Canon Support for imageRUNNER ADVANCE DX C5760 | Canon U.S.A., Inc.
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
imageRUNNER ADVANCE DX C5760i | |
MAIN UNIT | |
TYPE | ColorLaserMultifunctional |
CORE FUNCTIONS | Standard:Print,Copy,Scan,Send,Store Optional: Fax |
PROCESSOR | 1.75GHzDualCoreProcessor |
CONTROL PANEL | 10.1"TFTLCDWSVGAColorFlat-panel |
MEMORY | 4.0GBRAM |
HARD DISK DRIVE | Standard:250GB/Maximum:1TB |
PRINT RESOLUTION | 1200x1200 |
INTERFACE CONNECTION | Network: 1000Base-T/100Base-TX/10Base-T,WirelessLAN(IEEE802.11b/g/n)Others Standard:USB2.0(Host)x1,USB3.0x1(Host),USB2.0x1(Device) Optional:SerialInterface,CopyControlInterface |
PAPER CAPACITY (LETTER, 20 LB. BOND) | Standard:1,200Sheets Maximum:6,350Sheets |
PAPER SOURCES (LETTER, 20 LB. BOND) | Standard: Dual550-sheetPaperCassettes,100-sheetStackBypass Optional: Dual550-SheetPaperCassettes(CassetteFeedingUnit-AM1),2,450-SheetHighCapacityPaperCassette(HighCapacityCassetteFeedingUnit-A1),2,700-SheetPaperDeck(PaperDeckUnit-F1) |
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) | Standard:250Sheets Maximum: 3,450Sheets(withExternalFinisherandCopyTray) |
FINISHING CAPABILITIES | Standard:Collate,Group WithOptions:Collate,Group,Offset,Staple,Saddle-Stitch,HolePunch,EcoStaple,StapleOnDemand |
SUPPORTED MEDIA TYPES | Multi-PurposeTray: Thin,Plain,Recycled,Color,Heavy,Coated,Tracing,Bond,Transparency,Label,Pre-punched,Letterhead,Tab,Envelope PaperCassettes: Thin,Plain,Recycled,Color,Heavy,Bond,Transparency,Pre-punched,Letterhead,Envelope1 |
SUPPORTED MEDIA SIZES | UpperCassette: Letter,Executive,Statement-R,Envelope[No.10(COM10),DL,ISO-C5],CustomSize(3-7/8"x5-7/8"to11-3/4"x8-1/2") LowerCassette: 12"x18",11"x17",Legal,Letter,Letter-R,Executive,Statement-R,Envelope[No.10(COM10),Monarch,DL,ISO-C5],CustomSize(3-7/8"x7-1/8"to12"x18") Multi-PurposeTray: 12"x18",11"x17",Legal,Letter,Letter-R,Executive,Statement,Statement-R,Envelope[No.10(COM10),Monarch,DL,ISO-C5],EnvelopeCustomSize(3-7/8"x3-7/8"to12-5/8"x18"),CustomSize/FreeSize(3-7/8"x5-1/2"to12-5/8"x18") |
SUPPORTED MEDIA WEIGHTS | Cassettes: 14lb.Bondto140lb.Index(52to256g/m2) StackBypass:14lb.Bondto110lb.Cover(52to300g/m2) Duplexing:14lb.Bondto80lb.Cover(52to220g/m2) |
PRINT/COPY SPEED (BW AND COLOR) | Up to 60 ppm (Letter);Up to 36 ppm (Letter-R); Up to 34 ppm (Legal); Up to 32 ppm (11" x 17") |
WARM-UP TIME | FromPowerOn: Approx.10Seconds2 FromSleepMode: Approx.10Seconds3 QuickStartupMode: Approx.4Seconds4 |
DIMENSIONS (W x D x H) | 24-3/8"x28-1/2"x36-7/8"(620x722x937mm)5 |
INSTALLATION SPACE (W x D x H) | Basic:42-5/8"x45-3/4"(1,083x1,162mm)(RightCoverOpenwithMulti-purposetrayextended+CassetteDrawersOpen) FullyConfigured: 73-1/2"x45-3/4"(1,866x1,162mm)(BookletFinisher-Y1withtheextensiontrayextended+PaperDeckUnit-F1+CassetteDrawersopen) |
WEIGHT | Approx.310.9lb.(141kg)6 |
PRINT SPECIFICATIONS | |
STANDARD PAGE DESCRIPTION LANGUAGES | UFRII,PCL6,AdobePS3 |
SUPPORTED FILES | PDF,TIFF,JPEG,EPS,7XPS |
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES | ArangeofstandardandoptionalsoftwareandMEAP-basedsolutions(includingAirPrint,Mopria,Universal Print by Microsoft, CanonPRINTBusiness,anduniFLOWOnline)areavailabletoprovideprintingfrommobiledevicesorinternet-connecteddevicesandcloud-basedservicesdependingonyourrequirements.Pleasecontactyoursalesrepresentativeforfurtherinformation. |
FONTS | PCL:93Roman,10Bitmapfonts,2OCRfonts,AndaléMonoWTJ/K/S/T(Japanese,Korean,SimplifiedandTraditionalChinese),8BarcodeFonts9 PS:136Roman |
OPERATING SYSTEM 10 | UFRII/PS: Windows®7/8.1/10/Server2008/ Server2008R2/Server2012/Server2012R2/Server2016/Server2019,MacOSX(10.10orlater) PCL:Windows®7/8.1/10/Server2008/ Server2008R2/Server2012/Server2012R2/Server2016/Server2019 PPD:Windows®7/8.1/10,MacOSX(10.9orlater) |
COPY SPECIFICATIONS | |
FIRST-COPY-OUT-TIME | As fast as 2.9 seconds (BW)/ 4.5 seconds (Color) |
COPY RESOLUTION (dpi) | 600x600 |
MULTIPLE COPIES | Upto999 |
MAGNIFICATION | 25%-400%(1%Increments) |
PRESET REDUCTION / ENLARGEMENT | 25%,50%,64%,73%,78%,100%(1:1),121%,129%,200%,400% |
SCAN SPECIFICATIONS | |
TYPE | Single-PassDuplexingAutomaticDocumentFeeder |
DOCUMENT FEEDER PAPER CAPACITY | Upto200Sheets(20lb.Bond) |
DOCUMENT FEEDER SUPPORTED MEDIA SIZES | 11"x17",Legal,Letter,Letter-R,Statement,Statement-R,CustomSize:2-3/4"x5-1/2"to12"x17" |
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | Single-SidedScanning: 13.3lb.Bondto80lb.Cover(50to220gsm)(BW,CL) Double-SidedScanning: 13.3lb.Bondto80lb.Cover(50to220gsm)(BW,CL) |
PLATEN ACCEPTABLE ORIGINALS | Sheet,Book,3-DimensionalObjects |
PULL SCAN | ColorNetworkScanGear2forbothTwainandWIA SupportedOS:Windows®7/8.1/10/Server2008/Server2008R2/Server2012/Server2012R2/Server2016 |
SCAN RESOLUTION (dpi) | ScanforCopy: 600x600 ScanforSend:(Push)600x600(SMB/FTP/WebDAV/ IFAX),(Pull)600x600 ScanforFax:600x600 |
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES | Arangeofsolutionsisavailabletoprovidescanningtocompatiblemobiledevicesandcertaincloud-basedservicesdependingonyourrequirements. |
SCAN SPEED (LETTER) | Single-sidedScanning: 135/135(300dpi),80/80(600dpi), Double-sidedScanning: 270/270(300dpi),160/90(600dpi) |
SEND SPECIFICATIONS | |
DESTINATION | Standard:E-mail/InternetFAX(SMTP),SMB3.0,FTP,WebDAV,MailBox Optional: SuperG3FAX,IPFax |
ADDRESS BOOK | LDAP(2,000)/Local(1,600)/SpeedDial(200) |
SEND RESOLUTION | Push:Upto600x600 Pull:Upto600x600 |
COMMUICATION PROTOCOL | File:FTP(TCP/IP),SMB3.0(TCP/IP),WebDAV Email:SMTP,POP3 |
FILE FORMAT | Standard:TIFF,JPEG,PDF(Encrypted,Compact,Searchable,ApplyPolicy,OptimizeforWeb,UserSignature,PDFA/1-b,LimitedColor,DeviceSignature,UserSignature),XPS(Compact,Searchable,DeviceSignature,UserSignature),OfficeOpenXML(PowerPoint,Word) |
FAX SPECIFICATIONS | |
MODEM SPEED | SuperG3:33.6Kbps G3: 14.4Kbps |
COMPRESSION METHOD | MH,MR,MMR,JBIG |
RESOLUTION | 400x400,200x400,200x200,200x100 |
SENDING / RECORDING SIZE | Statement-Rto11"x17" |
FAX MEMORY | Upto30,000Pages(2,000jobs) |
SPEED DIALS | Max.200 |
GROUP DIALS / DESTINATIONS | Max.199Dials |
SEQUENTIAL BROADCAST | Max.256Addresses |
MEMORY BACKUP | Yes |
STORE SPECIFICATIONS | |
MAIL BOX SIMPLE (NUMBER SUPPORTED) | 100UserIn-boxes,1MemoryRXIn-box,50ConfidentialFaxIn-boxes,Maximum10,000Pages(2,000jobs)Stored |
ADVANCED BOX | CommunicationProtocol:SMBorWebDAV SupportedClientPC: Windows(Windows8.1/10) ConcurrentConnections(Max.) SMB: 64 WebDAV: 3 |
ADVANCED BOX AVAILABLE DISC SPACE | Approx.16GB(StandardHDD) Approx.480GB(WithOptional1TBHDD) |
SECURITY SPECIFICATIONS | |
AUTHENTICATION | Standard: UniversalLoginManager,uniFLOWOnlineExpress,11UserAuthentication,DepartmentIDAuthentication,AccessManagementSystem,DeviceandFunctionLevelLog-in Optional:uniFLOW |
DATA | Standard:TrustedPlatformModule(TPM),HardDiskPasswordLock,HardDiskDriveErase,MailBoxPasswordProtection,HardDiskDriveEncryption(FIPS140-2Validated),VerifySystematStartup,3McAfeeEmbeddedControl Optional:HardDiskDriveMirroring,IEEE2600.2CommonCriteriaCertification,DataLossPrevention(RequiresuniFLOW) |
NETWORK | Standard: EncryptedSecurePrint,IP/MacAddressFiltering,IPsec,TLSEncryptedCommunication(v1.0/1.1/1.2/1.3),SNMPV3.0,IEEE802.1X,IPv6,SMTPAuthentication,POPAuthenticationbeforeSMTP,S/MIME,SIEMIntegration |
DOCUMENT | Standard: SecureWatermark,SecurePrint,AdobeLiveCycle®RightsManagementES2.5Integration,EncryptedPDF,EncryptedSecurePrint,DigitalSignature UserSignature |
ENVIRONMENTAL SPECIFICATIONS | |
OPERATING ENVIRONMENT | Temperature: 50to86ºF Humidity:20to80%RH(RelativeHumidity) |
POWER REQUIREMENTS | 110-127V,60Hz,11.5A |
POWER CONSUMPTION | Maximum: Approx.1,800W Standby:Approx.63.1W12 SleepMode:Approx.0.8W13 TypicalElectricityConsumption(TEC)Rating14 0.84kWh |
STANDARDS | ENERGYSTAR®Certified RatedEPEAT®Gold |
CONSUMABLES | |
TONER | GPR-55 Toner15 |
TONER YIELD (ESTIMATED @ 5% COVERAGE) | Black: 69,000 Images |
FOOTNOTES | |
