Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.26.25
File Size 7.44 MB
Date 04.15.25
File Size 78.41 KB
Date 04.15.25
File Size 5.28 MB
Date 04.15.25
File Size 9.65 MB
Date 04.15.25
File Size 2.39 MB
Date 04.15.25
File Size 438.98 KB
Date 04.15.25
File Size 60.53 KB
Date 05.12.25
File Size 2.31 MB
Date 05.12.25
File Size 2.14 MB
Date 05.25.25
File Size 5.20 MB
Date 05.12.25
File Size 922.57 KB
Date 04.13.26
File Size 1.73 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Print and scan wirelessly from any Wi-Fi® enabled computer from your local network connection. Wireless printing requires a working network with wireless 802.11b/g/n capability. You will need a Wi-Fi enabled Computer, a wireless router and a wireless printer. All three devices must be connected to the same wireless network connection. Click on the specific topic below to get detail information.
Initial Setup
Need additional information or assistance
Products Windows 7 Windows 8 Windows 10 Windows 11
imagePROGRAF TC-21M
imagePROGRAF TC-21M
Print Head PF-08
Technology FINE (Photolithography Inkjet Nozzle Engineering)
Print Resolution (Max.) 2400 x 1200 dpi
Line Accuracy* ±0.1% or LessFootnote *
Number of Nozzles Black: 1,280 Nozzles
C/M/Y: 1,024 Nozzles Per Color
Ink Type Pigment Cyan (C), Magenta (M), Yellow (Y), Black (BK)
Ink Bottle Shipped with Printer: C, M, Y, BK, (70 ml per bottle)
Replacement: PFI-050 (70 ml)
Ink Supply Method Tubing System
Printer RAM 1 GB
Media Feed Roll Feed: One Roll, Top-Loading, Front Output
Cut Sheet: Automatic Sheet Feeder, Top-Loading, Front Output
Media Width Roll Feed: 11.7 - 24
Cut Sheet: 3.5 - 11.7
Printable Margins Roll Feed: All Sides: .2 (5 mm); Some Photo
Modes: Top/Bottom: 30 mm;
Cut Sheet: All Sides: .2 (5 mm)
Media Cutter Rotary Cutter
Media Thickness 0.08 mm 0.28 mm
Media Core Size Internal Diameter of Roll Core: 2
Maximum Roll Outer Diameter 4.3 (110 mm)
Printing Software Utilities imagePROGRAF Printer Driver for WindowsFootnote 3/MacFootnote 4, Apple AirPrintFootnote 5, Mopria Print Service, Direct Print Plus, Canon PRINT appFootnote 6, Cloud Integration Service, Free Layout Plus, PosterArtist Online Version, Media Configuration Tool, Quick Utility Toolbox, Wi-Fi® Connection Assistant, and Printer Update Utility
Operating System 32-bit:Footnote 3,Footnote 4 Windows® 7/8.1/10
64-bit:Footnote 3,Footnote 4 Windows 7/8.1/10/11, Windows Server 2008 R2, 2012, 2012 R2, 2016, 2019, 2022, 2025
Mac: macOS v11.7.10macOS 15
Mobile Operating Systems iOS®, Android, Chromebook CompatibleFootnote 7,Footnote 8
Print Language SGRaster
Scanner Type Flatbed
Scanning Method Contact Image Sensor (CIS)
Scanning Resolution 1200 x 2400 dpi (Optical)Footnote 9
Maximum Color Grayscale: 16-bit / 8-bit
Scanning Bit Depth Color: 16-bit / 8-bit Per Color
Max. Document Size Flatbed: 8.5 x 11.7 (A4 / Letter)
Scanner Software Utilities Scanner Driver/Scan Utility, Scan Utility Lite, Canon PRINT app, Cloud Integration Service, Printer Update Utility
Model No. imagePROGRAF TC-21M 24 Large Format Multi-function Printer
Compatible Inks PFI-050 BK Black Ink Bottle PFI-050 C Cyan Ink Bottle
PFI-050 M Magenta Ink Bottle
PFI-050 Y Yellow Ink Bottle
Interface Standard (Built-in): Hi-Speed USB, Wi-Fi® (Wireless LAN, 2.4/5 GHz, IEEE 802.11 b/g/n/a/ac)Footnote 1, Wired LAN (100BASE-TX)/(10BASE-T)Footnote 1
Display 2.7 Touchscreen LCD Display
Acoustic Noise Operation: 41.5 dB (A)
Standby: 35 dB (A) or Less
Acoustic Power: 6 Bels
Power Supply AC 100 240V (50 - 60 Hz)
Power Consumption Maximum: 28 W or Less
Standby: 1.7 W or Less
Power Off: 0.07 W or Less (Executive Order Compliant)
Certifications Electrical Safety Regulations C TUVus (U.S.A.)
Electromagnetic Interface Regulations FCC Part 15B (U.S.A.)
Radio Regulations FCC Part 15C (U.S.A.)
ENERGY STAR® CertifiedFootnote 10
EPEAT Gold
Operational Environment Temperature: 59° 86° F (15° 30° C)
Relative Humidity: 10 80% (No Dew Condensation)
Printer Dimensions (H x W x D) and Weight ASF Opened: 16 x 38 x 22, Approx. 72 lbs.
ASF Closed: 10 x 38 x 22, Approx. 72 lbs.
Printer Dimensions (H x W x D) and Weight Printer: 16 x 44 x 29, Approx. 73 lbs.
Options
  • Desktop Basket (BU-06)
  • Stand (SD-24)
  • PosterArtist (PC Only)
  • User-Replaceable Items:
    • Ink Bottle: PFI-050 (70 ml)
    • Print Head: PF-08
    • Maintenance Cartridge: MC-32
CANON imagePROGRAF TC-20 / TC-20M LARGE FORMAT PRINTER LIMITED WARRANTY
The limited warranty set forth below is given by Canon U.S.A., Inc. or Canon Canada Inc. (as applicable, "Canon") with respect to the Canon imagePROGRAF TC-20 / TC-20M Large Format Printer packaged with this limited warranty and any Canon branded printhead, accessories and options designed for use with the imagePROGRAF TC-20 / TC-20M Large Format Printer (collectively, the "Product"). Canon warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of one (1) year after delivery to the original purchaser (“Purchaser”) by Canon or its authorized dealer. During such warranty period, Canon shall, in its sole discretion and without charge, repair or replace any defective part with a new or comparable rebuilt part or replace the Product with a new or comparable rebuilt part. This warranty shall not extend to other consumable parts or consumables, such as paper and ink bottles, as to which there shall be no warranty or replacement. Replacement products or parts shall not extend the original warranty period provided.
If purchased and used in the United States:        If purchased and used in Canada:
1-800-423-2366        1-800-OK-CANON
Monday through Friday from 8:00a.m. to 8:00p.m. ET*                                                         Monday through Friday from 9:00 a.m. to 6:00 p.m. ET*
You must cooperate with Canon in remotely diagnosing the Products malfunction. Canon may attempt to correct the malfunction remotely, with your assistance. If Canon cannot fix your Product’s malfunction through remote diagnostics, you will be provided instructions for Canon’s then current warranty service procedures. You may be asked for the Product serial number and other information pertaining to your Product. Canon may schedule an on-site service call by an independent authorized Canon Service Provider (the "Authorized Service Provider") for service or Canon may exchange the Product, as determined by Canon in its sole discretion, except where the malfunction involves a user replaceable item, in which case Canon will send you a replacement part with installation instructions. You will be responsible for installing the user replaceable items in your Product. The service delivery mechanism will be determined by Canon solely at its discretion. You will be charged the then-current respective service call rates of either Canon or the Authorized Service Provider if the defects in the Product are not covered by this limited warranty, or if the applicable warranty period for the Product has expired or warranty coverage has not been sufficiently established by appropriate documentation.
This warranty shall only apply if this Product is used in conjunction with compatible computers, peripheral equipment and software, as to which items Canon shall have no responsibility. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON, INCLUDING ANY IMPLIED WARRANTY OR CONDITION OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
THIS WARRANTY IS IN LIEU OF ALL OTHER WARRANTIES OR CONDITIONS, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTY OR CONDITION OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, RELATING TO THE USE OR PERFORMANCE OF THE PRODUCT. NO OTHER EXPRESS WARRANTY, CONDITION OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON OR ANY AUTHORIZED SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
THIS WARRANTY SHALL BE VOID AND OF NO FORCE AND EFFECT IF THE PRODUCT IS DAMAGED AS A RESULT OF (A) ABUSE, NEGLECT, MISHANDLING, ALTERATION, ELECTRIC CURRENT FLUCTUATION OR ACCIDENT, (B) IMPROPER USE, INCLUDING FAILURE TO FOLLOW OPERATING OR MAINTENANCE INSTRUCTIONS IN, OR ENVIRONMENTAL CONDITIONS PRESCRIBED IN, CANON’S USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT, (C) REPAIR BY OTHER THAN SERVICE REPRESENTATIVES QUALIFIED BY CANON WHO ARE ACTING IN ACCORDANCE WITH CANON’S SERVICE BULLETINS (D) USE OF SUPPLIES OR PARTS (OTHER THAN THOSE DISTRIBUTED BY CANON) WHICH DAMAGE THE PRODUCT OR CAUSE ABNORMALLY FREQUENT SERVICE CALLS OR SERVICE PROBLEMS OR (E) USE OF THE PRODUCT WITH NON-COMPATIBLE COMPUTERS, PERIPHERAL EQUIPMENT OR SOFTWARE, INCLUDING THE USE OF THE PRODUCT IN ANY SYSTEM CONFIGURATION NOT RECOMMENDED IN ANY USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT. NOR DOES THIS WARRANTY EXTEND TO ANY PRODUCT ON WHICH THE ORIGINAL IDENTIFICATION MARKS OR SERIAL NUMBERS HAVE BEEN DEFACED, REMOVED, OR ALTERED. ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE DISKETTES OR CD-ROM'S ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD “AS IS” AND WITHOUT WARRANTY BY CANON. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
NEITHER CANON OR ITS SUPPLIERS NOR ANY AUTHORIZED SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON OR ANY AUTHORIZED SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE T0 REALIZE SAVINGS OR OTHER BENEFITS, LOSS OR CORRUPTION OF DATA INCLUDING, WITHOUT LIMITATION, DATA STORED ON THE PRODUCT'S HARD DISK DRIVE, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON OR ANY AUTHORIZED SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON OR ANY AUTHORIZED SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS, ARISING OUT OF THE POSSESSION, USE, MISUSE OR INABILITY TO USE THE PRODUCT SOLD BY CANON NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON OR ANY AUTHORIZED SERVICE PROVIDER. THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE PURCHASER, AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
CONDITIONS OF WARRANTY
Defective parts must be returned to Canon or an Authorized Service Provider with all necessary documentation and will become the property of Canon. THIS WARRANTY APPLIES TO PRODUCTS SOLD AND USED IN THE U.S.A. AND CANADA ONLY.
*Actual hours of support are subject to change.
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
