll: One Roll, Top-loading, Front Output Cut Sheet: Automatic Sheet Feeder, Top-loading, Front Output |
| Media Width | Roll Feed: 12"- 24 (297 mm - 610 mm) Cut Sheet: 8.3" - 12" (210 mm - 297 mm) |
| Maximum Print Length | Roll Feed: 13.1 (4 m)Footnote1 Cut Sheet: 17" (432 mm)Footnote1 |
| Media Thickness | 0.08 mm - 0.28 mm |
| Media Core Size | 2 Core |
| Maximum Media Roll Diameter | 4.3 (110 mm) |
| Printable Margins | Roll Feed: All Sides - 0.19 (5 mm) |
| Acoustic Noise | Operation Approx. 41.5dB 35dB or Less Acoustic Power Approx. 6.0 Bels |
| Power Supply | AC 100240 V (50-60 Hz) |
| Power Consumption | Maximum 26W or Less Standby 0.3W or Less Power Off |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity: 10-80% (No Condensation) |
| Environmental Certifications | ENERGY STAR®, EPEAT GOLD |
| Physical Dimensions | 38.1 x 21.4 x 16 (W x D x H) |
| Weight | 72.8lbs |
| User-replaceable items | Print Head (PF-08) Maintenance Cartridge (MC-32) Ink Tanks (PFI-050) |
CANON imagePROGRAF TC-20 / TC-20M LARGE FORMAT PRINTER LIMITED WARRANTY
The limited warranty set forth below is given by Canon U.S.A., Inc. or Canon Canada Inc. (as applicable, "Canon") with respect to the Canon imagePROGRAF TC-20 / TC-20M Large Format Printer packaged with this limited warranty and any Canon branded printhead, accessories and options designed for use with the imagePROGRAF TC-20 / TC-20M Large Format Printer (collectively, the "Product"). Canon warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of one (1) year after delivery to the original purchaser (“Purchaser”) by Canon or its authorized dealer. During such warranty period, Canon shall, in its sole discretion and without charge, repair or replace any defective part with a new or comparable rebuilt part or replace the Product with a new or comparable rebuilt part. This warranty shall not extend to other consumable parts or consumables, such as paper and ink bottles, as to which there shall be no warranty or replacement. Replacement products or parts shall not extend the original warranty period provided.
If purchased and used in the United States: If purchased and used in Canada:
1-800-423-2366 1-800-OK-CANON
Monday through Friday from 8:00a.m. to 8:00p.m. ET* Monday through Friday from 9:00 a.m. to 6:00 p.m. ET*
You must cooperate with Canon in remotely diagnosing the Products malfunction. Canon may attempt to correct the malfunction remotely, with your assistance. If Canon cannot fix your Product’s malfunction through remote diagnostics, you will be provided instructions for Canon’s then current warranty service procedures. You may be asked for the Product serial number and other information pertaining to your Product. Canon may schedule an on-site service call by an independent authorized Canon Service Provider (the "Authorized Service Provider") for service or Canon may exchange the Product, as determined by Canon in its sole discretion, except where the malfunction involves a user replaceable item, in which case Canon will send you a replacement part with installation instructions. You will be responsible for installing the user replaceable items in your Product. The service delivery mechanism will be determined by Canon solely at its discretion. You will be charged the then-current respective service call rates of either Canon or the Authorized Service Provider if the defects in the Product are not covered by this limited warranty, or if the applicable warranty period for the Product has expired or warranty coverage has not been sufficiently established by appropriate documentation.
This warranty shall only apply if this Product is used in conjunction with compatible computers, peripheral equipment and software, as to which items Canon shall have no responsibility. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON, INCLUDING ANY IMPLIED WARRANTY OR CONDITION OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
THIS WARRANTY IS IN LIEU OF ALL OTHER WARRANTIES OR CONDITIONS, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTY OR CONDITION OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, RELATING TO THE USE OR PERFORMANCE OF THE PRODUCT. NO OTHER EXPRESS WARRANTY, CONDITION OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON OR ANY AUTHORIZED SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
THIS WARRANTY SHALL BE VOID AND OF NO FORCE AND EFFECT IF THE PRODUCT IS DAMAGED AS A RESULT OF (A) ABUSE, NEGLECT, MISHANDLING, ALTERATION, ELECTRIC CURRENT FLUCTUATION OR ACCIDENT, (B) IMPROPER USE, INCLUDING FAILURE TO FOLLOW OPERATING OR MAINTENANCE INSTRUCTIONS IN, OR ENVIRONMENTAL CONDITIONS PRESCRIBED IN, CANON’S USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT, (C) REPAIR BY OTHER THAN SERVICE REPRESENTATIVES QUALIFIED BY CANON WHO ARE ACTING IN ACCORDANCE WITH CANON’S SERVICE BULLETINS (D) USE OF SUPPLIES OR PARTS (OTHER THAN THOSE DISTRIBUTED BY CANON) WHICH DAMAGE THE PRODUCT OR CAUSE ABNORMALLY FREQUENT SERVICE CALLS OR SERVICE PROBLEMS OR (E) USE OF THE PRODUCT WITH NON-COMPATIBLE COMPUTERS, PERIPHERAL EQUIPMENT OR SOFTWARE, INCLUDING THE USE OF THE PRODUCT IN ANY SYSTEM CONFIGURATION NOT RECOMMENDED IN ANY USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT. NOR DOES THIS WARRANTY EXTEND TO ANY PRODUCT ON WHICH THE ORIGINAL IDENTIFICATION MARKS OR SERIAL NUMBERS HAVE BEEN DEFACED, REMOVED, OR ALTERED. ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE DISKETTES OR CD-ROM'S ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD “AS IS” AND WITHOUT WARRANTY BY CANON. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
NEITHER CANON OR ITS SUPPLIERS NOR ANY AUTHORIZED SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON OR ANY AUTHORIZED SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE T0 REALIZE SAVINGS OR OTHER BENEFITS, LOSS OR CORRUPTION OF DATA INCLUDING, WITHOUT LIMITATION, DATA STORED ON THE PRODUCT'S HARD DISK DRIVE, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON OR ANY AUTHORIZED SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON OR ANY AUTHORIZED SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS, ARISING OUT OF THE POSSESSION, USE, MISUSE OR INABILITY TO USE THE PRODUCT SOLD BY CANON NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON OR ANY AUTHORIZED SERVICE PROVIDER. THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE PURCHASER, AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
Defective parts must be returned to Canon or an Authorized Service Provider with all necessary documentation and will become the property of Canon. THIS WARRANTY APPLIES TO PRODUCTS SOLD AND USED IN THE U.S.A. AND CANADA ONLY.
*Actual hours of support are subject to change.
next to your download
