Canon Support for imageRUNNER 1435iF | Canon U.S.A., Inc.
imageRUNNER 1435iF
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 06.23.15
File Size 10.38 MB
Date 06.23.15
File Size 0 B
Date 06.23.15
File Size 1.60 MB
imageRUNNER 1400 Series Spec Sheet
imageRUNNER 1435iF
MAIN UNIT
SYSTEM TYPEDigital Multifunction Imaging System
FUNCTIONSCopy, Print, Scan, Send, Fax
OPERATION PANEL 5-line LCD
MEMORY RAM 512 MB; Standard USB Port
NETWORK INTERFACE CONNECTION Standard: 1000Base-T, 100Base-TX, 10Base-T
Other: USB2.0 x1 (Host), USB1.1 x1(Host), USB (Device)
COPY SPEED Letter: Up to 37 ppmLegal: Up to 25 ppm
PRINT SPEED Letter: Up to 37 ppmLegal: Up to 25 ppm
FIRST-COPY-OUT TIME (LETTER) As fast as 6.9 Seconds
FIRST-PRINT-OUT TIME (LETTER) As fast as 5.0 Seconds
PAPER SOURCES (20 lb. Bond) Standard: 500-sheet Cassette 100-sheet Bypass
Optional: 500-sheet Cassette
Maximum: 1,100 Sheets
OUTPUT CAPACITY (20 lb. Bond) Maximum: 100 Sheets
OUTPUT PAPER SIZES Cassette: Letter, Legal
Bypass: Letter, Legal, Statement, Executive, Custom Size (3” x 5” to 8-1/2” x 14”), Envelope (C5/DL/ COM-10/Monarch)
ACCEPTABLE PAPER WEIGHTS Cassette: 17 lb. Bond to 24 lb. Bond (64 to 90 g/m2)
Bypass: 16 lb. Bond to 34 lb. Bond (60 to 128 g/m2
WARM-UP TIME From Power On: 20 Seconds or Less
From Sleep: 7.8 Seconds or Less
POWER REQUIREMENTS / PLUG 120-127 V AC, 60 Hz, 7.8 A/NEMA 5-15P
POWER CONSUMPTION Maximum: 1,500 W
Sleep Mode: 2.0 W or Less
DIMENSIONS (W X D X H) 18-3/4” x 21-1/2” x 18” (475.3 mm x 545 mm x 457 mm)
INSTALLATION SPACE (WXD) 30-3/8” x 18” (772.1 mm x 457 mm) (when the Multi-purpose Tray is extended)
WEIGHT Approx. 52.3 lb. (23.74 kg)
IMAGE READER UNIT
SCAN RESOLUTION Up to 600 x 600 dpi
ACCEPTABLE ORIGINALS (GLASS) Sheet, Book, 3-Dimensional objects up to 4.4 lb. (2 kg)
MAXIMUM ORIGINAL SIZE Up to 8-1/2” x 14”
DOCUMENT FEEDER
SCAN METHOD Duplexing Automatic Document Feeder
ACCEPTABLE ORIGINALS Paper Sizes: 5-1/2” x 5” to 8-1/2” x 14”
Paper Weights:
Simplex: 13 lb. to 28 lb. Bond (50 to 105 g/m2)
Duplex: 17 lb. to 28 lb. Bond (64 to 105 g/m2)
SCAN SPEED (BW / COLOR; LETTER) Simplex: Up to 29 ipm (BW)/10 ipm (Color)
Duplex: Up to 10 ipm (BW)/6 ipm (Color)
PAPER CAPACITY (20 lb. Bond) : Up to 50 Sheets (20 lb. Bond)
COPY SPECIFICATIONS
MULTIPLE COPIES 1 to 999
COPY EXPOSURE Automatic or Manual (17 Levels)
MAGNIFICATION 25% - 400% (1% Increments) from Platen Glass
PRESET REDUCTIONS 25%, 50%, 64%, 78%
PRESET ENLARGEMENTS 129%, 200%, 400%
BASIC COPY FEATURES Preset R/E Ratios by Area, Two-Sided, Exposure Adjustment, Original Type Selection, Setting Confirmation/Cancel, Standard Keys, Reset, ID Management, Counter Check
SPECIAL COPY FEATURES ID Card Copy, Frame Erase, Mode Memory, Sharpness, Image Combination, Different Size Original
PRINT SPECIFICATIONS
PROCESSOR Canon Dual Custom Processor (Shared)
ENGINE RESOLUTION 600 x 600 dpi; 1200 x 600 dpi (Enhanced)
PDL SUPPORT Standard: UFR II LT
Standard (1435iF/1435P): PCL 5e/6, and Adobe PS 3
Optional: Barcode Printing Kit
PRINT DRIVERS SUPPORTED OS UFR II LT, PCL 5e/6, Adobe PS 3, Windows® (XP/WindowsVista®/7/8/8.1), Windows Server (2003/2003R2/2008/2008 R2/ 2012/2012 R2), Windows Terminal Server(2003/2003R2/2008/2008 R2/2012/2012 R2),Microsoft Clustering Server 2003/2003R2/2008/2008 R2/2012/2012 R2),Microsoft App-V, Citrix(Presentation Server 4.5, XenApp 5.0/6.0/6.5/7.5,XenDesktop 4.0/5.0/5.5/5.6/7.0/7.1/7.5), VMware(vSphere 4/5/5.1), SAP (PS3, PCL), Macintosh® (OS X10.5.8 or later) (UFR II LT, PS 3)
DIRECT PRINT SUPPORT Standard: TIFF, JPEG
Standard:: PDF
PRINT FEATURES Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Printing on Transparencies, Front/ Back Covers, Objective, Toner Reduction, Poster Printing
SCAN SPECIFICATIONS
NETWORK TWAIN SCAN Standard
NETWORK SCAN UTILITY ScanGear MF
UNIVERSAL SEND SPECIFICATIONS
SENDING METHOD E-mail, USB, File Server (FTP, SMB)
COLOR MODE Color: 300 dpi, 200 dpi, 150 dpi
BW: 300 dpi, 150dpi
SCAN RESOLUTION 600 x 600 dpi, 400
ADDRESS BOOK CAPACITY Max. 300 Destinations (Incl. 19 One-Touch Buttons)
COMMUICATION PROTOCOL File: FTP (TCP/IP), SMB (TCP/IP)
E-mail: SMTP, POP3
FILE FORMAT Standard: TIFF, JPEG, PDF, PDF (Compact), PDF (Compact/OCR), PDF (OCR)
Optional: Encrypted PDF, Digital Signature PDF
UNIVERSAL SEND FEATURES Two Sided Original, Original Type Selection, Density Adjustment, Sharpness, Subject/Message, Reply-to, E-mail Priority, Senders Name
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES 1
MODEM SPEED Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
SENDING / RECORDING SIZE Letter, Legal, Statement
FAX FEATURES Job Forwarding, Adjusting Density, Sharpness, Specifying the Sender’s Name, Selecting the Telephone Line Type, Two-Sided Original, TX Archive, Distinctive Ring Detection
STORE SPECIFICATIONS
STANDARD USB Memory
SECURITY SPECIFICATIONS
STANDARD Department ID Management, IPv6, Restricting Features (Restricting New Addresses on Address Book, Allow Fax Driver TX, Restrict Recall, Confirm Entered Fax Numbers, Restrict Sequential Broadcast, Restrict USB Interface), Memory Lock, MAC/IP Address Filtering, SMTP Authentication POP Authentication before SMTP, IEEE802.1x, Authentication Feature for Send Operation (ASend), Secured Print, SNMP v1/v3, SSL Encrypted Communication, Fax Forwarding, Fax Destination Confirmation, USB Block, TLS Support for E-mail , Fax TX Archive
OPTIONAL Encrypted PDF, Device Signature PDF, uniFLOW
ENVIRONMENTAL INFORMATION
ENERGY STAR® Qualified
Rated EPEAT® Silver
EU RoHS Compliant
Blue Angel
WEEE Directive
CONSUMABLES
TONER GPR-54 Toner
TONER YIELD (ESTIMATED @ 6% COVERAGE) Black: 17, 600 Copies/Case
FOOTNOTES
* Duplexing Automat
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
