Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 01.17.23
File Size 675.73 KB
Date 01.18.18
File Size 2.00 MB
Date 07.21.19
File Size 619.55 KB
Date 08.03.25
File Size 423.73 KB
Date 08.07.19
File Size 2.01 MB
Date 07.21.19
File Size 1003.95 KB
Date 07.21.19
File Size 545.19 KB
Date 07.21.19
File Size 4.96 MB
Date 07.21.19
File Size 335.88 KB
Camera Connect
Camera Connect
image.canon
image.canon
Sensor 35mm Full Frame CMOS
Total Pixels Approx. 2.59M (2160 x 1200)
Effective Pixels Approx. 2.26M (2000 x 1128)
Resolution 1920 x 1080, 1280 x 720
Pixel Size 19um x 19um
Min. Sub. Illum. 0.0005 lux or less (at 75dB, F1.2, 29.97P, 50IRE)
Color Filter Array RGB Primary Color Filter Bayer Array
Canon EF Lenses Select EF, EF-S and Cinema (EF-mount) Lenses
GEN LOCK N/A
Microphone 3.5mm stereo mini jack (plug-in power mic supported)
Remote Control Remote A: 2.5mm stereo mini jack RS-232 (Canon OK Protocol)
Ethernet (Canon Webview Protocol)
External Device I/O Terminal Block Input x 1, Output x 1, RS-422/RS-485 x 1 (Pass-through only)
3G/HD-SDI Terminal 1 (On screen display optional)
- 3G-SDI: SMPTE 424, SMPTE 425, SMPTE ST 299-2
- HD-SDI: SMPTE 292, SMPTE ST 299-1
- Resolution: 1080P/1080i/720P
Frame Rates
- 1920 x 1080: 59.94P/59.94i/50P/50i/29.97P/25P/23.98P
- 1280 x 720: 59.94P/50P/29.97P/25P/23.98P
HDMI Terminal 1 (On screen display optional)
Resolution: 1080P/1080i/720P/576P*/480P*
Frame Rates
1920 x 1080: 59.94P/59.94i/50P/50i/29.97P/25P/23.98P, 1280 x 720: 59.94P/50P
* 480P/576P video signal is output only when a monitor that supports only 480P/576P is connected to the camera.
Ethernet LAN x 1 (RJ45, 100Base-TX (auto/full duplex/half-duplex))
MJPEG, MPEG4-AVC/H.264 Streaming Camera Controls over IP
Resolution: 1920 x 1080
Frame Rates: MJPEG: 0.1 - 30fps
H.264: 1/2/3/5/6/10/15/30
Target bit rate: Selection range 64-16384 kbps
Protocols: IPv4, IPv6, TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF Profile S/G, WV-HTTP (Canon proprietary)
Auto Exposure (AE) Iris, Gain, Shutter and ND filter operating together, AE shift/AE response selectable, AGC limit can be set from 36dB to 75dB (3dB intervals)
Manual Iris: Iris: 1/2 stops or 1/3 stops (push auto iris can be set to an assign button), Gain: 0dB to 75dB @3dB intervals (approx. ISO 4,560,000 equivalent at 75dB)
Shutter: 1/3 to 1/2000 (selections depend on system frequency and frame rate)
Focus Control Manual focus, One-shot AF (can be set to assign button)
White Balance AWB (2,000K-15,000K), Daylight, Tungsten, Custom Set A, Custom Set B, Color Temperature
Optical Filters ND filters: 1/8 & 1/64 Built-in (auto or manual activation)
IR cut filter: On/Off (manual activation)
Digital Teleconverter 2x, 3x, 4x
Custom Picture Setting EOS Standard, Wide DR, Canon Log, Custom 1-6
Other Functions Auto black balance, color bar, test tone (interlocking with color bar), assign buttons, peripheral illumination correction, focus limit, crop for EF-S lens, scan reverse, flicker reduction, noise reduction, time display, hour meter
Terminals Terminal block 2-pin jack and Ethernet port (PoE+)
Input Terminal block 2-pin jack: DC +11V , +17V
Ethernet: PoE IEEE802.3at Type 2 compliant (PoE+)
Consumption Power consumption approx. PoE+ 18W, DC 16W
Operating Temperature Approx. 0 - 40 °C (32-104 °F)
Dimensions 4.0 x 4.6 x 4.4 in. (102 x 116 x 113mm)
Weight Approx. 2.4 lbs. (1,100g)
Included in the Box ME20F-SHN, 2-pin DC Power Contact, Body Cap
Related Accessories Canon RC-V100 Remote Controller, Canon EF Lenses
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
