Canon Support for Mk1500 Cable & Wire Marker Printer | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
| Printing Method | Thermal Transfer Method |
| Resolution | 300 dpi |
| Printing Speed | Tube: High speed mode: 25 mm/sec Standard speed mode: 18.5 mm/sec Low speed mode: 12.5 mm/sec Label: High speed mode: 25 mm/sec Standard/Low speed mode: 12.5 mm/sec |
| Processing Speed | High speed mode: about 35 pieces/min Standard speed mode: about 30 pieces/min Low speed mode: about 21 pieces/min Conditions for printing and cutting - tube cut length: 20 mm, number of characters: 5 (two-byte characters of 3 mm wide), half cutting: on, cut strength: standard |
| Ink Ribbon | Ribbon IC cassette (black, white) Length - black: 100 m, white: 85 m |
| Size of Characters | 2 mm (Kanji characters not supported for this size), 3 mm, 6 mm (both one-byte and two-byte characters supported) |
| Types of Characters | JIS First-Level Kanji, JIS Second-Level Kanji, symbols |
| Data Entering | Rubber keyboard, alphanumeric input, area code input, symbol input |
| Vocabulary of Dictionary | About 5,000 words |
| Display | LCD graphic display (160 x 64 dots) |
| Number of Characters Displayed | Input data: 10 characters × 2 lines (two-byte characters), or 20 characters x 2 lines (one-byte characters) |
| Memory Capacity | Storage for character data: about 2,500 characters*2 Storage for files: about 7,500 characters*2 Folder hierarchy: none |
| Cutting Method | Automatic half cut, automatic full cut |
| Power | AC adapter (100 VAC - 240 VAC, 50/60 Hz) |
| Interface | - |
| Operating Environment | Temperature: 15°C to 32.5°C, Humidity: 10% to 85% |
| Maximum Power Consumption | 12.5 W |
| Storage Environment | Temperature: 5°C to 35°C, Humidity: 10% to 90% |
| Main Body Dimensions | Width: 250 mm x Depth: 300 mm x Height: 85 mm |
| Main Body Weight | 2 kg |
| Media Types | Tube: Commercially available PVC round tube*3 (Inner diameter: 2.5 mm to 5.2 mm, thickness: 0.5 mm) Label Tape Cassette (white, yellow, silver) - width: 6 mm, 9 mm, 12 mm, length: 30 m (27 m for silver)*4 Adjustable range of cut length: 8 mm to 150 mm*4 Wrap Around Tape: Cassette (white in the areas to be printed, transparent in other areas) Winding length: 8 m, length: 33 mm, width: 8 mm to 150 mm (adjustable by the cut length setting) |
Canon U.S.A., Inc. LIMITED WARRANTY – (USA Only)
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon USA") with respect to the new or refurbished Canon-brand Cable ID-Series printer product (“Product”) packaged with this limited warranty, when purchased and used in the United States only. This limited warranty will apply to a warranty repaired or replacement Product only as set forth below.
The Product is warranted against defects in materials and workmanship under normal use and service for a period of two (2) years from the date of original purchase.
Product returned to a Canon USA repair facility, and proven to be defective upon inspection, in Canon USA’s sole discretion and at no charge, will be (a) repaired utilizing new, remanufactured, repaired and/ or recycled parts (b) exchanged for new Product or; (c) exchanged for a refurbished Product, as determined by Canon USA. This limited warranty applies to a warranty repaired or replacement Product only as follows: a warranty repaired or replacement Product will be warranted under this limited warranty only until the end of the warranty period of the original Product purchased. A dated proof of purchase is required at the time of warranty service. A copy of your dated bill of sale will satisfy this requirement. This warranty does not cover any accessories, or any consumables, such as paper or ink ribbon, as to which there shall be no warranty or replacement. This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty (“Separate Warranty”). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. Non-Canon brand equipment and software that may be distributed with the Product are sold “as is” and without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose, and all such warranties are disclaimed. The sole warranty, if any, with respect to such non-Canon brand items is given by the manufacturer or producer thereof.
a) Loss of or damage to the Product due to abuse, neglect, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, improper use, failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA’s user’s manual or other documentation, or services performed by someone other than a Canon USA repair facility. Without limiting the foregoing, dropping the Product, scratches, and abrasions will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the user’s manual or other documentation for the Product.
b) Use of parts, media, software or supplies (other than those sold by Canon USA), including non-Canon ink ribbon, that cause damage to the Product or cause abnormally frequent service calls or service problems.
c) If the Product has had its serial number or dating defaced, altered or removed.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON, OR IN, THE SOFTWARE MEDIA ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD “AS IS” AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER’S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER’S LICENSE AGREEMENT.
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILTY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE, AND NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON OR ENTITY WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA,. (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU.) CANON USA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, INCONVENIENCE, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE, OR INABILITY TO USE THE PRODUCT REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT SOLD BY CANON USA NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA. (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE EXCLUSION OR LIMITATION MAY NOT APPLY TO YOU.) THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT, AND STATES YOUR EXCLUSIVE REMEDY.
A range of Canon USA customer technical support* options are available:- Interactive troubleshooting, the latest driver downloads, hours of operation, and answers to frequently asked questions (www.usa.canon.com/support)
- Toll-free live technical support Monday–Friday from 8 a.m. to 8 p.m. ET (excluding Canon-observed holidays) at 1-855-852-2666
- Telephone Device for the Deaf (TDD-1-855-270-3277)
- Warranty Service:
In the event service is required for the Product during the limited warranty period, a Canon USA Customer Care Center representative will attempt to diagnose the nature of the problem and, if possible, correct it over the telephone. If the problem cannot be corrected over the telephone, you will be provided instructions for Canon USA’s then current warranty service procedures. You may be asked for the Product serial number and/or other information pertaining to your Product. This limited warranty give you specific legal rights, and you may also have other rights, which vary from state to state.
next to your download
