Canon Support for imageRUNNER ADVANCE DX 6755i | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
MAIN UNIT
TYPE Monochrome Laser Multifunctional
CORE FUNCTIONS Standard: Print, Copy, Scan, Send, Store
Optional: Fax
PROCESSOR 1.75GHz Dual Core Processor
CONTROL PANELStandard: 10.1" TFT LCD WSVGA Color Flat Touch-panel
Optional 10.4" TFT LCD SVGA Color Upright Touch-panel
MEMORY3.0 GB RAM
HARD DISK DRIVEStandard: 250 GB
Maximum: 1 TB
INTERFACE CONNECTION Network
Standard: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n)
Optional: NFC, Bluetooth Low Energy
Others
Standard: USB 2.0 x1 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device)
Optional: Copy Control Interface
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 4,360 Sheets
Maximum: 8,020 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)Standard: Dual 1,560-sheet Paper Drawers, Dual 570-sheet Paper Cassettes, 100-sheet Multipurpose Tray
Optional: 3,660-sheet Paper Deck (Paper Deck Unit-E1 or POD Deck Lite-C1)
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)With Copy Tray: 250 Sheets
With External Finishers: 3,500 Sheets (with Staple Finisher-AC1 or Booklet Finisher-AC1)
FINISHING CAPABILITIESWith External Finishers: Collate, Group, Offset, Staple, Saddle Stitch, Hole Punch, Eco Staple, Staple On Demand, Document Insertion, Z-fold, C-fold
SUPPORTED MEDIA TYPESPaper Cassettes: Thin, Plain, Recycled, Color, Heavy, Bond, Pre-punched, Letterhead, Tab1
Multipurpose Tray: Thin, Plain, Recycled, Color, Heavy, Tracing,2 Bond, Transparency, Label, Pre-punched, Letterhead, Tab
Paper Decks: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Letterhead, Bond, Transparency, Labels, Tab
SUPPORTED MEDIA SIZES
Multipurpose Tray: 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size/Free Size
(4" x 5-7/8" to 11-3/4" x 19-1/4")
Paper Decks: Letter
Paper Cassettes: 11"x17", Legal, Letter, Letter-R, Executive, Statement-R, Custom size
(5-1/2" x 7-1/8" to 11-3/4" x 19-1/4")
SUPPORTED MEDIA WEIGHTSPaper Decks: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
Paper Cassettes: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
Multipurpose Tray: 14 lb. Bond to 140 lb. Index (52 to 256 g/m2)
Duplexing: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
PRINT/COPY SPEED Up to 55 ppm (Letter)
Up to 43 ppm (Letter-R)
Up to 39 ppm (Legal)
Up to 32 ppm (11" x 17")
WARM-UP TIMEFrom Power On: Approx. 30 Seconds3
From Sleep Mode: Approx. 30 Seconds4
Quick Startup Mode: Approx. 4 Seconds5
DIMENSIONS (W x D x H)26-3/8" x 30-3/8" x 46-5/8" (670 x 770 x 1,185 mm)
INSTALLATION SPACE (W x D x H) Basic: 60-3/8" x 53-1/4" (1,533 mm x 1,353 mm) (with Multi-purpose Tray/upper-right cover open + front cover open + Copy Tray)
Fully Configured: 95-7/8" x 53-1/4" (2,436 mm x 1,353 mm) (with POD Deck Lite-C1 + Document Insertion/Folding Unit-J1 + Booklet FinisherAC1/Staple Finisher-AC1 + Main unit front cover open )
WEIGHTStandard: Approx. 482.8 lb (219 kg)6
With Upright Touch Panel Approx. 491.6 lb (223 kg)6
PRINT SPECIFICATIONS
PRINT RESOLUTION 1200 x 1200
STANDARD PAGE DESCRIPTION LANGUAGESUFR II, PCL®6, Adobe® PS® 3
SUPPORTED FILE TYPES FOR DIRECT PRINTPDF, TIFF, JPEG, EPS,7 XPS
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES A range of standard and optional software and MEAP-based solutions (including AirPrint, Mopria, Universal Print by Microsoft, Canon PRINT Business, and uniFLOW Online) are available to provide printing from mobile devices or internet-connected devices and cloud-based services depending on your requirements. Please contact your sales representative for further information.
FONTS PCL Fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),8 Barcode Fonts9
PS Fonts: 136 Roman
OPERATING SYSTEM 10 UFRII/PS: Windows®7/8.1/10/Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/ Server 2016/Server 2019, MAC OS X (10.10 or later)
PCL: Windows®7/8.1/10/Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/ Server 2016/Server 2019
PPD: Windows®7/8.1/10, MAC OS X (10.9 or later)
COPY SPECIFICATIONS
FIRST-COPY-OUT-TIME As fast as 3.3 seconds
COPY RESOLUTION (dpi)600 x 600
MULTIPLE COPIESUp to 9,999 Copies
MAGNIFICATION 25%-400% (1% Increments)
PRESET REDUCTION / ENLARGEMENT 25%, 50%, 64%, 73%, 78%, 100%(1:1), 121%, 129%, 200%, 400%
SCAN SPECIFICATIONS
TYPE Single-pass Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY Up to 200 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R, Custom size: 2-3/4" x 5-1/2" to 12" x 17"
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS Single-sided/Double-sided scanning: 13.3 lb bond to 80 lb. cover (50 to 220 gsm)
PLATEN ACCEPTABLE ORIGINALS Sheet, Book, 3-Dimensional Objects
Max. Platen Scanning Size: Up to 11-3/4" x 17" (297 mm x 431.8 mm)
PULL SCAN Color Network ScanGear2 for both Twain and WIA Supported OS: Windows 7/8.1/10 Server 2008/Server 2008 R2/Server 2012/ Server 2012 R2/Server 2016
SCAN RESOLUTIONScan for Copy: 600 x 600
Scan for Send: (Push) 600 x 600 (SMB/FTP/WebDAV/IFAX), (Pull) 600 x 600
Scan for Fax: 600 x 600
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES A range of solutions is available to provide scanning to mobile devices and cloud-based services depending on your requirements.
SCAN SPEED (LETTER)Single-sided Scanning
BW/Color: 135 (300 dpi)/80 (600 dpi)
Double-sided Scanning
BW/Color: 270 (300 dpi)/160 (600 dpi)
SEND SPECIFICATIONS
DESTINATION Email/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional)
ADDRESS BOOK LDAP (2,000)/Local (1,600)/Speed dial (200)
SEND RESOLUTION Push: Up to 600 x 600
Pull: Up to 600 x 600
COMMUICATION PROTOCOLFile: FTP, SMB v3.0, WebDAV
Email: SMTP, POP3
FILE FORMAT TIFF, JPEG, PDF(Compact, Searchable, Apply policy, Optimize for Web, PDF/A-1b, Trace & Smooth, Encrypted, Device Signature, User Signature), XPS(Compact, Searchable, Device Signature, User Signature), Office Open XML (PowerPoint, Word)
FAX SPECIFICATIONS
MODEM SPEED Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE Statement-R to 11" x 17"
FAX MEMORY Up to 30,000 Pages (2,000 jobs)
SPEED DIALSMax. 200
GROUP DIALS / DESTINATIONS Max. 199 Dials
SEQUENTIAL BROADCASTMax. 256 Addresses
MEMORY BACKUPYes
STORE SPECIFICATIONS
MAIL BOX SIMPLE (NUMBER SUPPORTED)100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, Maximum 30,000 Pages (2,000 jobs) Stored
ADVANCED BOX Communication Protocol: SMB or WebDAV
Supported Client PC: Windows (Windows 8.1/10)
Concurrent Connections (Max.):
SMB: 64
WebDAV: 3 (Active Sessions)
ADVANCED BOX AVAILABLE DISC SPACEApprox. 16 GB (Standard HDD); 480 GB (With Optional 1 TB HDD)
SECURITY SPECIFICATIONS
AUTHENTICATIONStandard: Universal Login Manager, uniFLOW Online Express,11 User Authentication, Department ID Authentication, (Device and Function Level Log-in), Access Management System
Optional: uniFLOW
DATA Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption(FIPS140-2 Validated), Verify System at Startup, McAfee Embedded Control2
Optional: Hard Disk Drive Mirroring, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW)
NETWORKStandard: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication (v1.0/1.1/1.2/1.3), SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, S/MIME, SIEM Integration
DOCUMENTStandard: Secure Watermark, Secure Print, Adobe LiveCycle® Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device Signature, User Signature
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENTTemperature: 50 to 86 ºF
Humidity: 20 to 80 % RH (Relative Humidity)
POWER REQUIREMENTS 110-127 V AC, 60 Hz, 16 A
POWER CONSUMPTIONMaximum: Approx. 2,032 W
Standby: Approx. 278 W12
Sleep Mode: 0.9 W13
CONSUMABLES
TONER
GPR-38 Toner Black
TONER YIELD (ESTIMATED @ 6% COVERAGE)
Black: 56,000 Images
FOOTNOTES
  1. Tab Feeding Attachment-B1 is required.
  2. Some types of tracing paper cannot be used.
  3. Time from device power-on, until copy ready (not print reservation).
  4. Time from exiting Sleep mode to when printing is operational.
  5. Time from device power on to when the copy icon appears and is enabled to operate on the touch panel display.
  6. Includes consumables.
  7. EPS can be printed directly only from the Remote User Interface.
  8. Requires the optional PCL International Font Set-A1.
  9. Requires the optional Barcode Printer Kit-D1.
  10. Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
  11. No charge for this solution; however activation is required.
  12. Standby Reference Value: measured one unit.
  13. 0.9 W sleep mode not available in all circumstances due to certain settings.
Title Service Notice: Google Termination of Support for Google Cloud Print will be ending December 31, 2020.
Advisory Type
Date 12.01.20
SUPPLIES & ACCESSORIES
