Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 05.13.26
File Size 1.29 MB
Date 05.13.26
File Size 822.21 KB
Date 07.23.26
File Size 10.65 MB
Date 10.02.26
File Size 11.22 MB
Date 10.15.26
File Size 1.35 MB
Type Inkjet Label Printer
Print Method Dye-based Inkjet
Ink Cartridges 4 (1 x Black, 1 x Cyan, 1 x Magenta, 1 x Yellow)
Print Resolution 1200 x 1200 dpi
Number of Nozzles 5184 dots
Supported Media Types Label Roll Media (with Roll Holder) & Label Fanfold Media (IJ Coated: Matte or Glossy)
Media Size Width: 14.7 mm to 115.0 mm (0.58 to 4.53 including liner)
Length: 6.0 mm to 1346.2 mm (0.24 t0 53.0)
Media Thickness 0.145 - 0.254 mm
Ink Cartridge Fill Volume Black / Cyan / Magenta / Yellow: 240ml
Maintenance Cartridge WT-X404 Maintenance Cartridge
Control Panel 4.3-inch full color touch LCD
Connectivity / Interface USB2.0 Hi-speed, USB2.0 typeB, 1000BASE-T/100BASE-TX/10BASE-T, RS-232C and External I/O (For External Devices)
Supported OS Windows 11, Windows Server 2016, 2019, 2022, 2025Footnote5
Operating Environment Temperature 41° - 95°F (5° - 35°C)
Operating Environment Humidity 10 - 90% RH (Non-Condensing)
Chemical Safety TSCA, OSHA HCS
Power Consumption Approx. 230W (max. with RFID unit), approx. 87W (operating, average), approx. 24W (standby, average), approx. 5W (sleep mode, average), 0.3W or less (power off, average)
Electrical AC 100-240V, 50/60Hz
Max. Operating Noise 55dB or lessFootnote6
Standby Noise 35dB or lessFootnote6
Warranty 1 Year Warranty including printheadFootnote3
Dimensions 15.2(W) x 22.2(D) x 16.9(H) (386mm(W) x 565mm(D) x 430mm(H))
Weight 48.9lbs. (22.2kg) excluding printhead and ink tanks
CANON LX INKJET LABEL PRINTER LIMITED WARRANTY
The limited warranty set forth below is given by Canon U.S.A., Inc. and Canon Canada, Inc. (collectively, "Canon") with respect to the Canon LX-D400/LX-D5500/LX-P5510/LX-P1300/LX-D1300 Inkjet Label Printer (collectively, the "Product") packaged with this limited warranty and Canon branded accessories and options designed for use with the Product. Canon warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of one (1) year after delivery to the original purchaser (“Purchaser”) by Canon or its authorized dealer. During the relevant warranty period, Canon shall, in its sole discretion and without charge, repair or replace any defective part with a new or comparable rebuilt part or replace the Product with a new or rebuilt Product. Warranty replacement shall not extend the warranty period of the defective Product. This warranty does not cover consumable parts or consumables, such as paper and ink cartridges, as to which there shall be no warranty or replacement.
For remote diagnostic assistance for operation and support of the Product, call:
If purchased and used in the United States:
• Your local Service Provider; or
• 1-855-852-2666 Monday through Friday during regular business hours, excluding holidays
If purchased and used in Canada:
You must cooperate with Canon in remotely diagnosing the Product’s malfunction. Canon may attempt to correct the malfunction remotely, with your assistance. If Canon cannot fix your Product’s malfunction through remote diagnostics, Canon shall schedule an on-site service call by an independent authorized Canon Service Provider (the "Service Provider") or Canon will send you a replacement part for any defective user replaceable item. You will be charged at the then-current service call rates of Canon or the Service Provider if the defects in the Product are not covered by this limited warranty, or if the applicable warranty period for the Product has expired or warranty coverage has not been sufficiently established by appropriate documentation.
This warranty shall only apply if this Product is used in conjunction with compatible computers, peripheral equipment and software, as to which items Canon shall have no responsibility. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
THIS WARRANTY IS IN LIEU OF ALL OTHER WARRANTIES, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, RELATING TO THE USE OR PERFORMANCE OF THE PRODUCT. NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT. THIS WARRANTY SHALL BE VOID AND OF NO FORCE AND EFFECT IF THE PRODUCT IS DAMAGED AS A RESULT OF (A) ABUSE, NEGLECT, MISHANDLING, ALTERATION, ELECTRIC CURRENT FLUCTUATION OR ACCIDENT, (B) IMPROPER USE, INCLUDING FAILURE TO FOLLOW OPERATING OR MAINTENANCE INSTRUCTIONS IN, OR ENVIRONMENTAL CONDITIONS PRESCRIBED IN, CANON’S USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT, (C) REPAIR BY OTHER THAN SERVICE REPRESENTATIVES QUALIFIED BY CANON WHO ARE ACTING IN ACCORDANCE WITH CANON’S SERVICE BULLETINS (D) USE OF SUPPLIES OR PARTS (OTHER THAN THOSE DISTRIBUTED BY CANON), INCLUDING NON-CANON INK CARTRIDGES OR REFILLED INK CARTRIDGES, WHICH DAMAGE THE PRODUCT OR CAUSE ABNORMALLY FREQUENT SERVICE CALLS OR SERVICE PROBLEMS OR (E) USE OF THE PRODUCT WITH NON-COMPATIBLE COMPUTERS, PERIPHERAL EQUIPMENT OR SOFTWARE, INCLUDING THE USE OF THE PRODUCT IN ANY SYSTEM CONFIGURATION NOT RECOMMENDED IN ANY USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT. NOR DOES THIS WARRANTY EXTEND TO ANY PRODUCT ON WHICH THE ORIGINAL IDENTIFICATION MARKS OR SERIAL NUMBERS HAVE BEEN DEFACED, REMOVED, OR ALTERED.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON, OR IN, THE SOFTWARE MEDIA ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD “AS IS” AND WITHOUT WARRANTY BY CANON. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
CONDITIONS OF WARRANTY
THIS WARRANTY APPLIES TO PRODUCTS SOLD AND USED IN THE U.S.A. AND CANADA ONLY.
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
