Canon Support for imageRUNNER ADVANCE DX C7770i | Canon U.S.A., Inc.
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
imageRUNNER ADVANCE DX C7770i | |
MAIN UNIT | |
TYPE | Color Laser Multifunctional |
CORE FUNCTIONS | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
PROCESSOR | Canon Dual Custom Processor (Shared) |
CONTROL PANEL | Standard: 10.1" TFT LCD WSVGA Color Touch-panel Optional: 10.4" TFT LCD WSVGA Color Upright-panel |
MEMORY | 4.0 GB RAM |
HARD DISK DRIVE | Standard: 250 GB/Maximum: 1 TB |
PRINT RESOLUTION | 2400 dpi x 2400 dpi |
INTERFACE CONNECTION | Network Standard: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n) Optional: Bluetooth Low Energy Others Standard: USB 2.0 (Host) x 1,USB 3.0 (Host)x 1, USB 2.0 (Device) x 1 Optional: Copy Control Interface |
PAPER CAPACITY (LETTER, 20 LB. BOND) | Standard: 3,550 Sheets Maximum: 9,300 Sheets |
PAPER SOURCES (LETTER, 20 LB. BOND) | Standard: Two 1,100-sheet Paper Drawers, Two 550-sheet Paper Cassettes, 250-sheet Multi-purpose Tray Optional: 3,660-sheet Paper Deck (Paper Deck Unit-E1), 3,660-sheet Paper Deck (POD Deck Lite-C1), 6,000-sheet Paper Deck (MultiDrawer Paper Deck-C1) Maximum: 9,300 Sheets (With Multi-Drawer Paper Deck-C1) |
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) | 250 Sheets (with Copy Tray-R2) 4,250 Sheets (with Staple Finisher-X1 or Booklet Finisher-X1) |
FINISHING CAPABILITIES | With Finishers: Collate, Group, Offset, Staple, Saddle Stitch, Hole Punch, Eco Staple, Staple On Demand, Document Insertion, Z-fold, Half-fold, C-fold, Accordion-Z fold, Double Parallel-fold, Trimming |
SUPPORTED MEDIA TYPES | Multi-purpose tray: Thin, Plain, Recycled, Color, Heavy, Coated, Textured, Tracing, Bond, Transparency, Label, Pre-punched, Letterhead, Tab, Envelope Paper Decks: Thin, Plain, Recycled, Color, Heavy, Tracing, Bond, Transparency, Bond, Pre-punched, Letterhead Paper Cassettes: Thin, Plain, Recycled, Color, Heavy, Bond, Transparency, Pre-punched, Letterhead, Tab, Envelope1 |
SUPPORTED MEDIA SIZES | Multi-purpose Tray: Standard size: 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size/Free Size: 4" x 5-7/8" to 13" x 19-1/4", Envelope: COM10 No.10, Monarch, DL, ISO-C5, Envelope Custom Size: 3-1-/2" x 5-7/8" to 13" x 19-1/4" Paper Decks: Letter Paper Cassettes: 13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size: 5-1/2" x 7-1/8" to 13" x 19-1/4", Envelope: COM10 No.10, Monarch, DL, ISO-C5, Envelope Custom Size : 3-7/8" x 5-7/8" to 13" x 19-1/4" |
SUPPORTED MEDIA WEIGHTS | Paper Drawers: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) Paper Cassettes:14 lb. Bond to 140 lb. Index (52 to 256 g/m2) Multi-purpose Tray: 14 lb. Bond to 110 lb. Cover (52 to 300 g/m2) Duplexing: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) |
PRINT/COPY SPEED (BW AND COLOR) | Up to 70/65 ppm (Letter); Up to 52/48 ppm (Letter-R); Up to 41/38 ppm (Legal); Up to 35/32 ppm (11" x 17") |
WARM-UP TIME | From Power On: Approx. 30 Seconds2 Quick Startup Mode: Approx. 4 Seconds3 From Sleep Mode: 30 Seconds or Less4 |
DIMENSIONS (W x D x H) | 27-1/8" x 36-7/8" x 46-5/8" (689 mm x 937 mm x 1,185 mm) |
INSTALLATION SPACE (W x D x H) | Basic: 79-3/4" x 60" (2,026 mm x 1,524 mm) (with front cover open + Multi-purpose tray/upper-right cover open + Buffer Pass+ Booklet Finisher-AC1/extension tray and rotary tray extended) Fully Configured: 150-3/8" x 60" (3,818 mm x 1,524 mm) (with front door open + Multi-Drawer Paper Deck-C1 + Buffer Pass + Document Insertion Unit-N1 + Multi Function Professional Puncher-B1 + Paper Folding Unit-J1+ Booklet Finisher-X1) |
WEIGHT | Approx. 562.2 lb. (255 kg)5 |
PRINT SPECIFICATIONS | |
DATA PROCESSING RESOLUTION (dpi) | 2400 x 2400 |
STANDARD PAGE DESCRIPTION LANGUAGES | UFR II, PCL®6, Adobe® PS® 3 |
SUPPORTED FILES | PDF, TIFF, JPEG, EPS,6 XPS |
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES | A range of standard and optional software and MEAP-based solutions (including AirPrint, Mopria, Universal Print by Microsoft, Canon PRINT Business, and uniFLOW Online) are available to provide printing from mobile devices or internet-connected devices and cloud-based services depending on your requirements. Please contact your sales representative for further information. |
FONTS | PCL Fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),7 Barcode Fonts8 PS Fonts: 136 Roman |
OPERATING SYSTEM 9 | UFR II/PS: Windows® 7/8.1/10/Server2008/ Server2008 R2/Server2012/Server2012 R2/Server2016/Server2019, Mac OS X(10.10 or later) PCL: Windows 7/8.1/10/Server2008/Server2008 R2/Server2012/Server2012 R2/ Server2016/Server2019 PPD: Windows 7/8.1/10, Mac OS X(10.9 or later) |
COPY SPECIFICATIONS | |
FIRST-COPY-OUT-TIME | As fast as 4.8 seconds (BW)/ 5.9 seconds (Color) |
COPY RESOLUTION (dpi) | 600 x 600 |
MULTIPLE COPIES | Up to 9,999 |
MAGNIFICATION | 25%-400% (1% Increments) |
PRESET REDUCTION / ENLARGEMENT | 25%, 50%, 64%, 73%, 78%, 100%(1:1), 121%, 129%, 200%, 400% |
SCAN SPECIFICATIONS | |
TYPE | Single-pass Duplexing Automatic Document Feeder |
DOCUMENT FEEDER PAPER CAPACITY | 200 Sheets (20 lb. Bond) |
DOCUMENT FEEDER SUPPORTED MEDIA SIZES | 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R, Custom Size: 2-3/4" x 5-1/2" to 12"x17" |
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | Single-sided/Double-sided Scanning: 13.3 lb. Bond to 80 lb. Cover (50 to 220 gsm) |
PLATEN ACCEPTABLE ORIGINALS | Sheet, Book, 3-Dimensional Objects |
PULL SCAN | Color Network ScanGear2 for both Twain and WIA Supported OS: Windows/7/8.1/10 Server 2008/Server 2008 R2/Server 2012/ Server 2012 R2/Server 2016 |
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of solutions is available to provide scanning to mobile devices and cloud-based services depending on your requirements. |
SCAN SPEED (LETTER) | Single-sided Scanning BW/Color: 135/135 ipm (300 dpi), 80/80 ipm (600 dpi) Double-sided Scanning BW/Color: 270/270 ipm (300 dpi), 160/90 ipm (600 dpi) |
SEND SPECIFICATIONS | |
DESTINATION | Standard: E-mail/Internet FAX (SMTP), SMB v3.0, FTP, WebDAV, Mail Box Optional: Super G3 FAX, IP Fax |
ADDRESS BOOK | LDAP (2,000)/Local (1,600)/Speed dial (200) |
SEND RESOLUTION | Push: Up to 600 x 600 Pull: Up to 600 x 600 |
COMMUICATION PROTOCOL | File: FTP (TCP/IP), SMB v3.0, WebDAV Email: SMTP, POP3 |
FILE FORMAT | Standard: TIFF, JPEG, PDF (Limited Color, Compact, Searchable, Apply Policy, Optimize for Web, PDF/A-1b, Trace & Smooth, Encrypted, Device Signature, User Signature), XPS (Compact, Searchable, Device Signature, User Signature), Office Open XML (PowerPoint, Word) |
FAX SPECIFICATIONS | |
MAXIMUM NUMBER OF LINES | 4 |
MODEM SPEED | Super G3: 33.6 Kbps G3: 14.4 Kbps |
COMPRESSION METHOD | MH, MR, MMR, JBIG |
RESOLUTION | 400 x 400, 200 x 400, 200 x 200, 200 x 100 |
SENDING / RECORDING SIZE | Statement-R to 11" x 17" |
FAX MEMORY | Up to 30,000 Pages (2,000 Jobs) |
SPEED DIALS | Max. 200 |
GROUP DIALS / DESTINATIONS | Max. 199 Dials |
SEQUENTIAL BROADCAST | Max. 256 Addresses |
MEMORY BACKUP | Yes |
STORE SPECIFICATIONS | |
MAIL BOX SIMPLE (NUMBER SUPPORTED) | 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 10,000 Pages (2,000 Jobs) Stored |
ADVANCED BOX | Communication Protocol: SMB or WebDAV Supported Client PC: Windows (Windows 8.1/10) Concurrent Connections (Max.) SMB: 64 WebDAV: 3 |
ADVANCED BOX AVAILABLE DISC SPACE | Approx. 16 GB (Standard HDD)/Approx. 480 GB |
SECURITY SPECIFICATIONS | |
AUTHENTICATION | Standard: Universal Login Manager, uniFLOW Online Express,10 User Authentication, Department ID Authentication, Access Management System, Device and Function Level Log-in Optional: uniFLOW |
DATA | Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), Verify System at Startup, McAfee Embedded Control Optional: Hard Disk Drive Mirroring, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW) |
NETWORK | Standard: Encrypted Secure Print,IP/Mac Address Filtering, IPsec, TLS Encrypted Communication (v1.0/1.1/1.2/1.3), SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, S/MIME, SIEM Integration |
DOCUMENT | Standard: Secure Watermark, Secure Print, Forced Hold Printing, Adobe LiveCycle® Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device Signature, User Signature |
ENVIRONMENTAL SPECIFICATIONS | |
OPERATING ENVIRONMENT | Temperature: 50 to 86 ºF Humidity: 20 to 80% RH (Relative Humidity) |
POWER REQUIREMENTS | 110-127 V AC, 60 Hz,16 A |
POWER CONSUMPTION | Maximum: Approx. 2,000 W Standby: Approx. 119.2 W11 Sleep Mode: Approx. 0.9 W12 Typical Electricity Consumption (TEC) Rating13 1.23 kWh |
STANDARDS | ENERGY STAR® Certified Rated EPEAT® Gold |
CONSUMABLES | |
TONER | GPR-56 Toner |
TONER YIELD (ESTIMATED @ 5% COVERAGE) | Black: 82,000 Images |
FOOTNOTES | |
