Canon Support for imageRUNNER 1643P | Canon U.S.A., Inc.
imageRUNNER 1643P
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
imageRUNNER 1643 Series Brochure
imageRUNNER 1643P | |
MAIN UNIT | |
| TYPE | Monochrome Laser Printer |
| CORE FUNCTIONS | Print |
| PROCESSOR | Canon Dual Custom Processor2 (Shared) |
| OPERATION PANEL | 5-Line LCD Panel |
| MEMORY | 1.0 GB RAM |
| INTERFACE CONNECTION2 | 1000Base-T/100Base-TX/10-Base-T Others (Standard): USB 2.0 (Host) x3, USB 2.0 (Device) x1 |
| PAPER SOURCES (LETTER, 20 LB. BOND) | Standard: 550-sheet Paper Cassette, 100-sheet Stack Bypass Optional: 550-sheet PAPER FEEDER PF-C1 (up to 3) Maximum: 2,300 Sheets |
| PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) | Maximum: 150 Sheets |
SUPPORTED MEDIA SIZES | Cassette: Letter, Legal, Statement, Executive Bypass: Letter, Legal, Statement, Executive, Custom size (3" x 5" to 8-1/2" x 14"), Envelope (C5/DL/ COM-10/Monarch) |
| SUPPORTED MEDIA WEIGHTS | Cassette: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2) Bypass: 16 lb. Bond to 73 lb. Cover (60 to 199 g/m2) |
| PRINT SPEED (BW AND COLOR) | Up to 45 ppm (Letter); Up to 36 ppm (Legal) |
| WARM-UP TIME | From Power On: 30 Seconds or Less3 From Sleep Mode: 3 Seconds or Less |
| DIMENSIONS (W x D x H) | 16-1/8” x 14-13/16” x 10-13/16” (409 mm x 376 mm x 275 mm) |
| INSTALLATION SPACE (W x D x H) | 24-5/16” x 43-7/16” (617 mm x 1104 mm) |
| WEIGHT4 | Approx. 25.3 lb. (11.5 kg) |
PRINT SPECIFICATIONS | |
| FIRST-PRINT-OUT TIME (LTR) | Approx. 5.7 Seconds |
| PRINT RESOLUTION (dpi) | 600 × 600 |
| STANDARD PAGE DESCRIPTION LANGUAGES | UFR II LT, PCL®5e/6, Adobe® PS® 3 (Standard on 1643iF/1643P, optional on 1643i) Optional: Barcode Printing Kit |
| DIRECT PRINT | Supported File Types: TIFF, JPEG, PDF and XPS (only LPR) Available from USB memory, LPR |
| OPERATING SYSTEM | Windows 10/8.1/7 (32/64 bit), Windows Server (2019/2016/2012 R2 (64 bit)/2012 (64 bit)/ 2008 R2 (64 bit) /2008 (32/64 bit), Mac® (OS X 10.6 and later => 10.9 , 10/14) Linux (Web Distribution) |
| PRINT FEATURES | Suspend Job Timeout, Profile Settings, Secure Print, Header/ Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Front/ Back Covers, Toner Reduction, Poster Printing |
STORE SPECIFICATIONS | |
| MEMORY MEDIA | Standard: USB |
SECURITY SPECIFICATIONS | |
| AUTHENTICATION | Standard: Department ID Optional: uniFLOW and uniFLOW Online |
| NETWORK | Standard: IP/Mac Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6 |
| DOCUMENT | Standard: Secure Print |
ENVIRONMENTAL SPECIFICATIONS | |
| POWER REQUIREMENTS | 120-127 V, 60 Hz, 7.1 A |
| PLUG (MAIN UNIT) | NEMA 5-15P |
| POWER CONSUMPTION | Maximum: Approx. 1370W Sleep Mode: 1.9 W5 Typical Electricity Consumption (TEC) Rating6 0.50 kWh |
| STANDARDS | ENERGY STAR® Certified Rated EPEAT® Silver1 |
CONSUMABLES | |
| TONER | Toner T06 Black |
| TONER YIELD (ESTIMATED @ 5% COVERAGE) | 20,500 Images (Estimated Yield @ ISO 19752 Coverage) |
FOOTNOTES | |
ADDITIONAL SUPPORT
CONTACT US
next to your download
