Canon Support for PowerShot A75 | Canon U.S.A., Inc.
PowerShot A75
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.05.10
File Size 6.07 MB
Date 04.01.07
File Size 2.22 MB
Date 03.05.10
File Size 6.23 MB
Date 04.01.07
File Size 1.07 MB
Date 04.01.07
File Size 412.63 KB
Date 04.01.07
File Size 2.79 MB
Date 04.01.07
File Size 2.36 MB
Date 12.18.07
File Size 1.42 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type of Camera
Type Compact digital still camera with built-in flash and 3.0x Optical/3.2x Digital/10x Combined Zoom
Image Capture Device
Type 1/2.7 inch type Charge-Coupled Device (CCD)
Total Pixels Approx. 3.3 Million
Effective Pixels Approx. 3.2 Million
Lens
Focal Length 5.4 - 16.2mm zoom lens (35mm film equivalent: 35 - 105mm)
Digital Zoom 3.2x
Focusing Range Normal AF: 46cm/1.5 ft. - Infinity
Macro AF: 5 - 46cm/2.0 in. - 1.5 ft. (WIDE), 26 - 46cm/10 in. - 1.5 ft. (TELE)
Manual focus: 5cm/2.0 in. - Infinity (WIDE), 26cm/10 in. - Infinity (TELE)
Autofocus System 9-point AiAF/1-point AF(Fixed to center)
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 1.8 inch low-temperature polycrystalline silicon TFT color LCD
LCD Pixels Approx. 110,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.8 - 8.0 (W), f/4.8 - 8.0 (T)
Shutter Speed 15 - 1/2,000 sec.
Exposure Control
Sensitivity AUTO*; ISO 50/100/200/400 equivalent
*Camera automatically sets the optimum speed.
Light Metering Method Evaluative/ Center-weighted average/ Spot*
*Metering frame with Spot mode is center fixed.
Exposure Control Method Program AE/ Aperture or Shutter-priority AE/ Manual
Exposure Compensation +/- 2 EV in 1/3-stop increments
ND Filter Not Available
White Balance
White Balance Control Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H), or Custom White Balance
Flash
Built-in Flash Operation Modes: Auto, Red-Eye Reduction ON/OFF, Slow-Sync
Flash Range WIDE: 46cm - 4.2m (1.5 - 14 ft.)
TELE: 46cm - 2.5m (1.5 - 8.2 ft.)
MACRO: 26 - 46cm (10 in. - 1.5 ft.) (When sensitivity is set to Auto)
Recycling Time Approx. 15 sec. or less (battery voltage=4.3V)
Flash Exposure Compensation Not Available
Shooting Specifications
Shooting Modes Auto, Creative (P, Tv, Av, M), Programmed Image Control Zone (Portrait, Landscape, Night scene, Fast shutter, Slow shutter, Stitch assist), Movies, Special Scene Mode (Foliage, Snow, Beach, Fireworks, Underwater, Indoor)
Photo Effects Vivid, Neutral, Low Sharpening, Sepia and Black & White
Self Timer Operates with approx. 2 sec. or approx 10 sec. count-down.
Wireless Control Not Available
Continuous Shooting Approx. 2.2 shots/sec.
Image Storage
Storage Media CompactFlash (CF) Card Type I
Print Order Format Design rule for camera file system, Digital Print Order Format (DPOF) Version 1.1
Image Recording Format Exif 2.2 (JPEG)
JPEG Compression Mode SuperFine, Fine, Normal
Number of Recording Pixels Still Image: 2,048 x 1,536 (Large), 1,600 x 1,200 (Medium 1), 1,024 x 768 (Medium 2), 640 x 480 pixels (Small)
Movie: 640 x 480, 320 x 240 or 160 x 120
Number of Recordable Images
Image data &#160;These figures reflect standard shooting conditions established by Canon.
Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode.
Time of Recordable Movies
Movie data &#160;Above-written figures are measured under Canon's standard conditions and may vary depending on the scene, subjects or camera settings. Total length of movie files recordable on specific CF cards; Individual movie clips are limited to 3 minutes maximum per clip.
Playback Specifications
Playback Modes File Single, Index (9 thumbnails), Magnification (Approx. 2.0x to 10x), Slide Show or Movie
Erasing Specifications
Erase Modes Still Images: Single Image, All Images
Movie: Part of Movie, All Movie
Interfaces
Computer Interface Universal Serial Bus (USB) (mini-B jack)
Video Out NTSC or PAL
Audio Out Monaural
Other CF card slot (accept Type I card). Direct connection to Canon CP Printers and select BJ Printers (no computer required)
Power Supply 1. Size AA Alkaline battery x4
2. Rechargeable size AA NiMH battery x4 (NB-1AH)
3. Compact Power Adapter (CA-PS500)
4. Coin-type secondary lithium battery MS-614SAA ALKALINE: LCD on - Approx. 250; LCD Off - Approx. 800
AA NIMH: LCD On - Approx. 550; LCD Off - Approx. 1200Approx. 280 minutes (Under Canon's standard conditions*1 with fully charged battery)
Power Source 1. Size AA Alkaline battery x4
Shooting Capacity AA ALKALINE: LCD on - Approx. 250; LCD Off - Approx. 800
Playback Time Approx. 280 minutes (Under Canon's standard conditions*1 with fully charged battery)
Physical Specifications
Operating Temperature 32 - 104&deg;F (0 - 40&deg;C)
Operating Humidity 10 - 90%
Dimensions (W x H x D) 3.98 x 2.52 x 1.24 in./101.0 x 64.0 x 31.5mm (Excluding grip, lens and protrusions)
Weight Approx. 7.06 oz./200g (camera body only)
Computer System Requirements
Mac Requirements OS: Mac OS 9.0 - 9.2, Mac OS X (v10.1/10.2).
Computer Model: The above OS should be pre-installed on computer with built-in USB ports.
CPU: PowerPC.
Interface: USB (Models with Apple genuine USB interface only).
PC Requirements OS: Microsoft Windows 98 (including Second Edition)/Me/2000/XP.
CPU: Pentium 150MHz or higher processor (Windows 98/ Me/2000), Pentium 300MHz or higher processor (Windows XP).
Interface: USB (Windows 98/Me/2000/ XP pre-install model only).
*1 Normal temperature (23&deg;C). Shoot images at wide angle and at telephoto end alternatively with 20 second intervals. Use flash at every 4-time shooting. Turn camera off and on at every 8-time shooting. LCD brightness setting by Factory default.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
