Canon Support for MultiPASS F50 | Canon U.S.A., Inc.
MultiPASS F50
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Golden Gate v27
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
MFP F50 Setup
File Name
User manual for the MultiPASS F50
File Name
MFP F50 FAX Guide
File Name
F30 F50 Reference Guide
SELECT ERROR CODE
Printer
| Printing Method | Bubble Jet ink-on-demand |
| Print Speed (up to) | Black:17 ppm Color:12 ppm |
| Print Resolution (Up to) | Black:600 x 600 dpi Color:2400 x 1200 dpi |
| Ink Compatibility | BCI-3Bk Black Ink Tank, BCI-3C Cyan Ink Tank, BCI-3M Magenta Ink Tank, BCI-3Y Yellow ink Tank |
| Paper Sizes | Letter, legal, A4, banner paper, U.S. #10 envelopes |
| Paper Compatibility | Plain Paper, Envelopes, Canon Specialty Papers - Banner Paper, Glossy Photo Cards, Glossy Photo Paper, High Gloss Photo Film, High Resolution Paper, Photo Paper Pro, Transparencies |
| Paper Handling | Plain Paper - 100 sheets Envelopes - 10 Transparencies - 30 sheets |
| Paper Weights | 17 lb. - 28 lb. |
Copier
| Copy Resolution (up to) | 600 x 600 dpi |
| Copy Speed (up to) | 17 cpm |
| No. of Copies | Max. 99 copies |
| Reduction / Enlargement | 25% - 400% |
Scanner
| Max. Resolutions | Optical:600 x 1200 dpi Interpolated:9600 x 9600 dpi |
| Color Depth | Color - 36-bit internal, Grayscale - 12-bit internal |
| Interface | TWAIN |
Fax
| Applicable Line | Public Switched Telephone Network |
| Compatibility | G3 |
| Data Compression System | MH, MR, MMR, JBIG, JPEG |
| Transmission Speed (approx.) | Black & White Approx. 3 seconds/page* at 33.6 Kbps, ECM-MMR, transmitting from memory; Color: Approx. 1 minute/page** at 33.6 Kbps, ECM-JPEG, transmitting from memory |
| Memory Capacity | Memory Size Approx. 270 pages* transmitting from memory |
| Fax Scanning Speeds (up to) | Approx. 5 seconds/page* |
| Fax Resolution | B&W Standard: 203 x98 dpi; B&W Fine: 203 x 196 dpi; ; Color Standard: 200 x 200 dpi |
| Document Feeder | 30 pages (at 20 lb. paper) |
| Speed Dialing | Automatic dialing (One-touch speed dialing - 12 destinations; Coded Speed Dialing - 100 locations; Group Dialing - Max. 111 destinations). Regular Dialing: Automatic Redialing: Manual Redialing (with Redial/Pause button) |
| Receive Mode | Fax only mode; Fax/Tel mode; Manual mode; Answering machine mode; DRPD (Distinctive Ring Pattern Detection) |
| Other Features | Sequential Broadcast (Max. 113 destinations); Automatic Reception; Automatic Fax/Tel Switchover; Remote Reception by Telephone; Non-ring reception; ECM Deactivation; DRPD (Distinctive Ring Pattern); Activity Report (after every 20 transactions); Non-delivery report; TTI (Transit Terminal Identification) |
General
| OS Compatibility | Windows® 95/98/2000/Me/XP, Windows NT® 4.0 (Sp 4.0 or later) |
| System Requirements | Common:CD-ROM drive, 256-color SVGA monitor or greater, Bi-directional IEEE 1284 compatible parallel or USB cable (Windows 98/2000/Me/XP only) Windows:Windows 95/98 and Windows NT 4.0 (SP 4.0 or later) - 90MHz Pentium® processor, 32 MB (64 MB) RAM; Windows Me - 150 MHz Pentium processor, 32 MB (64 MB) RAM; Windows 2000 - 133 MHz Pentium processor, 64 MB (128 MB) RAM; Windows XP - 233 MHz (300 MHz) Pentium processor, 64 MB (128 MB) RAM, 60 MB free hard disk space (150 MB recommended) |
| Standard Interface | IEEE 1284 parallel, USB (Windows 98/2000/Me/XP only) |
| Software Included | Setup Software/User Guide CD-ROM including: MultiPASS Suite 4.0; ScanSoft® OmniPage® Pro OCR Software |
| Dimension (W x D x H) | 17.3"W x 23"D x 12.8"H (with attachments) |
| Weight | 27.3 lbs. (with attachments) |
| Warranty | 1-year limited warranty (conditions and restrictions apply, see warranty materials for details) |
| † Prices and specifications subject to change without notice. Actual prices are determined by individual dealers and may vary. * Based on ITU-T No.#1 Chart (standard mode). ** Based on Canon COLOR FAX TEST SHEET. |
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
next to your download
