Canon Support for imageRUNNER ADVANCE C5540i III | Canon U.S.A., Inc.
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
SELECT ERROR CODE
imageRUNNER ADVANCE C5500 III Series Spec Sheet
imageRUNNER ADVANCE C5540i III | |
MAIN UNIT | |
TYPE | Color Laser Multifunctional |
CORE FUNCTIONS | Standard: Print, Copy, Scan, Send, Store |
PROCESSOR | Canon Dual Custom Processor (Shared) |
CONTROL PANEL | 10.1" TFT LCD WSVGA Color Flat-panel |
MEMORY | 4.0 GB RAM |
HARD DISK DRIVE | Standard: 250 GB |
MIRRORING HARD DISK DRIVE | Optional: 250 GB, 1 TB |
INTERFACE CONNECTION | Network |
PAPER CAPACITY (LETTER, 20 LB. BOND) | Standard: 1,200 Sheets |
PAPER SOURCES (LETTER, 20 LB. BOND) | Standard: Dual 550-sheet Paper Cassettes, 100-sheet Stack Bypass |
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) | Standard: 250 Sheets |
FINISHING CAPABILITIES | Standard: Collate, Group |
SUPPORTED MEDIA TYPES | Paper Cassette 1: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Letterhead, Bond, Transparency, Envelope |
SUPPORTED MEDIA SIZES | Paper Cassette 1: Letter, Executive, Statement-R, Envelope [No.10 (COM10), DL, ISO-C5], Custom Size (3-7/8" x 5-7/8" to 11-3/4" x 8-1/2") |
SUPPORTED MEDIA WEIGHTS | Cassettes: 14 lb. Bond to 140 lb. Index (52 to 256 g/m2) |
WARM-UP TIME | From Power On: Approx. 10 Seconds2 |
DIMENSIONS (W x D x H) | 24-3/8" x 29-1/4" x 37-3/8"(620 mm x 742 mm x 950 mm)5 |
INSTALLATION SPACE (W x D x H) | Basic: Stack Bypass + Cassette Drawers open: 37-1/8" x 46-3/8" (943 mm x 1,176 mm) |
WEIGHT | 310.9 lb. (141 kg)6 |
PRINT SPECIFICATIONS | |
PRINT SPEED (BW AND COLOR) | Up to 40 ppm (Letter); Up to 24 ppm (Letter-R); Up to 23 ppm (Legal); Up to 22 ppm (11" x 17") |
PRINT RESOLUTION (dpi) | 1200 x 1200, 600 x 600 |
STANDARD PAGE DESCRIPTION LANGUAGES | UFR II, PCL®6, Adobe® PS® 3 |
DIRECT PRINT | Available from USB, Advanced Box, Remote UI, and Web Access7 |
SUPPORTED FILES | PDF, TIFF, JPEG, EPS,8 XPS |
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES | A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet connected devices and cloud-based services depending on your requirements. |
FONTS | PCL fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),9 Barcode Fonts10 |
OPERATING SYSTEM 11 | UFRII: Windows¿ Server 2008/Windows¿ 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.9 or later) |
PRINT FEATURES | Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Forced Hold Printing, Watermark, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Front/Back Covers, Toner Reduction, Poster Printing |
COPY SPECIFICATIONS | |
COPY SPEED (BW AND COLOR) | Up to 40 ppm (Letter); Up to 24 ppm (Letter-R); Up to 23 ppm (Legal); Up to 22 ppm (11" x 17") |
FIRST-COPY-OUT-TIME | As fast as 4.1 seconds (BW)/ 6.1 seconds (Color) |
COPY RESOLUTION (DPI) | Reading: 600 x 600 |
MULTIPLE COPIES | Up to 999 Copies |
COPY EXPOSURE | Automatic or Manual (9 Levels) |
MAGNIFICATION | 25%-400% (1% Increments) |
PRESET REDUCTIONS | 25%, 50%, 64%, 73%, 78% |
PRESET ENLARGEMENTS | 121%, 129%, 200%, 400% |
BASIC COPY FEATURES | Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
SPECIAL COPY FEATURES | Book to Two Pages, Two-sided Original, Finishing, Booklet, Job Build, N on 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Print on Tab, Store in Mail Box, Superimpose Image, Copy ID Card, Skip Blank Pages, Detect Feeder Multi Sheet Feed, Free Size Original, Color Balance, Adjust One-Touch Color, Area Designation |
SCAN SPECIFICATIONS | |
TYPE | Color Platen and Single-pass Duplexing Automatic Document Feeder |
DOCUMENT FEEDER PAPER CAPACITY | 150 Sheets (20 lb. Bond) |
DOCUMENT FEEDER SUPPORTED MEDIA SIZES | 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R, Custom Size: 5" x 5-1/2" to 12" x 17" |
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | BW Original: 13 lb. Bond to 58 lb. Cover (50 to 157 g/m2 ) |
PLATEN ACCEPTABLE ORIGINALS | Sheet, Book, 3-Dimensional Objects [Height: up to 2" (50 mm), Weight: Up to 4.4 lb. (2kg)] |
PULL SCAN | Color Network ScanGear2 for both Twain and WIA |
SCAN RESOLUTION | 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x 100, 150 x 150, 100 x 100 |
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of solutions is available to provide scanning to mobile devices and cloud-based services depending on your requirements. |
SCAN SPEED (LETTER) | Single-sided Scanning (BW): 80 ipm (300 dpi)/80 ipm (600 dpi) |
SEND SPECIFICATIONS | |
DESTINATION | Email/Internet Fax (SMTP), SMB v3.0, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional) |
COLOR MODE | Automatic-Color Select (Full Color/Grayscale), Automatic Color Select (Full Color/Black-and-White), Full color, Grayscale, and Black-and-White |
ADDRESS BOOK | LDAP (2,000)/Local (1,600)/Speed dial (200) |
SEND RESOLUTION | 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x 100, 150 x 150, 100 x 100 |
COMMUICATION PROTOCOL | File: FTP (TCP/IP), SMB v3.0, WebDAV |
FILE FORMAT | Standard: TIFF, JPEG, PDF (Encrypted, Compact, Searchable, Apply Policy, Optimize for Web, PDF A/1-b), Limited Color, Device Signature, XPS (Compact, Searchable, Device Signature), Office Open XML (PowerPoint¿, Word) |
UNIVERSAL SEND FEATURES | Original Type Selection,Two-sided Original, Book to Two Pages, Different-size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Job Done Notice, File Name, Subject/Message, Reply-to, Email Priority, TX Report, Original Content Orientation, Skip Blank Originals, Detect Feeder Multi Sheet Feed |
FAX SPECIFICATIONS | |
MAXIMUM NUMBER OF LINES | 4 |
MODEM SPEED | Super G3: 33.6 kbps |
COMPRESSION METHOD | MH, MR, MMR, JBIG |
RESOLUTION | 400 x 400, 200 x 400, 200 x 200, 200 x 100 |
SENDING / RECORDING SIZE | Statement-R to 11" x 17" |
FAX MEMORY | Up to 30,000 Pages |
SPEED DIALS | Max. 200 |
GROUP DIALS / DESTINATIONS | Max. 199 Dials |
SEQUENTIAL BROADCAST | Max. 256 Addresses |
MEMORY BACKUP | Yes |
FAX FEATURES | Original Type Selection, Two-sided Original, Book to Two Pages, Different-size Originals, Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Sender's Name (TTI), Select Line, Selecting the Telephone Line, Direct Send, Delayed Send, Preview, Job Done Notice, TX Report, Detect Feeder Multi Sheet Feed |
STORE SPECIFICATIONS | |
MAIL BOX SIMPLE (NUMBER SUPPORTED) | 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored |
ADVANCED BOX | Communication Protocol: SMB or WebDAV |
ADVANCED BOX AVAILABLE DISC SPACE | Approx. 16 GB (Standard HDD) |
ADVANCED BOX FEATURES | Authentication for Advanced Box Log-in, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
MEMORY MEDIA | Standard: USB |
SECURITY SPECIFICATIONS | |
AUTHENTICATION | Standard: Universal Login Manager, uniFLOW Online Express,12 User Authentication, Department ID Authentication, Access Management System, Device and Function Level Log-in |
DATA | Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption(FIPS140-2 Validated), Verify System at Startup, McAfee Embedded Control13 |
NETWORK | Standard: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, S/MIME, SIEM Integration |
DOCUMENT | Standard: Secure Watermark, Encrypted PDF, Encrypted Secure Print, Digital Signatures, Adobe LiveCycle¿ Rights Management ES2.5 Integration |
ENVIRONMENTAL SPECIFICATIONS | |
OPERATING ENVIRONMENT | Temperature: 50 to 86 ºF |
POWER REQUIREMENTS | 120-127V AC,60 Hz,10 A |
PLUG (MAIN UNIT) | NEMA 5-15P |
POWER CONSUMPTION | Maximum: Approx. 1,800 W |
STANDARDS | ENERGY STAR® Certified |
CONSUMABLES | |
TONER | GPR-55 Toner17 |
TONER YIELD (ESTIMATED @ 6% COVERAGE) | Black: 69,000 Images |
FOOTNOTES | |
