Canon Support for IVY CLIQ Instant Camera Printer | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 04.15.19
File Size 925.0 KB
Canon Mini Print - iOS
The Canon Mini Print App offers access to an exclusive array of photo editing tools — helping your images come to life through custom filters, frames, text, emojis, collage prints and more.
Canon Mini Print - Android
Printer
Printing Method ZINK&trade; - "Zero Ink"
Print Speed (up to) 50 Seconds or less2
Print Resolution (Up to) 314 x 500 dpi
Paper Compatibility ZINK&trade; Photo Paper
Maximum Paper Size 2.0" x 3.0"
Printer Features Borderless Printing
Paper Handling Capacity: Up to 10 Sheets of ZINK&trade; Photo Paper & 1 SMART SHEET&trade;
General
Operating Temperature: 59 - 90&deg;F (15 - 32&deg;C)
Operating Humidity: Up to 40-50% Relative Humidity
Warranty 1-Year Limited Warranty4
Camera
Camera Resolution 5MP
Photo Format JPEG
Video Capable No
Camera Aspect/Print Size 2" x 3", 2" x 2"
Flash Yes
Ring Light No
Focus Auto
Zoom Fixed
ISO Auto (Range: 100 - 1600)
White Balance Auto
Exposure Adjustment Auto
Self Timer No
Viewfinder Yes
Remote Shutter No
Selfie Mirror Yes - Small Selfie Mirror
Tripod Mount No
Reprint Button Yes
Connectivity
Bluetooth No
Wi-Fi&reg;/ Wireless Capable No
Storage & Memory
Built-in Storage Memory None
Memory Card Compatible Yes, MicroSD Memory Card (Up to 256 GB)3
Mass Storage Mode Yes, via included Micro USB 2.0 Cable3
ZINK&trade; Photo Paper Information
Photo Paper Information 2" x 3" Photo Paper Size, Sticker Back, Smudge-Free, Water & Tear Resistant
Photo Paper Storage Environment Temperature: 34 - 77&deg;F (1 - 25&deg;C)
Humidity: 40 - 55% Relative Humidity
Battery & Power Information
Battery Type Built-in Rechargeable Lithium-Polymer (700 mAh)
Battery Life Approx. 25 Photos
Battery Charge Time Full Charge in Approx. 90 Minutes (Measured at 5V/1A Charging Speed)
USB Port Micro USB for Charging & Data
Auto Power Off Yes (5 Min)
General Information
Control Panel Power Button, Shutter Button, Reprint Button, Aspect Ratio Button (2x3 / 2x2)
Display Type LED Light System
Bottom LED (Charging):
Red: Charging, Green: Charging Complete
Top Power LED (Status):
Color Flashing Loop: Printing Photo, White:
Power On/Standby, White Flashing: Processing SMARTSHEET&trade;, Preparing to Print, White - White Flashing: Device is Booting, Red: Device too high of temperature, Red Flashing: Cover Opened/Printing Error/No Paper/ Paper Jam, Red - White Flashing: Low Battery, Blue Flashing: SMARTSHEETTM Error, Cyan: Device too low of temperature, Cyan Flashing: Printer Head Cooling, Magenta: Mass Storage Mode, Magenta Flashing: MicroSD Error, Green Flashing: Firmware Updating
Aspect Ratio LED Yes
Speaker Status Power On/Off, Camera Shutter, Camera Error, Reprint Failed, Insert/Eject SD Card,SD Card Error
Customize Speaker Status No
Certification Battery Charging (BC) Systems - California Energy Commission (CEC) Compliant
RMN for Compliance PP2001
Reset Button Yes
IVY Mini Photo Printer, IVY 2 Mini Photo Printer, IVY CLIQ Instant Camera Printer, IVY CLIQ+ Instant Camera Printer + App, IVY CLIQ+2 Instant Camera Printer + App and IVY CLIQ2 Instant Camera Printer Limited Warranty
The limited warranty set forth below is given by Canon U.S.A., Inc. (“Canon USA”) in the United States with respect to the Canon-brand IVY Mini Photo Printer, IVY 2 Mini Photo Printer, IVY CLIQ Instant Camera Printer, IVY CLIQ+ Instant Camera Printer + App, IVY CLIQ+2 Instant Camera Printer + App and IVY CLIQ2 Instant Camera Printer (the “Product”) packaged with this limited warranty, when purchased and used in the United States.
When delivered to you in new condition in its original container, the Product is warranted against defects in materials and workmanship under normal use and service for a period of one (1) year from the date of original purchase. Product returned to a Canon USA repair facility and proven to be defective upon inspection will, in Canon's sole discretion and at no charge, be (a) repaired utilizing new, remanufactured, repaired and/or recycled parts; (b) exchanged for a new Product or; (c) exchanged for a refurbished Product, as determined by the Canon USA repair facility. Warranty replacement or exchange does not extend the original warranty period for the Product. A dated proof of purchase is required at the time of warranty service. A copy of your dated bill of sale will satisfy this requirement. This warranty does not cover any accessories for the Product, or any consumables used with the Product (e.g., paper), as to which there shall be no warranty or replacement.
This limited warranty shall only apply if the Product is used in conjunction with compatible devices, peripheral equipment and software, as to which items Canon USA shall have no responsibility. Non-Canon brand equipment and software that may be distributed with the Product, or with which the Product may be integrated, are sold “as is” and without warranty of any kind by Canon USA, including any implied warranty or condition regarding merchantability or fitness for a particular purpose, and all such warranties and conditions are disclaimed. The sole warranty, if any, with respect to such non-Canon brand items is given by the manufacturer or producer thereof.
  1. Loss of or damage to the Product due to abuse, neglect, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, improper use, failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's user's manual or other documentation, or services performed by someone other than a Canon USA repair facility. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, and abrasions will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts, supplies or consumables (other than those sold by Canon USA) that cause damage to the Product or cause abnormally frequent service calls or service problems.
  3. If the Product has had its serial number or dating defaced, altered or removed.
  4. If the Product is used for commercial or industrial use.
THIS LIMITED WARRANTY IS IN LIEU OF ALL OTHER WARRANTIES, REPRESENTATIONS AND CONDITIONS, EXPRESS OR IMPLIED. NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OR CONDITION OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCTS AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE, AND NO OTHER EXPRESS WARRANTY, GUARANTY OR CONDITION, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON OR ENTITY WITH RESPECT TO THE PRODUCT SHALL BIND CANON. (SOME STATES AND PROVINCES DO NOT ALLOW LIMITATION ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU.) CANON SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, INCONVENIENCE, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE, OR INABILITY TO USE THE PRODUCT REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.NOR SHALL RECOVERY OF ANY KIND AGAINST CANON BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT SOLD BY CANON USA NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON. (SOME STATES AND PROVINCES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE EXCLUSION OR LIMITATION MAY NOT APPLY TO YOU.) THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT, AND STATES YOUR EXCLUSIVE REMEDY.
You may obtain technical support for your Product as follows:
Support chat via our Web Site at www.usa.canon.com/support
Toll-free live technical support Monday—Friday (excluding holidays) at 1-800-OK-CANON (1-800-652-2666)
Telephone Device for the Deaf (TDD-1-866-251-3752)
When you contact Canon USA support, please have your Product serial number and your date of purchase available to expedite service.
MAIL-IN SERVICE
 is a program under which your Product is repaired by a Canon U.S.A. authorized service center for the Product. Authorized service center information can be obtained by visiting www.usa.canon.com/support or by contacting the Canon U.S.A., Customer Care Center at 1-800-OK-CANON (1-800-652-2666). You will be given the name, address and phone number of an authorized service center.
It is your responsibility to properly package and send the defective Product, together with a copy of your dated proof of purchase, a complete explanation of the problem and a return address to the authorized service center at your expense. Do not include any other items with the defective Product. The Product covered by this limited warranty and proven to be defective upon inspection will be repaired or replaced and returned to you without charge by the authorized service center. Any Product received by the authorized service center that is not covered by the limited warranty will be returned unrepaired, or at the discretion of the authorized service center, you may receive a written estimate of repair at such cost as the service center may establish from time to time.
*Support program specifics are subject to change without notice.
Canon U.S.A., Inc.
One Canon Park
Melville, NY 11747
USA
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
