Canon Support for MS-510 | Canon U.S.A., Inc.
MS-510
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
| Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
| Sensor | -1" SPAD Sensor |
| Total Pixels | 3.2M |
| Effective Pixels | 2.1M |
| Maximum Resolution | 1920x1080 |
| Minimum Subject Illumination | 0.0006 lux (Color (Night Mode), no light accumulation, f/1.4 equivalent, shutter speed 1/30, 50IRE, maximum gain 84 dB, Custom Picture [CrispImg2]) |
| Lens Mount | Bayonet lens mount based on BTA S-1005B standards |
| SDI Terminal | 3G/HD-SDI (4:2:2 10-bit) BNC jack (output only) x 1, 0.8 Vp-p/75 , unbalanced 3G-SDI: SMPTE 424, SMPTE 425, SMPTE ST 299-2 HD-SDI: SMPTE 292, SMPTE ST 299-1 Time code (VITC/LTC) |
| LAN Terminal | RJ-45 for IP Video Streaming and Control |
| Remote Terminal | RS-232C/RS-422/RS-485 NU Protocol (Canon proprietary, Serial), Pelco-D |
| GenLock Terminal | BNC jack (input only) x 1, 1.0 Vp-p/75 |
| Lens Terminal | Circular 12-pin Jack x1 |
| Ext. Device I/O Terminal | Input x2, Output x2 (for future expansion) |
| Memory Card | microSD card slot x1 (not recordable, for future expansion) |
| Focus Control | Manual, One-shot AF AF frame: Large, Small AF frame position: Center, Specified area |
| Resolution/Frame Rate | Frame Frequency 59.94P: 1920 x 1080: 59.94P*, 59.94i (4:2:2 10 bit) 1280 x 720: 59.94P (4:2:2 10 bit) * 3G-SDI mapping Level A/B supported Frame Frequency 29.97P: 1920 x 1080: 29.97P, 29.97PsF (4:2:2 10-bit) Frame Frequency 50.00P: 1920 x 1080: 50.00P*, 50.00i (4:2:2 10-bit) 1280 x 720: 50.00P (4:2:2 10 bit) *3G-SDI mapping Level A/B supported Frame Frequency 25.00P: 1920 x 1080: 25.00P, 25.00PsF (4:2:2 10-bit) |
| Shutter Speed | 1/4000s to 1/4s [59.94P], 1/4000s to 1/4s [29.97P], 1/4000s to 1/3s [50.00P], 1/4000s to 1/3s [25.00P] |
| Optical Filters | ND filter: motor operated insertion-extraction (manual/automatic), 1 density level (approx. 1/64) IR cut filter: motor operated insertion-extraction (manual/automatic) |
| Exposure | Auto, Tv, Av, AGC, Manual AE Shift |
| Metering Mode | Standard, Spotlight, Backlight, AF Frame Metering |
| White Balance | Manual (MWB), AWB, White Balance Set A (WB-A), White Balance Set B (WB-B), Daylight (Dylt), Tungsten (Tung), Color Temperature (Kelv) Preset setting/color temperature setting: available |
| Auto Black Balance | Available |
| Iris | Manual |
| Gain | 0.0-84.0 dB (3.0 84.0 dB if gamma is BT.709 Standard, 12.0 84.0 dB if Canon 709) |
| AGC Upper/Lower Limit | Available |
| Custom Picture | CrispImg2, BT.709 Standard, Canon 709 |
| Day/Night Switch | Auto/Day Mode/Night Mode |
| Color Bars | SMPTE, ARIB, EBU |
| Smart Shade Control (SSC) | Available |
| Haze Compensation | Available |
| Diffraction Correction | Available (excluding certain non-supported lenses) |
| Chromatic Aberration Correction | Available (excluding certain non-supported lenses) |
| Digital Zoom | Available 10x (Max.) |
| On-Screen Display | Available (English/Japanese) |
| Video Compression | JPEG, MPEG-4 AVC/H.264, H.265/HEVC |
| Video Size | 1920 x 1080, 1280 x 720, 640 x 360, 320 x 180 |
| Video Output Frame Rate | JPEG: 0.1 15 fps MPEG-4 AVC/H.264, H.265/HEVC Frame Frequency 59.94P/29.97P: 0.99/4.99/9.99/14.98/29.97/59.94 fps Frame Frequency 50.00P/25.00P: 1/5/12.5/25/50 fps |
| Network Protocol | IPv4, IPv6, TCP/IP, UDP, HTTP, SNMPv1/v2c/v3 (MIB2), RTP/RTCP, RTSP, DHCP, AutoIP, DNS, mDNS, ARP, ICMP, NTP, SSL/TLS |
| Control Protocol | ONVIF (Profile S), WV-HTTP (Canon proprietary), WVCOM (Canon proprietary) |
| External Power | External power source: 12 30 V DC (connector included) |
| Power Consumption | DC input: Max. 23.7 W (camera body only) |
| Temperature | Operating temperature range: -20°C +45°C (-4°F +113°F) Start-up temperature range: -10°C +45°C (-14°F +113°F) Storage temperature range: -30°C +60°C (-22°F +140°F), 5%-90% Humidity without condensation |
| Dimensions | Approx. 128 x 128 x 184 mm (5.04 x 5.04 x 7.24 in.) (excluding protrusions) |
| Weight | Approx. 2.2 kg (4.86 lb.) (camera body only) |
next to your download
