Canon Support for MS-500 | Canon U.S.A., Inc.
MS-500
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Image Sensor | -1" SPAD Sensor (effective pixels: approx. 2,100,000, total pixels: approx. 3,200,000) |
Minimum Subject Illumination | 0.001 lux (Color (Night Mode), no light accumulation, f/1.4 equivalent, shutter speed 1/30, 50IRE, maximum gain) |
Lens Mount | Bayonet lens mount based on BTA S-1005B standards |
Video Output Format | [Frame rate 59.94P] 1920 x 1080: 59.94P*, 59.94i (4:2:2 10 bit) 1280 x 720: 59.94P (4:2:2 10 bit) * 3G-SDI mapping Level A/B supported [Frame rate 29.97P] 1920 x 1080: 29.97P, 29.97PsF (4:2:2 10 bit) [Frame rate 50.00P] 1920 x 1080: 50.00P*, 50.00i (4:2:2 10 bit) 1280 x 720: 50.00P (4:2:2 10 bit) * 3G-SDI mapping Level A/B supported [Frame rate 25.00P] 1920 x 1080: 25.00P, 25.00PsF (4:2:2 10 bit) |
Exposure | Auto, Tv, Av, AGC, Manual AE Shift |
Metering Mode | Standard, Spotlight, Backlight, AF frame metering |
White Balance | Manual (MWB), AWB, White Balance Set A (WB-A), White Balance Set B (WB-B), Daylight (Dylt), Tungsten (Tung), Color Temperature (Kelv) Preset setting/color temperature setting: available |
Auto Black Balance | Available |
Iris | Manual (control range varies depending on the lens) |
Gain | 0.0 72.0 dB |
Custom Picture | CrispImg2 (preset) |
Shutter Speed | Frame rate 59.94P 1/4, 1/8, 1/15, 1/30, 1/60, 1/75, 1/90, 1/100, 1/120, 1/150, 1/180, 1/210, 1/250, 1/300, 1/360, 1/420, 1/500, 1/600, 1/720, 1/840, 1/1000, 1/1200, 1/1400, 1/1700, 1/2000 Frame rate 29.97P 1/4, 1/8, 1/15, 1/30, 1/34, 1/40, 1/48, 1/50, 1/60, 1/75, 1/90, 1/100, 1/120, 1/150, 1/180, 1/210, 1/250, 1/300, 1/360, 1/420, 1/500, 1/600, 1/720, 1/840, 1/1000, 1/1200, 1/1400, 1/1700, 1/2000 Frame rate 50.00P 1/3, 1/6, 1/12, 1/25, 1/50, 1/60, 1/75, 1/90, 1/100, 1/120, 1/150, 1/180, 1/210, 1/250, 1/300, 1/360, 1/420, 1/500, 1/600, 1/720, 1/840, 1/1000, 1/1200, 1/1400, 1/1700, 1/2000 Frame rate 25.00P 1/3, 1/6, 1/12, 1/25, 1/30, 1/33, 1/40, 1/50, 1/601/75, 1/90, 1/100, 1/120, 1/150, 1/180, 1/210, 1/250, 1/300, 1/360, 1/420, 1/500, 1/600, 1/720, 1/840, 1/1000, 1/1200, 1/1400, 1/1700, 1/2000 Only when the Extended Shutter Speed is set to [Enable], 1/600 1/2000 options can be selected. |
Shutter Speed Limit (Lower) | [Frame rate 59.94P] 1/4, 1/8, 1/15, 1/30 [Frame rate 29.97P] 1/4, 1/8, 1/15 [Frame rate 50.00P] 1/3, 1/6, 1/12, 1/25 [Frame rate 25.00P] 1/3, 1/6, 1/12 |
Flicker Reduction | Available |
Optical Filters | ND filter: motor operated insertion-extraction (manual/automatic), 1 density level (approx. 1/64) IR cut filter: motor operated insertion-extraction (manual/automatic) |
Focus | Manual, One-shot AF AF frame: Large, small AF frame position: Center, specified area |
AGC Limit | Off/72.0 48.0 dB |
Day/Night Switch | Auto/Day Mode/Night Mode |
Color Bars | SMPTE, ARIB, EBU |
Smart Shade Control (SSC) | Available |
Haze Compensation | Available |
Diffraction Correction | Available (excluding certain non-supported lenses) |
Chromatic Aberration Correction | Available (excluding certain non-supported lenses) |
Digital Zoom | Available, 10x (Max.) |
On-Screen Display | Available, English/Japanese |
Custom Picture | CrispImg2, BT.709 Standard, Canon 709 |
Video Compression Method | JPEG, MPEG-4 AVC/H.264, H.265/HEVC |
Video Size | 1920 x 1080, 1280 x 720, 640 x 360, 320 x 180 |
Video Quality | 10 levels |
Video Output Frame Rate (Output from Network Terminal | JPEG: 0.1 15 fps MPEG-4 AVC/H.264, H.265/HEVC Frame Frequency 59.94P/29.97P: 0.99/4.99/9.99/14.98/29.97/59.94 fps Frame Frequency 50.00P/25.00P: 1/5/12.5/25/50 fps |
I-Frame Interval | 0.5/1/1.5/2/3/4 sec. |
Simultaneous Client Access | Max. 15 Clients |
Bit Rate Control | Control Method: MBR, CBR Control: 128/256/384/512/768/1024/1536/2048/3072/4096/6144/8192/10240/12288/14336/16384/24576/32768 kbps |
Protocol | Network Protocol: IPv4, IPv6, TCP/IP, UDP, HTTP, SNMPv1/v2c/v3 (MIB2), RTP/RTCP, RTSP, DHCP, AutoIP, DNS, mDNS, ARP, ICMP, NTP, SSL/TLS Control Protocol: NU (Canon proprietary, Serial), Pelco-D (Serial), ONVIF, WV-HTTP (Canon proprietary), WVCOM (Canon proprietary) |
Security | Video Distribution: Enable/disable settings for each user level (Authorized user, Guest user) Access Control: User Restrictions (User name and Password), Host Access Restrictions (IPv4, IPv6) Encrypted Communications: SSL/TLS |
Preset | Number of registers: Max. 20 positions |
3G/HD-SDI Terminal | BNC jack (output only) x 1, 0.8 Vp-p/75 , unbalanced 3G-SDI: SMPTE 424, SMPTE 425, SMPTE ST 299-2 HD-SDI: SMPTE 292, SMPTE ST 299-1 Time code (VITC/LTC) |
GENLOCK Terminal | BNC jack (input only) x 1, 1.0 Vp-p/75 |
REMOTE Terminal | Circular 8-pin jack x 1 (RS-232C/RS-422/RS-485) Serial communication method can be switched by DIP switch |
LENS Terminal | Circular 12-pin jack x 1 |
External Device I/O Terminal | Input x 2, output x 2 (for future extensionn) |
Memory Card | microSD card slot x 1 (for future extension, not recordable) |
Power Supply | External power source: 12 30 V DC (connector included) |
Power Consumption | DC input: Max. 23.7 W (camera body only) |
Operating Temperature | Temperature
Operating temperature range
DC: -20°C +45°C (-4°F +113°F) Start-up temperature range DC: -10°C +45°C (-14°F +113°F) |
Storage Environment | Temperature
-30°C +60°C (-22°F +140°F) Humidity 5% 90% (without condensation) |
Dimensions (W x H x D) | Approx. 128 x 128 x 184 mm (5.04 x 5.04 x 7.24 in.) (excluding protrusions) |
Weight | Approx. 2.2 kg (4.86 lb.) (camera body only) |
