Canon Support for PowerShot A50 | Canon U.S.A., Inc.
PowerShot A50
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type of Camera
Type Compact digital still camera with built-in flash and optical zoom lens.
Image Capture Device
Type 1/2.7-inch charge coupled device (CCD)
Total Pixels 1,310,000
Lens
Digital Zoom Maximum 2.5x (Maximum 7.5x with optical zoom)
Autofocus System TTL 3 point AiAF
Viewfinders
LCD Monitor 1.5-inch low-temperature polycrystalline silicon TFT color LCD
LCD Pixels 117,600 effective pixels
LCD Coverage 80%
Aperture and Shutter
Shutter Speed 1 - 1/1500 sec.
* 1 sec. in manual mode with the flash off or in slow synchro mode. Noise reduction processing on speeds slower than 1/6 sec.
Exposure Control
Sensitivity ISO 100 equivalent (automatically raised to ISO 150 in low light)
Light Metering Method Evaluative metering (linked to focusing point)
Exposure Control Method Program AE; Exposure is locked once focusing is complete.
Exposure Compensation +/-2 stops in 1/3-stop increments.
White Balance
White Balance Control Automatic, Manual
Flash
Built-in Flash Red-Eye Reduction Auto/Auto/On/Off
Flash Range Normal Mode: 76cm - 4.2m (2.5 - 13.8 ft.) (Wide-angle), 76cm - 2.5m (2.5 - 8.2 ft.) (Telephoto)
Macro Mode: 26 - 76cm (10.2 in. - 2.5 ft.) (Wide-angle/Telephoto)
Shooting Specifications
Shooting Modes Auto/Manual/Stitch Assist/Playback
Self Timer Shoots after approx. 10 sec.
Image Storage
Number of Recording Pixels 1,280 x 960 pixels (Large), 640 x 480 pixels (Small)
Number of Recordable Images
Image data Note: N=Normal F=Fine CCD RAW=Non-compressedStorage capacity varies depending on the scene or subjects. This data is estimated from Canon's standard shooting conditions. These numbers are the values in the Auto or Program modes. In the Stitch Assist mode there is a possibility that the shooting capacity will be slightly lower than in the Full Auto or Program Mode.
Erasing Specifications
Erase Modes Single image, all images
Interfaces
Computer Interface RS-232 serial
Video Out NTSC or PAL selectable
Power Supply Lithium battery (2CR5), optional NiMH (NB-5H) battery or AC Compact Power Adapter CA-PS500
Power Source Lithium battery (2CR5), optional NiMH (NB-5H) battery or AC Compact Power Adapter CA-PS500
Physical Specifications
Dimensions (W x H x D) 4.1 x 2.7 x 1.5 in./103 x 68 x 37.3mm.
Weight Approx. 9.2 oz./260g (without battery and CF card).
Computer System Requirements
Mac Requirements Please install the software on a Macintosh computer that meets the following system requirements. Hardware: Power, Macintosh OS: Mac OS 7.5.3, QuickTime 2.1CPU: Power PCRAM: 32 MB or more, Free Hard Disk Space - Plug in Module 2.4: 15 MB or more; Time Tunnel 1.6: 25 MB or more; PhotoStitch 2.3: 30 MB or more; SlideShowMaker 1.3: 20 MB or more, Monitor: 640 x 480 pixels, 256 colors or more (1,024 x 768 pixels, millions of colors recommended)
PC Requirements Hardware: IBM PC/AT compatible, OS: Windows 95, Windows 98 or WindowsNT 4.0CPU: Pentium or better. RAM: Windows 95/98: 24 MB or more; Windows NT 4.0: 32 MB or more. Connectors: Standard RS-232C Interface(For PowerShot A50) D-SUB 9-Pin Connector (IBM PC/AT compatible)Free Hard Disk Space: TWAIN Driver 2.4: 15 MB or more; ZoomBrowser 1.1: 30 MB or more; SlideShowMaker 1.3: 20 MB or more; TimeTunnel 2.4: 30 MB or more; PhotoStitch 2.3: 40 MB or more; Ulead PhotoImpact 4.2: 130 MB or more. Monitor: 640 x 480 pixels, 256 colors or more (1,024 x 768 pixels, 24-bit color or more recommended)
Power Supply Kit DK110 (Consists of Compact Power Adapter CA-PS100, DC Coupler DR-100A, and Battery Pack NB-5H)Digital Printer CD-200Soft Case SC-1008MB CompactFlash Card with PCMCIA Adapter FC-8MAdditional Battery Pack NB-5H
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
