Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 02.28.08
File Size 4.90 MB
Date 02.28.08
File Size 1.80 MB
Date 02.24.08
File Size 3.35 MB
Date 02.28.08
File Size 5.93 MB
Printer
Printing Method Color Bubble Jet
Print Speed (up to) Black:18 ppm
Color:12 ppm*
Print Resolution (Up to) Black:600 x 600 dpi
Color:4800 x 1200 dpi**
Ink Compatibility BCI-24 Black Ink Tank, BCI-24 Color Ink Tank
Paper Sizes Letter, legal, 4" x 6", 5" x 7", U.S. #10 envelopes
Paper Handling Plain Paper - 100 sheets
Transparencies - 30 sheets
Envelopes - 10
Photo Paper Pro 4" x 6" - 20 sheets
Photo Paper Pro 8.5" x 11" - 10 sheets
Copier
Copy Resolution (up to) 600 x 600 dpi
Copy Speed (up to) 18 cpm
Reduction / Enlargement 25% to 400%
Copy Features Borderless Copy, 2 on 1, Image Repeat, Fit-to-Page
Scanner
Scanning Element CCD
Max. Resolutions Optical:1200 x 2400 dpi
Interpolated:9600 x 9600 dpi
Color Depth Max. 48-bit internal
Max. Document Size 8.5" x 11.7"
Fax
Modem Speed up to 33.6 Kbps
Transmission Speed (approx.) Black - approx. 3 seconds/page***; Color - approx. 1 minute/page****
Memory Capacity 200 pages (based on ITU-T Chart #1, standard mode)
Fax Resolution Black - 203 x 196 dpi (fine mode); Color - 200 x 200 dpi
Speed Dialing Speed Dials - 40 Directory Dials
Receive Mode Fax only, Fax/Tel Auto Switch, Manual, Answering, DRPD
Photo Connect
Interface Built-in memory card slots, Bubble Jet Direct or PictBridge direct printing
Media Card Support CompactFlash&reg;, SmartMedia&reg;, SD Secure Digital, Memory Stick&reg;, MultiMediaCard, MicroDrive&reg;, xD-Picture Card, and miniSD card
General
OS Compatibility Windows&reg; 7, Windows &reg; XP/2000/Me/98
System Requirements Windows:
Windows XP: Pentium&reg; 300Mhz/64MB RAM
Windows 2000: Pentium 233MHz/64MB RAM
Windows Me: Pentium 233MHz/64MB RAM
Windows 98: Pentium 233MHz/64MB RAM
Common:Microsoft&reg; Internet Explorer 4.01/SP2
65MB hard-disk space
Standard Interface USB 2.0 Hi-Speed;, Direct Print Port
Software Included Setup CD Includes: MP Driver, MP Toolbox, Easy-PhotoPrint, Easy-PhotoPrint Plus, Easy-WebPrint (requires Microsoft Internet Explorer version 5.5, version 6.0 recommended), ArcSoft&reg; PhotoStudio&reg;, ScanSoft&reg; OmniPage&reg; SE (OCR), electronic Software Guide and Photo Application Guide
Dimension (W x D x H) 17.9" x 21.5" x 11.3" (with attachments); 17.9" x 14.1" x 9.8" (without attachments)
Weight 18.1 lbs (with attachments)
Warranty 1-year telephone support (90 days toll free from time of first call). Subject to certain terms and conditions. See www.canontechsupport.com for details.
Prices and specifications subject to change without notice. Actual prices are determined by individual dealers and may vary.
* PPM print speed based on the highest printer driver setting. Print speed will vary depending on system configuration, software, document complexity, print mode and page coverage.
** Ink droplets can be placed with a pitch of 1/4800 inch at minimum. Resolution may vary based on printer driver setting.
*** Approximate 3-seconds-per-page fax transmission time is based on ITU-T Chart #1 (MMR/standard mode) at 33.6 Kbps modem speed when transmitting to another V.34 fax machine. The Public Switch Telephone Network (PSTN) currently supports 28.8 Kbps modem speed or lower depending on telephone line conditions.
**** Based on Canon Color Fax Test Sheet.
CPM copy speed based on fast mode when copying a letter sized document.
USB 2.0 Hi-Speed performance requires Windows XP Service Pack 1 or Windows 2000 Service Pack 4 with pre-installed USB 2.0 port.
Requires xD Picture Care to Compact Flash adapter and miniSD card requires miniSD to SD Secure Digital card adapter.
Based on Canon Inc. industry-standard testing, using a Pentium 4, 1.7GHz, 256MB RAM, scanning an approximate 8.5" x 11" image at 600 dpi. Results may vary.
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
