Canon Support for PIXMA MP780 | Canon U.S.A., Inc.
PIXMA MP780
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 02.25.08
File Size 3.39 MB
Date 02.25.08
File Size 2.07 MB
Date 02.29.08
File Size 1.55 MB
Date 02.29.08
File Size 976.66 KB
Date 02.25.08
File Size 3.96 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Products Windows 7 Windows 8 Windows 10 Windows 10s
PIXMA MP780 1
Printer
Print Speed (up to) Black:25 ppm (approx. 2.4 seconds/page)*
Color:17 ppm (approx. 3.5 seconds/page)*
Color Photo:4x 6 borderless photo: approx. 36 seconds
Number of Nozzles Black: 320
Color: 512 x 2 (C, M), 256 x 2 (Y, Bk)
Total: 1,856
Print Resolution (Up to) Black:600 x 600 dpi**
Color:4800 x 1200 dpi**
Ink Compatibility BCI-3eBk Black ink tank, BCI-6Bk Black ink tank, BCI-6C Cyan ink tank, BCI-6M Magenta ink tank, BCI-6Y Yellow ink tank
Ink Droplet Size 2 and 5 picoliters
Paper Sizes Letter , Legal, Credit Card (2.13" x 3.39"), 4" x 6", 5" x 7", U.S. #10 Envelopes
Paper Compatibility Plain paper, U.S. #10 envelopes; Canon Specialty Papers: Glossy Photo Paper (4x6, letter), High Resolution Paper (letter), Matte Photo Paper (letter), Photo Paper Plus Glossy (4x6, 5x7, letter), Photo Paper Plus Semi Gloss (5x7, letter), Photo Paper Pro (4x6, letter), Bubble Jet Transparencies (letter)
Output Tray Capacity Auto Sheet Feeder:Plain Paper: Approx. 150 Sheets (13mm)4" x 6" Photo Paper: 20 Sheets Cassette:Plain Paper: Approx. 150 Sheets (13mm)4" x 6" Photo Paper: 20 Sheets
Copier
Copy Resolution (up to) Black: 600 x 600 dpi; Color: 1200 x 1200 dpi
Copy Speed (up to) Black: 25 cpm (approx. 2.4 sec/page)*; Color: 17 cpm (approx. 3.5 sec/page)*
Reduction / Enlargement 25% - 400%
Copy Features Borderless, 2 on 1, Fit to Page, Image Repeat
Scanner
Scanner Type Flatbed
Scanning Element Charge-Coupled Device (CCD)
Max. Resolutions Optical:2400 x 4800 dpi
Interpolated:9600 x 9600 dpi
Color Depth 48-bit internal
Max. Document Size 8.5" x 11.7"
Fax
Modem Speed 33.6 Kbps***
Transmission Speed (approx.) Black: approx. 3 sec/page (Based on ITU-T Chart #1, standard mode.); Color: approx. 1 min/page (Based on Canon Color Fax Test Sheet.)
Memory Capacity 250 pages (Based on ITU-T Chart #1, standard mode.)
Fax Resolution Black: 203 x 196 dpi (fine mode); Color: 200 x 200 dpi
Receive Mode Fax only, Fax/Tel Auto Switch, Manual, Answering, DRPD
Photo Connect
Direct Connect Direct Print Port&#134; (cable not included)
General
OS Compatibility Windows 98/Me/2000/XP; Mac OS X v10.2.4 to 10.3.x
Standard Interface USB 2.0 Hi-Speed&#134;&#134; (cable not included)
Software Included CD-ROM&#135; including MP Driver, MP Navigator, Setup Software and User's Guide, Electronic Photo Application Guide, Electronic User's Guide, e-registration, ScanSoft&reg; Omnipage&reg; SE,11 Presto! PageManager, (Windows only) Easy-PhotoPrint 3.0, and Easy-WebPrint
Power Source 120V AC, 60Hz
Dimension (W x D x H) 18.5" x 19.1" x 12.0"
Weight 30 lbs.
Warranty Toll-free technical phone support plus 1-year limited warranty with InstantExchange program.&#135;&#135;
Specifications subject to change without notice.
* PPM print speeds are based on the highest speed printer driver mode. CPM copy speed based on fast mode when copying a letter-sized document. Photo print speed based on maximum print speed using Canon Photo Paper Plus Glossy. Print/copy speed will vary based on system configuration, software, document complexity, print mode and page coverage.
** Resolution may vary based on printer driver setting. Ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
*** The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T V.34 guidelines.
&#134; For a listing of select Canon digital cameras and DV camcorders featuring Bubble Jet Direct or PictBridge direct printing technology, visit www.usa.canon.com/consumer/direct print. To determine if a non-Canon brand camera or DV camcorder is PictBridge compatible, please consult the manufacturer.
&#134;&#134; USB 2.0 Hi-Speed performance requires Windows XP Service Pack 1 or Windows 2000 Service Pack 4 with pre-installed USB 2.0 port.
&#135; System requirements vary by application. ScanSoft OmniPage SE (OCR software) does not support Windows 98 first edition. Easy-WebPrint compatible with Windows only, requires Microsoft Internet Explorer version 5.5, version 6.0 recommended.
&#135;&#135; InstantExchange warranty program is subject to certain conditions and restrictions. See www.canontechsupport.com for details.
Limited Warranty & InstantExchange Program Details
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon USA") with respect to the new or refurbished Canon-brand product ("Product") packaged with this limited warranty, when purchased and used in the United States only.
The Product is warranted against defects in materials and workmanship under normal use and service (a) for a period of one (1) year from the date of original purchase when delivered to you in new condition in its original container or (b) for (1) year from the date of original purchase for refurbished Products. Product returned to a Canon USA repair facility or a Canon USA Authorized Service Facility ("ASF"), and proven to be defective upon inspection will be (a) repaired utilizing new, remanufactured, repaired and/or recycled parts (b) exchanged for new or; (c) exchanged for a refurbished Product, as determined by the Canon USA repair facility or the ASF. Warranty repair or replacement shall not extend the original warranty period of the Product. A dated proof of purchase is required at the time of warranty service. A copy of your dated bill of sale will satisfy this requirement. This warranty does not cover any accessories, or any consumables, such as paper or ink cartridges, as to which there shall be no warranty or replacement.
This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty ("Separate Warranty"). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. Non-Canon brand equipment and software that may be distributed with the Product are sold "as is" and without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose, and all such warranties are disclaimed. The sole warranty, if any, with respect to such non-Canon brand items is given by the manufacturer or producer thereof.
  1. Loss of or damage to the Product due to abuse, neglect, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, improper use, failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's user's manual or other documentation, or services performed by someone other than a Canon USA repair facility or ASF. Without limiting the foregoing, dropping the Product, scratches, and abrasions will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the user's manual or other documentation for the Product.
  2. Use of parts, media, software or supplies (other than those sold by Canon USA), including non-Canon ink cartridges or refilled ink cartridges, that cause damage to the Product or cause abnormally frequent service calls or service problems.
  3. If the Product has had its serial number or dating defaced, altered or removed.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE DISKETTES OR CD-ROMS ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE, AND NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON OR ENTITY WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA, OR ITS ASF. (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU.) CANON USA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, INCONVENIENCE, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE, OR INABILITY TO USE THE PRODUCT REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA OR ITS ASF HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ITS ASF BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT SOLD BY CANON USA NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA, OR ITS ASF. (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE EXCLUSION OR LIMITATION MAY NOT APPLY TO YOU.) THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT, AND STATES YOUR EXCLUSIVE REMEDY.
Canon USA offers a full range of customer technical support* options:
Interactive troubleshooting, the latest driver downloads, hours of operation, and answers to frequently asked questions (www.usa.canon.com/support)
Toll-free live technical support Monday–Friday (excluding Canon-observed holidays) at 1-800-OK-CANON (1-800-652-2666)
Telephone Device for the Deaf (TDD-1-855-270-3277)
Repair or Exchange Service Options: In the event service is required for the Product during the limited warranty period, Canon USA offers two hardware support options:
Canon USA's Carry-In/Mail-In Service provides repair or exchange, at Canon USA's option, through Canon USA's Authorized Service Facility (ASF) network. The name and telephone number of the ASF(s) near you may be obtained from Canon USA's Web site at www.canontechsupport.com or by calling the Canon USA Customer Care Center at 1-800-828-4040, or any time while speaking to a technical support person. A Product covered by this limited warranty will be repaired or exchanged, as determined by Canon USA, and returned without charge by the ASF.
InstantExchange Service**
The Canon USA repair facility will ship out the replacement Product prepaid by Canon USA. After receipt of the replacement Product (with instructions and a prepaid waybill), follow the enclosed instructions on how to ship your product to the Canon USA repair facility. Your Product must be returned in the shipping carton in which the replacement Product was packed and include the reference number, A COPY OF YOUR DATED PROOF OF PURCHASE (BILL OF SALE), and a complete explanation of the problem. DO NOT INCLUDE ANY OTHER ITEMS WITH THE YOUR PRODUCT IN THE RETURN SHIPPING CARTON, AND BE SURE TO RETAIN YOUR PRINTHEAD, INK CARTRIDGE(S) AND TANK(S).
InstantExchange Service exchanges your Product with a replacement Product, which will normally be shipped the same day if your request for this service is by 3 p.m. E.T. Monday through Friday, except holidays. Canon USA does not guarantee same day shipment in the event of the occurrence of factors beyond its reasonable control. The replacement Product you receive may be a refurbished or reconditioned unit and will be covered for the balance of the period remaining on your original limited warranty. NOTE THAT BY USING THIS SERVICE YOU WILL KEEP THE REPLACEMENT PRODUCT THAT IS SENT TO YOU. CANON USA WILL RETAIN THE PRODUCT THAT YOU ORIGINALLY PURCHASED, WHICH SHALL BECOME THE PROPERTY OF CANON USA. InstantExchange warranty program service is available only during the express limited-warranty period for your Product and only in the continental United States, Alaska and Hawaii during such period.
InstantExchange warranty service is subject to the availability of refurbished or new replacement units.
Canon U.S.A., Inc.
One Canon Park
Melville, NY 11747
USA
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
