Canon Support for PowerShot A520 | Canon U.S.A., Inc.
PowerShot A520
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type of Camera
Type | Compact digital camera with built-in flash and 4x Optical/3.6x Digital/14x Combined Zoom |
Image Capture Device
Type | 4.0 Megapixel, 1/2.5 inch type Charge Coupled Device (CCD) |
Total Pixels | Approx. 4.2 Megapixels |
Effective Pixels | Approx. 4.0 Megapixels |
Lens
Focal Length | 5.8-23.2mm, f/2.6-5.5 (35mm film equivalent: 35-140mm) |
Digital Zoom | 3.6x |
Focusing Range | NORMAL: 1.5 ft./45cm-Infinity MACRO: 2 in.-1.5 ft./5-45cm (WIDE), 11.8 in.-1.5 ft./30-45cm(TELE) |
Autofocus System | 9-point AiAF/1-point AF (Fixed to center)Manual Focus, AF Lock, AF-assist Beam ON/Off, MF magnified display function available |
Viewfinders
Optical Viewfinder | Real-image 4x optical zoom viewfinder |
LCD Monitor | 1.8 inch low-temperature polycrystalline silicon TFT color LCD |
LCD Pixels | Approx. 115,000 pixels |
LCD Coverage | 100% |
Aperture and Shutter
Maximum Aperture | f/2.6-8.0 (W), f/5.5-8.0 (T) |
Shutter Speed | 15-1/2000 sec; can be set in 1/3-stop increments in Manual and Shutter-priority (Tv) Modes. |
Exposure Control
Sensitivity | AUTO, ISO 50/100/200/400 equivalent |
Light Metering Method | Evaluative, Center-weighted average, Spot**Metering frame with Spot mode is center fixed. |
Exposure Control Method | Program AE, Aperture or Shutter-Priority AE, Manual |
Exposure Compensation | +/- 2 stops in 1/3-stop increments |
ND Filter | Not Available |
White Balance
White Balance Control | Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H) or Custom |
Flash
Built-in Flash | Operation Modes: Auto*, Flash On*, Flash Off* Red-Eye Reduction is available |
Flash Range | WIDE: 1.5-11.5 ft./45cm-3.5m TELE: 1.5-7.2 ft./45cm-2.2m MACRO: 11.8 in.-1.5 ft./30-45cm (W/T) (When sensitivity is set to Auto) |
Recycling Time | Approx. 15 sec. or less (battery voltage=3.15V) |
Flash Exposure Compensation | Not Available |
Shooting Specifications
Shooting Modes | Auto, Creative Zone (P, Tv, Av, M), Image Zone (Portrait, Landscape, Night scene, Fast shutter, Slow shutter), Special Scene Modes (Foliage, Snow, Beach, Fireworks, Underwater, Indoor, Kids & Pets, Night Snapshot), Stitch Assist, Movie |
Photo Effects | Off, Vivid, Neutral, Low Sharpening, Sepia and Black & White |
Self Timer | Activates shutter after an approx. 2 sec. or approx 10 sec. delay, Custom timer |
Wireless Control | Not Available |
Continuous Shooting | Approx. 1.9 shots/sec. |
Image Storage
Storage Media | SD memory card |
Print Order Format | Design rule for camera file system Exif 2.2(JPEG) and DPOF (Version 1.1) compliant |
Image Recording Format | Still: Exif 2.2 (JPEG) Movie: AVI (Image data: Motion JPEG; Audio data: WAVE (Monaural)) |
JPEG Compression Mode | Normal, Fine, SuperFine |
Number of Recording Pixels | Still Image: 2272x1704 (Large), 1600x1200 (Medium 1), 1024x768 (Medium 2), 640x480 (Small) Movie: 640x480, 320x240 or 160x120 |
Number of Recordable Images
Image data |   Note: N=Normal F=Fine SF=SuperFine Storage capacity varies depending on the scene or the subjects. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of SD Memory Card. Individual clips are limited to 3 minutes (30 seconds maximum at 640 x 480 resolution). File sizes and resulting number of shots given above will vary depending on the subject, shooting conditions and shooting mode. |
Playback Specifications
Playback Modes File | Single, Index (9 thumb images), Normal Playback, Special Playback, Movie Editing, Camera Sound Playback |
Erasing Specifications
Erase Modes | Still Images: Single Images, All Images Movies: Part of Movie, All of Movie |
Interfaces
Computer Interface | USB (mini-B/PTP) |
Video Out | NTSC or PAL |
Audio Out | Monaural |
Other | SD memory card slot. Direct connection to Canon CP Printers and select BJ Printers via camera's USB cable (no computer required). |
Power Supply | 1. Two Size AA Alkaline batteries 2. Two Rechargeable size AA NiMH batteries (Canon brand NB-2AH/NB-1AH) 3. AC Adapter Kit (ACK800)AA NiMH: LCD On - Approx. 300 shots (CIPA Test Standard); LCD Off - Approx. 800 shotsAA Alkaline batteries Approx. 180 minutes (Under Canon's standard conditions*1 with fully charged battery), AA NiMH batteries Approx. 300 minutes. |
Power Source | 1. Two Size AA Alkaline batteries 2. Two Rechargeable size AA NiMH batteries (Canon brand NB-2AH/NB-1AH) 3. AC Adapter Kit (ACK800) |
Shooting Capacity | AA NiMH: LCD On - Approx. 300 shots (CIPA Test Standard); LCD Off - Approx. 800 shots |
Playback Time | AA Alkaline batteries Approx. 180 minutes (Under Canon's standard conditions*1 with fully charged battery), AA NiMH batteries Approx. 300 minutes. |
Physical Specifications
Operating Temperature | 32-104° F/0-40° C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 3.57 x 2.52 x 1.51 in./90.7 x 64.0 x 38.4mm (Excluding protrusions) |
Weight | Approx. 6.35 oz./180g (camera body only) |
Note: *1 Normal temperature (73° F/23° C). Shoot images at wide angle and at telephoto end alternatively with 20 second intervals. Use flash at every fourth shot. Turn camera off and on after every eight shots. LCD brightness setting by Factory default. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
