Canon Support for PowerShot A495 | Canon U.S.A., Inc.
PowerShot A495
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type | 10.0 Megapixel, 1/2.3-inch type Charge Coupled Device (CCD) |
Total Pixels | Approx. 10.3 Megapixels |
Effective Pixels | Approx. 10.0 Megapixels |
Focal Length | 6.6 (W) - 21.6 (T)mm - 35mm (film equivalent: 37 - 122mm) |
Digital Zoom | Approx. 4x |
Focusing Range | Normal: 2 in. (5 cm) - infinity (W), 9.8 in. (25 cm) - infinity (T)Macro: 0.4 in - 1.6 ft. (W), 9.8 in. - 1.6 ft. (T) (1 - 50 cm (W), 25 - 50 cm (T)) |
Autofocus System | TTL Autofocus |
Optical Viewfinder | N/A |
LCD Monitor | 2.5-inch type |
LCD Pixels | Approx. 115,000 dots |
LCD Coverage | Approx. 100% |
Maximum Aperture | f/3.0 (W) - f/5.8 (T) |
Shutter Speed | 1 - 1/2000 sec.15 - 1/2000 sec. (Total shutter speed range)Shutter speeds differ depending on the shooting mode.Shutter speed available in Long Shutter: 15, 13, 10, 8, 6, 5, 4, 3.2, 2.5, 2, 1.6, 1.3, 1 (Unit: sec.) |
Sensitivity | Auto, ISO 80/100/200/400/800/1600 (Standard Output Sensitivity. Recommended Exposure Index) |
Light Metering Method | Evaluative*, Center-weighted average, Spot** * Facial brightness is evaluated in Face AiAF (9-point) ** Fixed to the center |
Exposure Control Method | Program AE; AE Lock |
Exposure Compensation | +/-2 stops in 1/3-stop increments |
White Balance Control | Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom * Facial brightness is evaluated in Face AiAF (9-point) |
Built-in Flash | Auto, Slow Synchro, Red-eye Reduction, Auto Red-eye Correction, Shutter Sync: 1st curtain, Flash On, Flash Off; FE lock, Smart Flash Exposure |
Flash Range | 30 cm - 3.0 m (W), 30 cm - 2.0 (T) (12 in. - 9.8 ft (W), 12 in. - 6.6 ft. (T))Image brightness may diminish depending on the shooting distance. |
Recycling Time | 10 sec. or less (battery voltage: 3.0 V) |
Flash Exposure Compensation | N/A |
Shooting Modes | Auto, P, Special Scene (Portrait, Night Snapshot, Kids & Pets, Indoor, Face Self-Timer, Low Light, Super Vivid, Poster Effect, Beach, Foliage, Snow, Fireworks, Long Shutter), Movie |
Photo Effects | My Colors Off, Vivid, Neutral, Sepia, Black & White, Custom Color* *Adjustment of contrast, sharpness and saturation. |
Self Timer | Approx. 10-sec. delay/approx. 2.sec. delay/custom* Shooting start time (0-10 sec. (in 1-second increments), 15/20/30 sec.) and number of shots (1 - 10 shots (in 1-shot increments)) can be specified. |
Wireless Control | N/A |
Continuous Shooting | Approx. 0.9 shot/sec. approx. 2.5 shots/sec. in Low Light) |
Storage Media | SD/SDHC/SDXC Memory Card, MultiMediaCard, MMC Plus Card, HC MMC Plus Card |
File Format | Design rule for camera file system, DPOF (Version 1.1) compliant |
JPEG Compression Mode | Still Image: Exif 2.2 (JPEG) Movie: AVI (Image data: Motion JPEG; Audio: WAVE (Monaural)) |
Number of Recording Pixels | Still Image: 3648 x 2736 (Large), 2816 x 2112 (Medium 1), 2272 x 1704 (Medium 2), 1600 x 1200 (Medium 3/Date Stamp), 640 x 480 (Small), 3648 x 2048 (Widescreen) Movie: Standard Definition: 640 x 480 (30 (29.97) fps/30 (29.97) fps LP), 320 x 240 (30 (29.97) fps) Available up to 4GB* *Even if the file size has not reached 4GB, recording stops when the recording time reaches 1 hour. For memory cards with a capacity less than 4GB, recording stops when the recording time reaches 1 hour. |
Image data |
Movie data | Note: N=Normal F=Fine Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media. |
Playback Modes File | Still Image: Single, Magnification (approx. 2x-10x), Resume, Index (4-130 thumbnails), Slide Show, Red-eye Correction, Resize, Rotate, Jump, Slide Show, Focus Check, Histogram, Overexposure Warning Movie: Normal Playback*, Slow Motion**, Pause, First Frame, Last Frame, Next Frame, Previous Frame, Fast Forward, Fast Rewind.Displays playback position and shooting time *Audio settings available in 5 levels. ** 5 levels (including normal playback), sound not available |
Erase Modes | Still Image: single image, all images Movie: any movie file one at a time. |
Computer Interface | Hi-Speed USB 2.0 (mini-B jack) |
Video Out | NTSC/PAL |
Audio Out | Monaural |
Other | Memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable |
Power Source | 1.AA-size Alkaline Battery (x2) 2.AA NiMH batteries (NB-3AH) (x2) 3.Compact Power Adapter CA-PS800 (available accessory) |
Shooting Capacity | Still Image: approx. 150 shots (AA-size Alkaline Battery), approx. 400 shots (AA-size NiMH Battery (NB-3AH))* |
Playback Time | Approx. 8 hours. (AA-size Alkaline Battery), approx. 10 hours (AA-size NiMH Battery)* LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used. |
Operating Temperature | 32-104°F/0-40°C 0 - 35°C/32 - 95°F when NB-3AH is used |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 3.68 x 2.43 x 1.20 in./93.5 x 61.7 x 30.6mm |
Weight | Approx. 6.17 oz./175g (camera, including batteries and memory card)26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi) All data are based on Canon's Standard Test Method. Subject to change without notice. Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
