Canon Support for imageRUNNER 1643iF | Canon U.S.A., Inc.
imageRUNNER 1643iF
Language
Type
Our software & drivers for your product are specific to your operations system. We've detected your operating system as {{os}}. If you need software or drivers for a different operating system make sure to select the correct operating system & version with the dropdowns below. Not all our software & drivers are compatible with all operating systems and versions.
of
There are no results for the OS Version you selected.
image icon
Canon PRINT Business - iOS
Easily print from and scan to your iCloud accounts right from your smartphone or tablet with the Canon PRINT Business app. Available for select imageRUNNER ADVANCE and imageCLASS printers.
image icon
Canon PRINT Business - Android
Easily print from and scan to your Dropbox, Google Drive accounts right from your smartphone or tablet with the Canon PRINT Business app. Available for select imageRUNNER ADVANCE and imageCLASS printers.
imageRUNNER 1643 Series Brochure
imageRUNNER 1643iF
MAIN UNIT
TYPE
Monochrome Laser Multifunctional
CORE FUNCTIONS
Print, Copy, Scan, Send, Fax
PROCESSOR
Canon Dual Custom Processor2 (Shared)
OPERATION PANEL
5" TFT LCD WVGA Color Touch Panel
MEMORY
1.0 GB RAM
INTERFACE CONNECTION
Network (Standard): 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n), NFC,1 Wi-Fi Direct Connection
Others (Standard): USB 2.0 (Host) x2, USB 2.0 (Device) x1
PAPER SOURCES (LETTER, 20 LB. BOND)
Standard: 550-sheet Paper Cassette, 100-sheet Stack Bypass
Optional: 550-sheet PAPER FEEDER PF-C1 (up to 3)
Maximum: 2,300 Sheets
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)
Maximum: 150 Sheets
SUPPORTED MEDIA SIZES
Cassette: Letter, Legal, Statement, Executive Bypass: Letter, Legal, Statement, Executive, Custom size
(3" x 5" to 8-1/2" x 14"), Envelope (C5/DL/ COM-10/Monarch)
SUPPORTED MEDIA WEIGHTS
Cassette: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2)
Bypass: 16 lb. Bond to 73 lb. Cover (60 to 199 g/m2)
COPY SPEED/PRINT SPEED
Up to 45 ppm (Letter); Up to 36 ppm (Legal)
WARM-UP TIME
From Power On: 14 Seconds or Less2
From Sleep Mode: 4 Seconds or Less
DIMENSIONS (W x D x H)
19-7/16” x 18-5/16” x 17-3/16” (494 mm x 465 mm x 452 mm)
INSTALLATION SPACE (W x D x H)
27-7/8” x 43-1/2” (708 mm x 1105 mm)
WEIGHT3
Approx. 41.9 lb. (19 kg)
PRINT SPECIFICATIONS
FIRST-PRINT-OUT TIME (LTR)
Approx. 5.7 Seconds
PRINT RESOLUTION (dpi)
600 × 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II LT, PCL®5e/6, Adobe® PS® 3 (Standard on 1643iF/1643P, optional on 1643i) Optional: Barcode Printing Kit
DIRECT PRINT
Supported File Types:
TIFF, JPEG, PDF and XPS (only LPR) Available from USB memory, LPR
OPERATING SYSTEM
Windows 10/8.1/7 (32/64 bit), Windows Server (2019/2016/2012 R2 (64 bit)/2012 (64 bit)/ 2008 R2 (64 bit) /2008 (32/64 bit), Mac® (OS X 10.6 and later => 10.9 , 10/14) Linux (Web Distribution)
PRINT FEATURES
Suspend Job Timeout, Profile Settings, Secure Print, Header/ Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Front/ Back Covers, Toner Reduction, Poster Printing
COPY SPECIFICATIONS
FIRST-COPY-OUT-TIME
As fast as 6.0 Seconds (via Platen)
COPY RESOLUTION (dpi)
Reading/ Printing: Up to 600 x 600
COPY SPECIFICATIONS
Automatic or Manual (9 Levels)
MULTIPLE COPIES
Up to 999
MAGNIFICATION
25% - 400% (1% Increments) from Platen Glass
PRESET REDUCTIONS
25%, 50%, 64%, 78%
PRESET ENLARGEMENTS
129%, 200%, 400%
BASIC COPY FEATURES
Preset R/E Ratios by Area, Paper Setting, Favorite Setting, Two-Sided, Density Adjustment, Original Type Selection
SPECIAL COPY FEATURES
Two-sided Original, Sort, Job Build, N on 1, Different Size Originals, Density Adjustment, Original Type Selection, Sharpness, Erase Frame, Copy ID Card
SCAN SPECIFICATIONS
TYPE
Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY
LTR: 50 Sheets (20 lb. Bond), LGL: 30 Sheets (20 lb. Bond)
MAXIMUM ORIGINAL SIZE
Up to 8-1/2" x 14"
DOCUMENT FEEDER SUPPORTED MEDIA SIZES
4-1/8" x 5" to 8-1/2" x 14"
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS
Simplex: 13 lb. to 28 lb. Bond (50 to 105 g/m2)
Duplex: 17 lb. to 28 lb. Bond (64 to 105 g/m2)
PLATEN ACCEPTABLE ORIGINALS
Sheet, Book, 3-Dimensional Objects
NETWORK TWAIN SCAN
Standard
NETWORK SCAN UTILITY
ScanGear MF
SCAN RESOLUTION
Up to 600 x 600
SCAN SPEED (LETTER)
300 dpi
Simplex: Up to 38ipm (BW)/ 13ipm (Color) / Duplex: Up to 70ipm (BW)/ 26 (Color)
600 dpi
Simplex: Up to 21 ipm (BW) / Duplex: Up to 35 ipm (BW)
SEND SPECIFICATIONS
DESTINATION
E-mail/Internet FAX (SMTP), SMB, FTP
COLOR MODE
Color, BW
ADDRESS BOOK
LDAP (50)/Local (300)/Speed Dial (281)
SEND RESOLUTION
600 dpi, 300 dpi (CL/BW)
COMMUICATION PROTOCOL
File: FTP (TCP/IP), SMB (TCP/IP)
Email: SMTP, POP3
FILE FORMAT
Standard: TIFF, JPEG, PDF(Compact, Searchable, Encrypted, Digital Signature)
UNIVERSAL SEND FEATURES
Original Type Selection, Two-sided Original, Density Adjustment, Sharpness, File Name, Subject/Message, E-mail Priority, TX Report, Original Content Orientation
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES
One
MODEM SPEED
Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD
MH, MR, MMR, JBIG
RESOLUTION
400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE
FAX FEATURES
Two-sided Original, Density (for Scanning), Sharpness, TX Report, RX Mode, Resolutions, Favorite Settings
STORE SPECIFICATIONS
MEMORY MEDIA
Standard: USB
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard: Department ID, Embedded Universal Login Manager, uniFLOW Online Express4
Optional: uniFLOW and uniFLOW Online
NETWORK
Standard: IP/Mac Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP
DOCUMENT
Standard: Secure Print, Encrypted PDF, Device Signature
ENVIRONMENTAL SPECIFICATIONS
POWER REQUIREMENTS
120-127 V, 60 Hz, 7.1 A
PLUG (MAIN UNIT)
NEMA 5-15P
POWER CONSUMPTION
Maximum: Approx. 1430W
Sleep Mode: 0.9 W5
Typical Electricity Consumption (TEC) Rating:6 0.40 kWh
STANDARDS
ENERGY STAR® Certified Rated EPEAT® Silver1
CONSUMABLES
TONER
T06 Black (All-In-One Toner Cartridge)
TONER YIELD (ESTIMATED @ 5% COVERAGE)
20,500 images (Estimated Yield @ ISO 19752 Coverage)
FOOTNOTES
  1. For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
  2. Time from device power-on until copy ready (not print reservation).
  3. Includes consumables.
  4. No charge for this solution, however activation is required.
  5. 0.9 W Sleep mode not available in all circumstances due to certain settings.
  6. Based on ENERGY STAR Product Specification for Imaging Equipment Version 3.0.
NOTE: Check for availability and details for uniFLOW solutions.
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
