Canon Support for Optura Pi | Canon U.S.A., Inc.
Optura Pi
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
Directional Microphones DM-50
File Name
Optura Pi Instruction Manual
File Name
Video Light VL-3
File Name
File Name
Battery Packs BP-512, BP-522 & BP-535
File Name
Video Light VL-3
File Name
ins_opturapi.pdf
SELECT ERROR CODE
| Power Supply (rated) | 7.4 V DC |
| Power Consumption | 4.7 W (using viewfinder), 5.5 W (using LCD screen) |
| Television System | EIA standard (525 lines, 60 fields) NTSC color signal |
| Video Recording system | 2 rotary heads, helical scanning system, DV system; VCR SD/SDL System |
| Audio Recording system | PCM digital sound: 16 bit (48 Khz/2 ch.); 12 bit (32 khz/ 4 ch) |
| Image Sensor | 1/4" CCD (charge coupled device); 380,000 pixels (approx. 360,000 effective pixels) |
| Tape Format | Video casettes bearing the MiniDV mark |
| Tape Speed | Sp: 3/4 ips (18.81mm/sec); LP: 1/2 ips (12.56mm/sec) |
| Maximum Recording Time (with an 80-min. cassette) | SP: 80 min; LP: 1/2 ips (12.56mm/sec) |
| Fast Forward/Rewind Time | 2 min. 30 sec. (with a 60 min cassette) |
| Lens | f/1.6 - 2.5, 12x power zoom, 4.1 - 49.2mm |
| Focusing System | TTL autofocus, manual focusing possible |
| Focusing System | 3 ft. 3 3/8 in (1m); 3/8 in. (1cm) on maximum wide angle |
| Minimum Illumination | 2.5 lux using the Low-Light program during tape recording |
| Recommended Illumination | More than 100 lux |
| Filter Diameter | 30.5 mm |
| Viewfinder | 0.55 in., color LCD (approx 113,00 pixels) |
| LCD Screen | 3.5 in measured diagonally (approx 200,000 pixels) |
| Microphone | Stereo electret condenser microphone |
| DV Terminal | Special 4-pin connector (Based on IEEE 1394 ) |
| Video Terminal | 1Vp-p/75 ohms unbalanced |
| S-video Terminal | 1Vp-p (Y signal) 0.286 Vp-p (C signal) |
| Audio Terminal | -10 dBV/47 kohms, unbalanced; Output level; -10 dBV, less than 3 kohms, unbalanced |
| Operating Temperature range | 32- 104°: F (0-40° C) |
| Dimensions | 2 5/8 x 3 3/8 x 5 7/8 in. (68 x 87 x 148mm) |
| Weight (not including lens and battery pack) | 1 lb. 6 7/8 oz. (650g) |
ADDITIONAL SUPPORT
CONTACT US
next to your download
