Canon Support for imageRUNNER 1435P | Canon U.S.A., Inc.
imageRUNNER 1435P
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
| Type | Digital Laser Printer |
| Functions | |
| Operation Panel | 5-line LCD |
| Image Server Memory | RAM 512 MB; Standard USB Port |
| Network Interface Connection | Standard: 1000Base-T, 100Base-TX, 10Base-T Other: USB2.0 x1 (Host), USB1.1 x1(Host), USB (Device) |
| Printing Resolution | 600 x 600 dpi; 1200 x 600 dpi (Enhanced) First-Print-Out-Time (Letter) As fast as 5.0 Seconds |
| Standard Paper Capacity | 500-sheet Cassette |
| Optional | 500-sheet Cassette |
| Manual Bypass | 100-sheet Bypass |
| Maximum Paper Capacity | 1,100 Sheets |
| Output Paper Capacity | (20 lb. Bond) Maximum: 100 Sheets |
| Warm Up Time | From Power On: 20 Seconds or Less From Sleep: 7.8 Seconds or Less |
| Power Requirements | 120-127 V AC, 60 Hz, 7.8 A |
| Power Consumption | Maximum: 1,500 W Sleep Mode: 2.0 W or Less |
| Plug | NEMA 5-15P |
| Dimension | (H x W x D) 15-1/8" x 21-1/2" x 18" (382.5 mm x 545 mm x 457 mm) |
| Installation Space | (W x D) 30-3/8" x 1 8" (772.1 mm x 457 mm) (when the Multi-purpose Tray is extended) |
| Weight | Approx. 47.3 lb. (21.44 kg) Special Media Support: Standard: USB Memory |
| Environmental Features | ENERGY STAR® Qualified Rated EPEAT® Silver EU RoHS Compliant* Blue Angel* WEEE Directive* |
Output Sizes
| Cassette | Letter, Legal |
| Bypass | Letter, Legal, Statement, Executive, Custom Size (3" x 5" to 8-1/2" x 14"), Envelope (C5/DL/ COM-10/Monarch) |
Security Features
| Standard | Department ID Management, IPv6, Restricting Features (Restricting New Addresses on Address Book, Restrict Recall, Restrict Sequential Broadcast, Restrict USB Interface), Memory Lock, MAC/IP Address Filtering, SMTP Authentication POP Authentication before SMTP, IEEE802.1x, Secured Print, SNMP v1/v3, SSL Encrypted Communication, USB Block, TLS Support for E-mail |
| Optional | Encrypted PDF, Device Signature PDF, uniFLOW |
| Estimated Toner Yield | 17,600 Copies/Bottle (Estimated Yield @ 6% Coverage) |
Paper Supply Options
| Description | Cassette Module - AC1 |
| Paper Capacity | 500-Sheet Cassette [20 lb. Bond (80 g/m2)] |
| Paper Size | Legal, Letter |
| Paper Weight | 17 lb. Bond to 24 lb. Bond (64 to 90 g/m2) |
| Power Source | From the Main Unit |
| Power Consumption | Approximately 3.6 W |
| Dimensions | 6-1/8" x 20-1/2" x 17-3/4" (54.8 mm x 520 mm x 450.8 mm) |
| Weight | Approximately 11 lb. (5 kg) |
| Description | Cabinet Type - K |
| Dimensions | 21-7/8" x 20-1/2" x 17-1/4" (554 mm x 520 mm x 439 mm) |
| Weight | 40 lb. (18.14 kg) |
| Description | FL Cassette - AW1 |
next to your download
