Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Image Sensor -1" SPAD Sensor (effective pixels: approx. 2,100,000, total pixels: approx. 3,200,000)
Minimum Subject Illumination 0.001 lux (Color (Night Mode), no light accumulation, f/1.4 equivalent, shutter speed 1/30, 50IRE, maximum gain)
Lens Mount Bayonet lens mount based on BTA S-1005B standards
Video Output Format [Frame rate 59.94P] 1920 x 1080: 59.94P*, 59.94i (4:2:2 10 bit) 1280 x 720: 59.94P (4:2:2 10 bit) * 3G-SDI mapping Level A/B supported [Frame rate 29.97P] 1920 x 1080: 29.97P, 29.97PsF (4:2:2 10 bit) [Frame rate 50.00P] 1920 x 1080: 50.00P*, 50.00i (4:2:2 10 bit) 1280 x 720: 50.00P (4:2:2 10 bit) * 3G-SDI mapping Level A/B supported [Frame rate 25.00P] 1920 x 1080: 25.00P, 25.00PsF (4:2:2 10 bit)
Exposure Auto, Tv, Av, AGC, Manual AE Shift
Metering Mode Standard, Spotlight, Backlight, AF frame metering
White Balance Manual (MWB), AWB, White Balance Set A (WB-A), White Balance Set B (WB-B), Daylight (Dylt), Tungsten (Tung), Color Temperature (Kelv) Preset setting/color temperature setting: available
Auto Black Balance Available
Iris Manual (control range varies depending on the lens)
Gain 0.0 72.0 dB
Custom Picture CrispImg2 (preset)
Shutter Speed Frame rate 59.94P
1/4, 1/8, 1/15, 1/30, 1/60, 1/75, 1/90, 1/100, 1/120, 1/150, 1/180, 1/210, 1/250, 1/300, 1/360, 1/420, 1/500, 1/600, 1/720, 1/840, 1/1000, 1/1200, 1/1400, 1/1700, 1/2000
Frame rate 29.97P
1/4, 1/8, 1/15, 1/30, 1/34, 1/40, 1/48, 1/50, 1/60, 1/75, 1/90, 1/100, 1/120, 1/150, 1/180, 1/210, 1/250, 1/300, 1/360, 1/420, 1/500, 1/600, 1/720, 1/840, 1/1000, 1/1200, 1/1400, 1/1700, 1/2000
Frame rate 50.00P
1/3, 1/6, 1/12, 1/25, 1/50, 1/60, 1/75, 1/90, 1/100, 1/120, 1/150, 1/180, 1/210, 1/250, 1/300, 1/360, 1/420, 1/500, 1/600, 1/720, 1/840, 1/1000, 1/1200, 1/1400, 1/1700, 1/2000
Frame rate 25.00P
1/3, 1/6, 1/12, 1/25, 1/30, 1/33, 1/40, 1/50, 1/601/75, 1/90, 1/100, 1/120, 1/150, 1/180, 1/210, 1/250, 1/300, 1/360, 1/420, 1/500, 1/600, 1/720, 1/840, 1/1000, 1/1200, 1/1400, 1/1700, 1/2000 Only when the Extended Shutter Speed is set to [Enable], 1/600 1/2000 options can be selected.
Shutter Speed Limit (Lower) [Frame rate 59.94P] 1/4, 1/8, 1/15, 1/30 [Frame rate 29.97P] 1/4, 1/8, 1/15 [Frame rate 50.00P] 1/3, 1/6, 1/12, 1/25 [Frame rate 25.00P] 1/3, 1/6, 1/12
Flicker Reduction Available
Optical Filters ND filter: motor operated insertion-extraction (manual/automatic), 1 density level (approx. 1/64) IR cut filter: motor operated insertion-extraction (manual/automatic)
Focus Manual, One-shot AF
AF frame: Large, small
AF frame position: Center, specified area
AGC Limit Off/72.0 48.0 dB
Day/Night Switch Auto/Day Mode/Night Mode
Color Bars SMPTE, ARIB, EBU
Smart Shade Control (SSC) Available
Haze Compensation Available
Diffraction Correction Available (excluding certain non-supported lenses)
Chromatic Aberration Correction Available (excluding certain non-supported lenses)
Digital Zoom Available, 10x (Max.)
On-Screen Display Available, English/Japanese
Custom Picture CrispImg2, BT.709 Standard, Canon 709
Video Compression Method JPEG, MPEG-4 AVC/H.264, H.265/HEVC
Video Size 1920 x 1080, 1280 x 720, 640 x 360, 320 x 180
Video Quality 10 levels
Video Output Frame Rate (Output from Network Terminal JPEG: 0.1 15 fps
Frame Frequency 59.94P/29.97P: 0.99/4.99/9.99/14.98/29.97/59.94 fps
Frame Frequency 50.00P/25.00P: 1/5/12.5/25/50 fps
I-Frame Interval 0.5/1/1.5/2/3/4 sec.
Simultaneous Client Access Max. 15 Clients
Bit Rate Control Control Method: MBR, CBR
Control: 128/256/384/512/768/1024/1536/2048/3072/4096/6144/8192/10240/12288/14336/16384/24576/32768 kbps
Protocol Network Protocol: IPv4, IPv6, TCP/IP, UDP, HTTP, SNMPv1/v2c/v3 (MIB2), RTP/RTCP, RTSP, DHCP, AutoIP, DNS, mDNS, ARP, ICMP, NTP, SSL/TLS
Control Protocol: NU (Canon proprietary, Serial), Pelco-D (Serial), ONVIF, WV-HTTP (Canon proprietary), WVCOM (Canon proprietary)
Security Video Distribution: Enable/disable settings for each user level (Authorized user, Guest user)
Access Control: User Restrictions (User name and Password), Host Access Restrictions (IPv4, IPv6)
Encrypted Communications: SSL/TLS
Preset Number of registers: Max. 20 positions
3G/HD-SDI Terminal BNC jack (output only) x 1, 0.8 Vp-p/75 , unbalanced 3G-SDI: SMPTE 424, SMPTE 425, SMPTE ST 299-2 HD-SDI: SMPTE 292, SMPTE ST 299-1 Time code (VITC/LTC)
GENLOCK Terminal BNC jack (input only) x 1, 1.0 Vp-p/75
REMOTE Terminal Circular 8-pin jack x 1 (RS-232C/RS-422/RS-485) Serial communication method can be switched by DIP switch
LENS Terminal Circular 12-pin jack x 1
External Device I/O Terminal Input x 2, output x 2 (for future extensionn)
Memory Card microSD card slot x 1 (for future extension, not recordable)
Power Supply External power source: 12 30 V DC (connector included)
Power Consumption DC input: Max. 23.7 W (camera body only)
Operating Temperature Temperature Operating temperature range DC: -20°C +45°C (-4°F +113°F)
Start-up temperature range DC: -10°C +45°C (-14°F +113°F)
Storage Environment Temperature -30°C +60°C (-22°F +140°F)
Humidity 5% 90% (without condensation)
Dimensions (W x H x D) Approx. 128 x 128 x 184 mm (5.04 x 5.04 x 7.24 in.) (excluding protrusions)
Weight Approx. 2.2 kg (4.86 lb.) (camera body only)
Title Firmware Notice: MS-500: Firmware Version 2.0.0
Advisory Type Firmware Notice
Date 08.08.24
SUPPLIES & ACCESSORIES
