Canon Support for PowerShot A495 | Canon U.S.A., Inc.
PowerShot A495
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 01.06.10
File Size 1.52 MB
Date 01.06.10
File Size 4.37 MB
Date 01.06.10
File Size 6.23 MB
Date 01.06.10
File Size 6.07 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
10.0 Megapixel, 1/2.3-inch type Charge Coupled Device (CCD)
Total Pixels
Approx. 10.3 Megapixels
Effective Pixels
Approx. 10.0 Megapixels
Focal Length
6.6 (W) - 21.6 (T)mm - 35mm (film equivalent: 37 - 122mm)
Digital Zoom
Approx. 4x
Focusing Range
Normal: 2 in. (5 cm) - infinity (W), 9.8 in. (25 cm) - infinity (T)Macro: 0.4 in - 1.6 ft. (W), 9.8 in. - 1.6 ft. (T) (1 - 50 cm (W), 25 - 50 cm (T))
Autofocus System
TTL Autofocus
Optical Viewfinder
N/A
LCD Monitor
2.5-inch type
LCD Pixels
Approx. 115,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/3.0 (W) - f/5.8 (T)
Shutter Speed
1 - 1/2000 sec.15 - 1/2000 sec. (Total shutter speed range)Shutter speeds differ depending on the shooting mode.Shutter speed available in Long Shutter: 15, 13, 10, 8, 6, 5, 4, 3.2, 2.5, 2, 1.6, 1.3, 1 (Unit: sec.)
Sensitivity
Auto, ISO 80/100/200/400/800/1600 (Standard Output Sensitivity. Recommended Exposure Index)
Light Metering Method
Evaluative*, Center-weighted average, Spot**
* Facial brightness is evaluated in Face AiAF (9-point)
** Fixed to the center
Exposure Control Method
Program AE; AE Lock
Exposure Compensation
+/-2 stops in 1/3-stop increments
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
Built-in Flash
Auto, Slow Synchro, Red-eye Reduction, Auto Red-eye Correction, Shutter Sync: 1st curtain, Flash On, Flash Off; FE lock, Smart Flash Exposure
Flash Range
30 cm - 3.0 m (W), 30 cm - 2.0 (T) (12 in. - 9.8 ft (W), 12 in. - 6.6 ft. (T))Image brightness may diminish depending on the shooting distance.
Recycling Time
10 sec. or less (battery voltage: 3.0 V)
Flash Exposure Compensation
N/A
Shooting Modes
Auto, P, Special Scene (Portrait, Night Snapshot, Kids & Pets, Indoor, Face Self-Timer, Low Light, Super Vivid, Poster Effect, Beach, Foliage, Snow, Fireworks, Long Shutter), Movie
Photo Effects
My Colors Off, Vivid, Neutral, Sepia, Black & White, Custom Color*
*Adjustment of contrast, sharpness and saturation.
Self Timer
Approx. 10-sec. delay/approx. 2.sec. delay/custom*
Shooting start time (0-10 sec. (in 1-second increments), 15/20/30 sec.) and number of shots (1 - 10 shots (in 1-shot increments)) can be specified.
Wireless Control
N/A
Continuous Shooting
Approx. 0.9 shot/sec. approx. 2.5 shots/sec. in Low Light)
Storage Media
SD/SDHC/SDXC Memory Card, MultiMediaCard, MMC Plus Card, HC MMC Plus Card
File Format
Design rule for camera file system, DPOF (Version 1.1) compliant
JPEG Compression Mode
Still Image: Exif 2.2 (JPEG)
Movie: AVI (Image data: Motion JPEG; Audio: WAVE (Monaural))
Number of Recording Pixels
Still Image: 3648 x 2736 (Large), 2816 x 2112 (Medium 1), 2272 x 1704 (Medium 2), 1600 x 1200 (Medium 3/Date Stamp), 640 x 480 (Small), 3648 x 2048 (Widescreen)
Movie: Standard Definition: 640 x 480 (30 (29.97) fps/30 (29.97) fps LP), 320 x 240 (30 (29.97) fps)
Available up to 4GB*
*Even if the file size has not reached 4GB, recording stops when the recording time reaches 1 hour. For memory cards with a capacity less than 4GB, recording stops when the recording time reaches 1 hour.
Image data
Movie data
Note: N=Normal F=Fine
Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media.
Playback Modes File
Still Image: Single, Magnification (approx. 2x-10x), Resume, Index (4-130 thumbnails), Slide Show, Red-eye Correction, Resize, Rotate, Jump, Slide Show, Focus Check, Histogram, Overexposure Warning
Movie: Normal Playback*, Slow Motion**, Pause, First Frame, Last Frame, Next Frame, Previous Frame, Fast Forward, Fast Rewind.Displays playback position and shooting time
*Audio settings available in 5 levels.
** 5 levels (including normal playback), sound not available
Erase Modes
Still Image: single image, all images
Movie: any movie file one at a time.
Computer Interface
Hi-Speed USB 2.0 (mini-B jack)
Video Out
NTSC/PAL
Audio Out
Monaural
Other
Memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Source
1.AA-size Alkaline Battery (x2)
2.AA NiMH batteries (NB-3AH) (x2)
3.Compact Power Adapter CA-PS800 (available accessory)
Shooting Capacity
Still Image: approx. 150 shots (AA-size Alkaline Battery), approx. 400 shots (AA-size NiMH Battery (NB-3AH))*
Playback Time
Approx. 8 hours. (AA-size Alkaline Battery), approx. 10 hours (AA-size NiMH Battery)* LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used.
Operating Temperature
32-104&deg;F/0-40&deg;C
0 - 35&deg;C/32 - 95&deg;F when NB-3AH is used
Operating Humidity
10-90%
Dimensions (W x H x D)
3.68 x 2.43 x 1.20 in./93.5 x 61.7 x 30.6mm
Weight
Approx. 6.17 oz./175g (camera, including batteries and memory card)26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi)
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
