Canon Support for imageRUNNER 1750iF | Canon U.S.A., Inc.
imageRUNNER 1750iF
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Model Name imageRUNNER 1750iF
Type Digital Multifunction Imaging System Functions: Standard: Copy, Print (UFR II LT, PCL, PostScript® 3 Emulation), Scan, Send, Fax Operation Panel: 5.7" QVGA Black-and-White LCD Touch-Screen
Image Server Memory Standard/ Maximum: 512MB RAM
Network Interface Connection: Ethernet 10/100Base-TX
Other Interface: Standard: USB 2.0 (Host)x1, USB 2.0 (Device)x1
Letter Up to 52 ppm
First Copy Time 5.0 Seconds
Multiple Copies 1 to 999
Magnification 25% - 400% (1% Increments)
Preset Reductions 25%, 50%, 64%, 78%
Preset Enlargements 129%, 200%, 400%
Standard Paper Capacity (20 lb. Bond): 550-sheet Paper Cassette
100-sheet Stack Bypass
Optional: 550-sheet Paper Cassette (up to three)
Maximum Paper Capacity 2,300 Sheets
Output Sizes
Cassette Cassette 1/3/4: Legal, Letter, Statement, Executive
Cassette 2: Legal, Letter, Statement, Executive, Envelopes (COM10 No.10/Monarch/ DL/ISO-B5/ISO-C5)&Delta;*
Bypass Legal, Letter, Statement, Executive, Envelopes (COM10 No.10/Monarch/DL/ ISO-B5/ISO-C5), Custom Size [3-15/16" to 8-1/2" x 5-9/16" to 14-1/8" (99mm to 216mm x 140mm to 356mm)]
Acceptable Paper Weights
Cassette 17 lb. Bond to 28 lb. Bond
Bypass 17 lb. Bond to 34 lb. Bond
Duplexing Paper Size: Standard Automatic Trayless Duplexing (Statement to Legal)
Paper Weight: 17 lb. Bond to 28 lb. Bond
Warm Up Time From Power On: 30 Seconds or Less
From Sleep Mode: 10 Seconds or Less
Exposure Control Automatic or Manual (9 Levels)
Power Requirements 120V AC, 60Hz, 9.3A
Plug: NEMA 5-15P
Power Consumption: Maximum: 1.5kW or Less; Sleep Mode: 1W
Dimension 24-7/8" x 22-1/8" x 19-3/4"
Installation Space (W x D): 37-1/8" x 37-3/4" (with no optional equipment attached)
50-1/4" x 37-3/4" (with the optional Staple Finisher-H1 attached)
Weight Approximately 97.7 lb.**
Estimated Toner Yield 15,100 Images @ 6% Coverage Basic Copy Features Preset R/E Ratios by Area, Finishing, Two-sided, Exposure Adjustment, Original Type Selection Special Copy Features Image Combination, Frame Erase, Different Size Original, Sharpness, Mode Memory, ID Card Copy Scan Specifications
Network TWAIN Scan Standard
Network Scan Utility Color Network Scan Gear Security Specifications
Department ID Management, User ID Management, IPv6, Restricting Features (Restricting New Addresses on Address Book, Address Book Password, Allow Fax Driver TX, Restrict Recall, Confirm Entered Fax Numbers, Restrict Sequential Broadcast, Restrict USB Interface), Memory Lock, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP, IEEE802.1x, Authentication Feature for Send Operation (AuSend), uniFLOW Serverless Secure Printing&bull;, Secured Print&bull;&bull;Environmental Information RoHS Compliant Blue Angel Mercury-free
Feeders
Description Duplexing Automatic Document Feeder
Acceptable Originals Letter, Statement-R, Legal
Scanning Speed 52/52 ipm (300 dpi)
Paper Weights BW Originals: 13 lb. Bond to 34 lb. Bond
Color Originals: 17 lb. Bond to 34 lb. Bond
Description Cassette Module-Y1*
Acceptable Originals Legal, Letter, Statement, Executive
Acceptable Paper Type: Plain, Recycled, Color, 3-hole Punch, Heavy Paper (24 lb. Bond to 28 lb. Bond)
Capacity 550 Sheets x 1 Cassette (20 lb. Bond)
Paper Weights 17 lb. Bond to 28 lb. Bond
Dimensions 4-3/4" x 21-1/4" x 19-3/4"&loz;&loz;
Weight Approximately 17 lb
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
