Canon Support for MAXIFY MB2720 | Canon U.S.A., Inc.
MAXIFY MB2720
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 08.29.24
File Size 770.22 KB
Date 08.29.24
File Size 760.69 KB
Date 08.29.24
File Size 771.01 KB
Date 06.01.16
File Size 5.34 MB
Date 08.29.24
File Size 781.78 KB
Date 07.01.24
File Size 1.15 MB
Date 06.01.16
File Size 5.34 MB
Date 09.02.16
File Size 14.84 MB
Date 09.02.16
File Size 15.09 MB
Date 09.02.16
File Size 18.40 MB
Date 01.27.17
File Size 75.59 KB
Date 01.27.17
File Size 89.11 KB
Date 05.26.25
File Size 5.20 MB
Date 06.01.16
File Size 4.92 MB
Date 06.01.16
File Size 15.02 MB
Date 09.02.16
File Size 18.07 MB
Date 08.29.24
File Size 6.13 MB
Date 07.01.24
File Size 1.15 MB
Date 06.01.16
File Size 4.92 MB
Date 06.01.16
File Size 15.02 MB
Date 08.29.24
File Size 6.10 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Print and scan wirelessly from any Wi-Fi® enabled computer from your local network connection. Wireless printing requires a working network with wireless 802.11b/g/n capability. You will need a Wi-Fi enabled Computer, a wireless router and a wireless printer. All three devices must be connected to the same wireless network connection. Click on the specific topic below to get detail information.
Initial Setup
Need additional information or assistance
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
MAXIFY MB2720
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15
MAXIFY MB2720
Products ChromeOS
MAXIFY MB2720
Printer
Print Speed (up to) Black:FPOT (Black): 6 Seconds - ESAT (Black): 24.0 ipm1
Color:FPOT (Color): 7 Seconds - ESAT (Color): 15.5 ipm1
Number of Nozzles Pigment Black: 1,280 / Color: 3,072 / Total: 4,352
Print Resolution (Up to) Up to 600 x 1200 dpi8
Ink Compatibility PGI-1200 Black - 12.4 ml (Std) / 34.7 ml (XL)
PGI-1200 Cyan - 4.5 ml (Std) / 12.0 ml (XL)
PGI-1200 Magenta - 4.5 ml (Std) / 12.0 ml (XL)
PGI-1200 Yellow - 4.5 ml (Std) / 12.0 ml (XL)
Up to 1,200 Black & White / 900 Color Pages when using XL ink tanks.
Paper Sizes 4" x 6", 5" x 7", 8" x 10", Letter, Legal, U.S. #10 Envelopes
Paper Compatibility Plain: Plain Paper, High Resolution Paper
Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy
Semi-Gloss: Photo Paper Plus Semi-Gloss, Photo Paper Pro Luster
Matte: Matte Photo Paper
Other: Business Card, Label Paper, U.S.#10 Envelopes
Recycled paper and Chlorine-free paper can be used.
Printer Features AirPrint5, Mopria® Print Service7, Auto 2-Sided Printing, Advanced Auto Sheet Feeder, Canon PRINT app4, Document Printing, Microsoft Mobile Print, Quick Toolbox, Wireless Printing3
Output Tray Capacity Upper Cassette: 250 Sheets Plain Paper (Letter or Legal) or 20 Sheets Photo Paper 4" x 6"
Lower Cassette: 250 Sheets Plain Paper (Letter or Legal)
Noise Level (Approx.) Approx. 56.0 dB(A)16
Copier
Copy Speed (up to) FCOT (Color): Approx. 12 Seconds1
Reduction / Enlargement 25% - 400%
Copy Features 2-on-1 Copy, 4-on-1 Copy, ID Card Copy, AE (Auto Exposure / Intensity) Copy, Collated Copy (ADF only), Fit-to-Page, Frame Erase Copy (Flatbed), Preset Copy Ratios, Preview, Standard Copy, 2-Sided Copy, Zoom
Scanner
Scanning Element Contact Image Sensor (CIS)
Max. Resolutions Optical:ADF & Flatbed: 1200 x 1200 dpi (Optical)11
Interpolated:19,200 x 19,200 dpi (Interpolated)11
Scanner Features Push Scan, Scan to Memory (USB Flash Memory), Network Scan, Scan to Cloud, Scan to Email, Scan to Network Folder
Color Depth 48-bit internal/24-bit external
Max. Document Size Flatbed: 8.5" x 11" (Letter); ADF - 50 Sheet Capacity
ADF: 8.5" x 14" (Legal); ADF - 10 Sheet Capacity
Fax
Modem Speed 33.6 Kbps (Super G3 Color FAX)12
Transmission Speed (approx.) Black: Approx. 3 sec. per page13
Color: Approx. 1 min. per page13
Memory Capacity Approx. 250 Pages14
Speed Dialing 100 Locations
Fax Features Answering Machine Connectivity, Caller Rejection, Check RX Fax Info., Dial Search, Double-Sided Printing (Fax Images), FAX to Network Folder, Extra Fine Mode, Fax Reception Reject, Fax Number Re-Entry, F/T Changing (Manual), Memory Transmission, Redial, Remote Reception
General
Other Features Custom Profiles, Folder Setting Utility, Highlighter and Smudge Resistant Ink, Access Point Mode, High Page Yield, Job Reservation, Low Cost Per Page Printing, Quick First Print1, MAXIFY Cloud Link15, Quiet Mode, Standard MIB Support, SNMP Support, Records of Use, Job Reservation, Remote UI, Setting Restrictions, Up to 20,000 pages Duty Cycle2, Auto Power On, Schedule On/Off
OS Compatibility Computer Operating Systems:
Windows:17,18 Windows® 10, Windows 8, Windows 8.1, Windows 7, Windows 7 SP1, Windows Vista® SP1, Vista SP2, Windows Server® 2012, 2012 R218, Windows Server®2008, 2008 R218
Mac:19 Mac OS® X v10.8.5 - 10.11
Mobile Operating Systems:20
iOS®, Android, Windows RT21 and Windows 10 Mobile
Standard Interface Wireless LAN (IEEE 802.11b/g/n)2
Ethernet
USB Flash Memory
Hi-Speed USB
Software Included WINDOWS17,18/MAC19
MAXIFY MB2720 Printer Driver
Master Setup
PosterArtist Lite22 (Windows Only)
Scan Utility
My Printer (Windows Only)
Network Tool
Speed Dial Utility
Power Consumption (approx.) 27.0W Copying (0.9W Standby)
Dimension (W x D x H) 18.1" (W) x 18.3" (D) x 12.6" (H)
Weight 26.5 lbs.
Warranty 1-Year limited warranty with InstantExchange Program.23
Recommended Monthly Print Volume 250 - 1,250 Pages per Month - Ideal for 1-4 users
Limited Warranty & InstantExchange Program Details
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon USA") with respect to the new or refurbished Canon-brand product ("Product") packaged with this limited warranty, when purchased and used in the United States only.
The Product is warranted against defects in materials and workmanship under normal use and service (a) for a period of one (1) year from the date of original purchase when delivered to you in new condition in its original container or (b) for (1) year from the date of original purchase for refurbished Products. Product returned to a Canon USA repair facility or a Canon USA Authorized Service Facility ("ASF"), and proven to be defective upon inspection will be (a) repaired utilizing new, remanufactured, repaired and/or recycled parts (b) exchanged for new or; (c) exchanged for a refurbished Product, as determined by the Canon USA repair facility or the ASF. Warranty repair or replacement shall not extend the original warranty period of the Product. A dated proof of purchase is required at the time of warranty service. A copy of your dated bill of sale will satisfy this requirement. This warranty does not cover any accessories, or any consumables, such as paper or ink cartridges, as to which there shall be no warranty or replacement.
This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty ("Separate Warranty"). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. Non-Canon brand equipment and software that may be distributed with the Product are sold "as is" and without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose, and all such warranties are disclaimed. The sole warranty, if any, with respect to such non-Canon brand items is given by the manufacturer or producer thereof.
  1. Loss of or damage to the Product due to abuse, neglect, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, improper use, failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's user's manual or other documentation, or services performed by someone other than a Canon USA repair facility or ASF. Without limiting the foregoing, dropping the Product, scratches, and abrasions will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the user's manual or other documentation for the Product.
  2. Use of parts, media, software or supplies (other than those sold by Canon USA), including non-Canon ink cartridges or refilled ink cartridges, that cause damage to the Product or cause abnormally frequent service calls or service problems.
  3. If the Product has had its serial number or dating defaced, altered or removed.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE DISKETTES OR CD-ROMS ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
Canon USA offers a full range of customer technical support* options:
    Interactive troubleshooting, e-mail technical support, the latest driver downloads and answers to frequently asked questions (www.canontechsupport.com)
    Toll-free live technical support within the limited warranty
    Monday - Friday 8:00 a.m. - 10:00 p.m. ET(excluding holidays)
    Saturday 10:00 a.m. - 7:00 p.m. EST
    at 1-844-4-MAXIFY (1-844-462-9439)
    Telephone Device for the Deaf (TDD-1-855-270-3277)
    Repair or Exchange Service Options: In the event service is required for the Product during the limited warranty period, Canon USA offers two hardware support options:
Canon USA's Carry-In/Mail-In Service provides repair or exchange, at Canon USA's option, through Canon USA's Authorized Service Facility (ASF) network. The name and telephone number of the ASF(s) near you may be obtained from Canon USA's Web site at www.canontechsupport.com or by calling the Canon USA Customer Care Center at 1-800-828-4040, or any time while speaking to a technical support person. A Product covered by this limited warranty will be repaired or exchanged, as determined by Canon USA, and returned without charge by the ASF.
InstantExchange Service **
The Canon USA repair facility will ship out the replacement Product prepaid by Canon USA. After receipt of the replacement Product (with instructions and a prepaid waybill), follow the enclosed instructions on how to ship your product to the Canon USA repair facility. Your Product must be returned in the shipping carton in which the replacement Product was packed and include the reference number, A COPY OF YOUR DATED PROOF OF PURCHASE (BILL OF SALE), and a complete explanation of the problem. DO NOT INCLUDE ANY OTHER ITEMS WITH THE YOUR PRODUCT IN THE RETURN SHIPPING CARTON, AND BE SURE TO RETAIN YOUR PRINTHEAD, INK CARTRIDGE(S) AND TANK(S).
InstantExchange Service exchanges your Product with a replacement Product, which will normally be shipped the same day if your request for this service is by 3 p.m. E.T. Monday through Friday, except holidays. Canon USA does not guarantee same day shipment in the event of the occurrence of factors beyond its reasonable control. The replacement Product you receive may be a refurbished or reconditioned unit and will be covered for the balance of the period remaining on your original limited warranty. NOTE THAT BY USING THIS SERVICE YOU WILL KEEP THE REPLACEMENT PRODUCT THAT IS SENT TO YOU. CANON USA WILL RETAIN THE PRODUCT THAT YOU ORIGINALLY PURCHASED, WHICH SHALL BECOME THE PROPERTY OF CANON USA. InstantExchange warranty program service is available only during the express limited-warranty period for your Product and only in the continental United States, Alaska and Hawaii during such period.
InstantExchange warranty service is subject to the availability of refurbished or new replacement units.
Canon U.S.A., Inc.
One Canon Park
Melville, NY 11747
USA
Title Canon Support | Canon print services provided on the IFTTT platform will discontinued
Advisory Type
Date 07.14.20
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
