Canon Support for LE-5W BK | Canon U.S.A., Inc.
LE-5W BK
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
Projector Specifications
| Imaging Device | 0.45" DLP Panel |
| Aspect Ratio | 16:10 |
| Native Resolution | WXGA equivalent |
| Brightness | 500 Lumens |
| Contrast Ratio | 3000:1 |
| Digital Keystone (Vertical) | ±40 degrees (Auto/Manual) |
Optics
| Throw Ratio | 1.2:1 |
Image Adjustments
| Mounting | Ceiling / Rear-Ceiling |
| Tilt Angle | 0 to 6 degrees |
Input Signals
| Scanning Frequency | H-Sync: 31-102MHz, V-Sync: 23-120MHz |
| Analog PC Input | WSXGA+ / SXGA+ / WXGA+ / WXGA / SXGA / XGA / SVGA / VGA |
| Digital PC Input | WSXGA+ / SXGA+ / WXGA+ / WXGA / SXGA / XGA / SVGA / VGA |
| Video/S-Video Input | NTSC / NTSC4.43 / PAL / SECAM / PAL-M / PAL-N / PAL-60 |
| Component Input | 1080p / 1080i / 720p / 576p / 576i / 480p / 480i |
| Digital Video Input | 1080p / 1080i / 720p / 576p / 576i / 480p / 480i |
Terminals
| (Input) RCA x1 | Composite Video Input |
| (Input) Stereo Mini Jack | Stereo Input x1 |
| (Output) Stereo Mini Jack | Stereo Output x1 |
| Built-in Speaker | 2.5W x2 (Stereo) |
Lamp
| Lamp Type | LED x3(RGB) |
| Lamp Life | 20,000 Hours |
Remote Control
| Sensor | Wireless Infrared |
Ratings
| Fan Noise (Quiet/Normal) | 38dB (Normal) / 31dB (Power Saver) |
| Power Consumption (Normal/Quiet/Stand-By) | 130W (Normal) / 90W (Power Saver) / 0.5W (Standby) |
| Power Voltage | AC 100 , 240V, 50/60Hz |
| Temperature Operating | 32° to 104° F (0° to 40° C) |
| Dimension (WxHxD) | 9.8 x 2.2 x 7.6 in.(248 x 54.9 x 193mm)*including protrusion 9.8 x 1.9 x 7.6 in.(248 x 49.4 x 193mm)*not including protrusion |
| Weight | 3.5 lbs. / 1.6 kg. |
| Warranty | 3 years limited parts and labor |
CANON PROJECTOR LIMITED WARRANTY
The limited warranty set forth below is given by Canon U.S.A., Inc. (Canon USA) in the United States, or Canon Canada Inc. (Canon Canada) in Canada, with respect to the Canon-brand Projector, including its internal light source (collectively, the 'Projector') accompanying this limited warranty in the Projector's original container, when purchased and used in the United States or Canada, as applicable. This limited warranty is only effective upon presentation of your Bill of Sale or other proof of purchase.
Canon U.S.A., Inc. and Canon Canada Inc. (collectively, 'Canon') warrant to the original end-user purchaser, when delivered in new condition in its original container, that the Projector will be free from defects in materials and workmanship under normal use and service for a period of THREE YEARS from the date of original purchase. When returning a Projector under this warranty, you must pre-pay the shipping charges, and you must enclose a copy of the Bill of Sale or other proof of purchase with a complete explanation of the problem. Projectors returned to a Canon repair facility, and proven to be defective upon inspection, will be, without charge:
a. repaired utilizing new or comparable refurbished parts, or
b. exchanged for a refurbished or new Projector
as determined in the Canon repair facility's sole discretion. The repaired or exchanged Projector will be shipped back to you free of charge. Warranty exchange or replacement does not extend the original warranty period of the Projector. For repairs after the warranty period has expired, an estimate will be provided of the cost of repair and an opportunity to approve or reject the repair expense before it is incurred. If you approve, repairs will be made and the Projector will be returned at your risk and expense. If you reject, the Projector will be returned to you at no charge to an address within the United States or Canada
This limited warranty only applies if the Projector is used in conjunction with compatible computer equipment and compatible software, as to which items Canon will have no responsibility. Canon shall have no responsibility under this limited warranty for use of the Projector in conjunction with incompatible peripheral equipment and/or incompatible software. Non-Canon brand peripheral equipment and software which may be distributed with, or factory loaded on, the Projector, are sold 'AS IS' without warranty or condition of any kind by Canon USA or Canon Canada, including any implied warranty or condition regarding merchantability or fitness for a particular purpose. The sole warranty with respect to such non-Canon brand items is given by the manufacturer or producer thereof. If the Projector contains a hard disk drive, Canon recommends that data stored on that drive be duplicated or backed up to prevent its loss in the event of failure or other malfunction of such drive
In order to obtain warranty service:
Canon U.S.A.
You may obtain technical support* for your Projector as follows:
E-mail support via our Web site at www.usa.canon.com/support, or
Canon Canada
* Technical support program specifics subject to change without notice.
This Limited Warranty covers all defects encountered in normal use of the Projector and does not apply in the following cases:
A. Loss or damage to the Projector due to abuse, neglect, mishandling, electric current fluctuation, accident, improper maintenance, use of non-Canon accessories or failure to follow operating, maintenance or environmental instructions prescribed in Canon USA's or Canon Canada's user's manual;
B. If defects or damages are caused by the use of parts or supplies (other than those sold by Canon USA or Canon Canada) that cause damage to the Projector or that cause abnormally frequent service calls or service problems;
C. If defects or damages are caused by service other than Canon's factory service centers or authorized service facilities;
D. Any internal modification to product hardware or firmware;
E. Any maintenance of the Projector, including any fees for such maintenance; or
F. If the Projector has had its serial number or dating altered or removed.
This Limited Warranty does not apply to Projectors purchased outside the United States or Canada. This Limited Warranty does not apply to accessories or consumables for the Projector, which are sold 'AS IS', without warranty or condition of any kind by Canon USA or Canon Canada. Please retain this warranty card and your Bill of Sale as a permanent record of your purchase. This card ensures that you are contacted promptly should there be a safety inspection, modification or product recall under applicable laws or regulations.
NO IMPLIED WARRANTY OR CONDITION, INCLUDING IMPLIED WARRANTIES OR CONDITIONS OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THIS PROJECTOR AFTER THE APPLICABLE PERIOD OF EXPRESS WARRANTY OR GUARANTY UNDER THIS LIMITED WARRANTY (EXCEPT AS MENTIONED ABOVE). SOME STATES AND PROVINCES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY OR CONDITION LASTS, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU. CANON USA AND CANON CANADA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, EXPENSE FOR SUBSTITUTE PROJECTORS OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, INCLUDING WITHOUT LIMITATION, LOSS OR CORRUPTION OF DATA STORED ON THE EQUIPMENT'S HARD DRIVE, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PROJECTOR, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA OR CANON CANADA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR CANON CANADA BE GREATER THAN THE PURCHASE PRICE OF THE PROJECTOR SOLD BY CANON USA OR CANON CANADA AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE, MISUSE OR INABILITY TO USE THE PROJECTOR NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON USA OR CANON CANADA (SOME STATES AND PROVINCES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU).THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS PROJECTOR OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
This warranty gives you specific legal rights, and you may also have other rights which vary from state to state (or province to province in Canada).
next to your download
