Canon Support for PowerShot A300 | Canon U.S.A., Inc.
PowerShot A300
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.05.10
File Size 6.07 MB
Date 04.01.07
File Size 3.05 MB
Date 03.05.10
File Size 6.23 MB
Date 11.14.07
File Size 789.64 MB
Date 04.01.07
File Size 3.37 MB
Date 04.01.07
File Size 1.56 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type of Camera
Type Compact digital still camera with built-in flash and 5.1x digital zoom
Image Capture Device
Type 1/2.7 inch charge coupled device (CCD)
Total Pixels Approx. 3.3 million
Effective Pixels Approx. 3.2 million
Lens
Focal Length 5mm f/3.6 (35mm film equivalent: 33mm)
Digital Zoom 5.1x
Focusing Range Normal AF: 20cm - infinity; Macro AF: 5 - 20cm
Autofocus System 5-point AiAF/ 1-point AF (Fixed to center)
Viewfinders
Optical Viewfinder Inverted Galilean type
LCD Monitor 1.5 inch amorphous silicon TFT color LCD
LCD Pixels Approximately 67,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/3.6 - 5.6
Shutter Speed 1 - 1/2000 sec.; Slow shutter speed of 1/6 sec. is only available in select modes
Exposure Control
Sensitivity AUTO /ISO 50/ 100 / 200 / 400 equivalent
Light Metering Method Evaluative / Center-weighted average / Spot
Exposure Control Method Program AE
Exposure Compensation +/- 2.0 EV in 1/3-stop increments
AE Lock Not Available
White Balance
White Balance Control Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, or Flash), or Custom.
Flash
Built-in Flash Auto, Red-Eye Reduction On/ Off, Slow-Sync
Flash Range 20cm - 2.0m/0.67 ft. - 6.7 ft. (When ISO speed is set to AUTO)
Recycling Time Approx. 10 sec. or less.
Flash Exposure Compensation +/- 2.0 EV in 1/3-stop increments.
Shooting Specifications
Shooting Modes Auto, Manual, Stitch Assist, Movie
Photo Effects Vivid, Neutral, Low Sharpening, Sepia and Black & White.
Self Timer Operates with approx. 2 sec. or approx 10 sec. count-down.
Wireless Control Not Available
Continuous Shooting Approx. 2.2 shots/sec. (Large / Fine Mode and LCD monitor is Off)
Image Storage
Storage Media CompactFlash (CF) Card Type I
File Format QuickTime&#153; AVI
Print Order Format Digital Print Order Format (DPOF) Version 1.1
Image Recording Format Still Image: JPEG (Exif 2.2 compliant)
JPEG Compression Mode SuperFine, Fine or Normal
Number of Recording Pixels 2048 x 1536 (Large), 1600 x 1200 (Medium 1), 1024 x 768 (Medium 2), 640 x 480 pixels (Small)
Movie: 640 x 480, 320 x 240 or 160 x 120
Number of Recordable Images
Image data &#160;These figures reflect standard shooting conditions established by Canon.
Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode.
Time of Recordable Movies
Movie data &#160;Individual movie clips are limited to 30sec. (640 x 480) or 3 minutes each maximum per clip. Above figures show total movie capacity on various CF cards, measured under Canon's standard test conditions, and may vary depending upon scene, subjects or camera settings.
Playback Specifications
Playback Modes File Single, Index (9 thumbnails), Magnification (2x to 10x), Slide Show or Movie
Erasing Specifications
Erase Modes Single Image, All Images
Interfaces
Computer Interface Universal Serial Bus (USB)(mini-B jack)
Video Out None
Other CF card slot (accept type I cards). Direct connection to Canon CP Printers and select Bubble Jet Photo Printers (no computer required).
Power Supply 1. Size AA Alkaline battery x2
2. Rechargeable size AA NiMH battery x2 (NB4-100)
3. AC Adapter kit ACK-800Approx. 75 shots/Approx. 200 shots (LCD monitor ON)
Approx. 210 shots/Approx. 450 shots (LCD monitor OFF)
(Alkaline battery/NB4-100)Approx. 90 min/Approx 120 min. (Alkaline battery/NB-1AH)
Power Source 1. Size AA Alkaline battery x2
Shooting Capacity Approx. 75 shots/Approx. 200 shots (LCD monitor ON)
Playback Time Approx. 90 min/Approx 120 min. (Alkaline battery/NB-1AH)
Physical Specifications
Operating Temperature 32 - 104&deg;F (0 - 40&deg;C)
Operating Humidity 10 - 90%
Dimensions (W x H x D) 4.37 x 2.28 x 1.44 in./110.0 x 58.0 x 36.6mm (Excluding protrusions)
Weight Approx. 6.17 oz./175g (Camera body only)
Computer System Requirements
Mac Requirements Hardware: Power Macintosh, PowerBook, iMac, iBook or eMac. A CD-ROM drive is required to install the software.
OS: Mac OS 9.0 through 9.2, OS X (Version 10.1/10.2). (Please see our Mac OS X Compatibility Statement); Note: USB Mounter software is not supported in Mac OS X.
CPU: PowerPC
Interface: USB: Cable connection via the camera's USB port is limited to genuine Apple Computer brand models with a built-in USB interface.
Free Hard Drive Space: 200MB or more for Canon Utilities
RAM: 20MB or more of application memory (Mac OS 9.x), 128MB or more (Mac OS X)
Display: 800 x 600 pixels/32,000 colors or better is required, 1024 x 768 pixels or better is recommended.
PC Requirements Hardware: IBM PC/AT compatible with CD-ROM Drive.
OS: Windows 98 (including the Second Edition), Windows 2000, Windows Me, Windows XP (Home, Professional) (Please see our Windows XP compatibility statement)
CPU: Pentium 150 MHz or higher processor (Windows 2000/Windows ME/Windows 98); 300MHz or higher processor (Windows XP)
Interface: USB: Cable connection via the camera's USB port is limited to computers pre-installed with an OS listed above.
Free Hard Drive Space: 300MB or more for Canon Utilities/Drivers.
RAM: 64MB or more (Windows 2000/Windows ME/Windows 98), 128MB or more (Windows XP)
Display: 800 x 600 pixels/High Color (16 bit) or better is required, 1024 x 768 pixels or better is recommended.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
