Canon Support for LG-P800 | Canon U.S.A., Inc.
LG-P800
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
| Type | Inkjet Label Printer |
| Print Method | Pigment-based Inkjet |
| Ink Cartridges | 4 (1 x Black, 1 x Cyan, 1 x Magenta, 1 x Yellow) |
| Print Resolution | 1200 x 1200 dpi |
| Number of Nozzles | Magenta/Black/Yellow/Cyan: 2,560 |
| First Print Out Time | 13.6 sec or lessFootnote1 |
| Default Print Speed | Matte Coated: Standard 14.0 mm/sec, Fine 7.3 mm/sec, Fast 26.1 mm/secFootnote1 |
| Print Speed Range | 7.3 - 47.0 mm/sFootnote1 |
| Supported Media Types | Label Roll Media (with Roll Holder), Fanfold Media (IJ Coated: Matte or Glossy) |
| Supported Media Format | Label Roll Media (with Roll Holder), Fanfold Media |
| Roll Media Capacity | Outer Diameter: Up to 6.0 inch (152.4mm), Core/Inner Diameter: 3.0 inch ± 0.04inch (76.2±1.0mm) |
| Fanfold Media Capacity | Media Height: Up to 11.8 inch (300mm) |
| Media Size - Width | 2.0 - 8.5 inch (50.9 - 216.0 mm) Including Liner |
| Media Size - Length | 1.5 - 53.0 inch (38.1 - 1,346.20 mm) |
| Media Thickness | 5.0mil-8.5mil(0.1-0.2mm) |
| Max. Printable Area Width | Up to 8.61 inch (215.9mm) |
| Max. Printable Area Length | Up to 53.62 inch (1343.2mm) |
| Min. Margin Top/Bottom | 118.1mil (0.12 inch) (3.0 mm) |
| Min. Margin Left/Right | 59.1mil (0.06 inch) (1.5 mm) |
| Product Life | 2.3 Million Sheets or 5 Years |
| Ink Cartridge Fill Volume | Black / Cyan / Magenta / Yellow: 10.1oz (300 ml) |
| Maintenance Cartridge Info & Fill Volume | WT-X801 Maintenance Cartridge : 12.2oz (360 ml), Approx. 49,000 Sheets |
| Control Panel | 4.3-inch LCD touch panel |
| Connectivity / Interface | USB2.0 Hi-speed, 1000BASE-T/100BASE-TX/10BASE-T |
| Supported OS | Windows 11, Windows Server 2016,2019,2022,2025 StandardFootnote2 |
| Operating Environment Temperature | Operating temperature range: 41°95°F (5°35°C); Guaranteed print qualty is ensured between 59°- 86F(15°-30) |
| Operating Environment Humidity | 10 - 90% RH (Non-Condensing) Guaranteed print qualty is ensured between 10-80%RH |
| Chemical Safety | TSCA, OSHA HCS |
| Power Consumption | 53W (operating), 1.9W (sleep mode), 0.1W(OFF) |
| Electrical | AC 100-240V, 50/60Hz |
| Max. Operating Noise | 55dB or lessFootnote3 |
| Standby Noise | 35dB or lessFootnote3 |
| Warranty | 1 Year Warranty including PrintheadFootnote4 |
| Dimensions | 22.5(W) x 29.4(D) x 17.2(H) (572mm(W) x 746mm(D) x 436mm(H)) |
| Weight | 79.4 lbs. (36kg) |
The limited warranty set forth below is given by Canon U.S.A., Inc. and Canon Canada, Inc. (collectively, "Canon") with respect to the Canon LG-P800 Inkjet Label Printer packaged with this limited warranty and Canon branded accessories and options designed for use with the Canon LG-P800 Inkjet Label Printer (the "Product"). Canon warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of one (1) year after delivery to the original purchaser (“Purchaser”) by Canon or its authorized dealer.* During the relevant warranty period, Canon shall, in its sole discretion and without charge, repair or replace any defective part with a new or comparable rebuilt part or replace the Product with a new or rebuilt Product. Warranty replacement shall not extend the warranty period of the defective Product. This warranty shall not extend to the Canon Printhead for the Product, for which a separate warranty is given. Nor shall this warranty cover other consumable parts or consumables, such as paper and ink cartridges, as to which there shall be no warranty or replacement.
Your local Service Provider; or call
| If purchased and used in the United States: | If purchased and used in Canada: |
You must cooperate with Canon in remotely diagnosing the Products malfunction. Canon may attempt to correct the malfunction remotely, with your assistance. If Canon cannot fix your Product’s malfunction through remote diagnostics, Canon shall schedule an on-site service call by an independent authorized Canon Service Provider (the "Service Provider") or Canon will send you a replacement part for any defective user replaceable item. You will be charged at the then-current service call rates of Canon or the Service Provider if the defects in the Product are not covered by this limited warranty, or if the applicable warranty period for the Product has expired or warranty coverage has not been sufficiently established by appropriate documentation.
This warranty shall only apply if this Product is used in conjunction with compatible computers, peripheral equipment and software, as to which items Canon shall have no responsibility. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
THIS WARRANTY IS IN LIEU OF ALL OTHER WARRANTIES OR CONDITIONS, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTY OR CONDITION OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, RELATING TO THE USE OR PERFORMANCE OF THE PRODUCT. NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS EXPRESSLY MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
THIS WARRANTY SHALL BE VOID AND OF NO FORCE AND EFFECT IF THE PRODUCT IS DAMAGED AS A RESULT OF (A) ABUSE, NEGLECT, MISHANDLING, ALTERATION, ELECTRIC CURRENT FLUCTUATION OR ACCIDENT, (B) IMPROPER USE, INCLUDING FAILURE TO FOLLOW OPERATING OR MAINTENANCE INSTRUCTIONS IN, OR ENVIRONMENTAL CONDITIONS PRESCRIBED IN, CANON’S USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT, (C) REPAIR BY OTHER THAN SERVICE REPRESENTATIVES QUALIFIED BY CANON WHO ARE ACTING IN ACCORDANCE WITH CANON’S SERVICE BULLETINS (D) USE OF SUPPLIES OR PARTS (OTHER THAN THOSE DISTRIBUTED BY CANON) INCLUDING NON-CANON INK CARTRIDGES OR REFILLED INK CARTRIDGES, WHICH DAMAGE THE PRODUCT OR CAUSE ABNORMALLY FREQUENT SERVICE CALLS OR SERVICE PROBLEMS OR (E) USE OF THE PRODUCT WITH NON-COMPATIBLE COMPUTERS, PERIPHERAL EQUIPMENT OR SOFTWARE, INCLUDING THE USE OF THE PRODUCT IN ANY SYSTEM CONFIGURATION NOT RECOMMENDED IN ANY USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT. NOR DOES THIS WARRANTY EXTEND TO ANY PRODUCT ON WHICH THE ORIGINAL IDENTIFICATION MARKS OR SERIAL NUMBERS HAVE BEEN DEFACED, REMOVED, OR ALTERED.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE DISKETTES OR CD-ROM'S ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD “AS IS” AND WITHOUT WARRANTY BY CANON. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
CONDITIONS OF WARRANTY
THIS WARRANTY APPLIES TO PRODUCTS SOLD AND USED IN THE U.S.A. AND CANADA ONLY.
next to your download
