Canon Support for PowerShot A80 | Canon U.S.A., Inc.
PowerShot A80
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.05.10
File Size 6.07 MB
Date 03.05.10
File Size 6.23 MB
Date 04.01.07
File Size 2.67 MB
Date 11.14.07
File Size 1.24 MB
Date 04.01.07
File Size 4.15 MB
Date 11.14.07
File Size 976.56 KB
Date 04.01.07
File Size 1.56 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type of Camera
Type Compact digital still camera with built-in flash and 3x Optical / 3.6x Digital /11x Combined Zoom
Image Capture Device
Type 1/1.8 inch Charge-Coupled Device (CCD)
Effective Pixels Approx. 4.0 million
Lens
Focal Length 7.8 - 23.4mm, f/2.8 - 4.9 zoom Lens(35mm film equivalent: 38 - 114mm)
Digital Zoom 3.6x
Focusing Range Normal AF: 1.5 ft. - infinity/45cm - infinity
Macro AF: 2 in. - 1.5 ft./5 - 45cm (WIDE), 9.8 in. - 1.5 ft./25 - 45cm (TELE)
Autofocus System 9-point AiAF/ 1-point AF (Fixed to center)
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 1.5 in. amorphous silicon TFT color LCD With variable-angle function.
LCD Pixels Approx. 67,000 pixels (Picture coverage approx. 100%)
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.8/8.0 (W), f/4.9/8.0 (T)
Shutter Speed 15 - 1/2,000 sec. Slow shutter of 1.3 sec. and more operates with noise reduction
Exposure Control
Sensitivity AUTO/ISO 50/100/200/400
Light Metering Method Evaluative/Center-weighted average/Spot
Exposure Control Method Program AE/Aperture or Shutter-priority AE/Manual
White Balance
White Balance Control Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent or Fluorescent H) or Custom
Flash
Built-in Flash Operation Modes: Auto, Red-eye Reduction On/ Off, Slow-Sync
Flash Range WIDE: 1.5 - 14 ft. (45cm - 4.4m)
TELE: 1.5 - 8.2 ft. (45cm - 2.5m)
Macro: 9.8 in. - 1.5 ft./25 - 45cm (When sensitivity is set to ISO 100 equivalent)
Recycling Time Approx. 10 sec. or shorter
Shooting Specifications
Shooting Modes Auto, Creative (P, Av, Tv, M, Custom 1, Custom 2), Programmed Image Control Zone, Image (Portrait, Landscape, Night Scene, Stitch Assist, Movie)
Photo Effects Vivid, Neutral, Low Sharpening, Sepia and Black & White
Self Timer Operates with approx. 2 sec. or approx 10 sec. count-down
Wireless Control Not Available
Continuous Shooting Approx. 2.4 shots/sec. (Large/Fine Mode and LCD monitor is Off)
Image Storage
Storage Media CompactFlash (CF) Card Type I
Print Order Format Digital Print Order Format (DPOF) Version 1.1
Image Recording Format Still Image: JPEG (Exif 2.2 compliant)
JPEG Compression Mode SuperFine, Fine or Normal
Number of Recording Pixels Still image: Large: 2,272 x 1,704, Medium 1: 1,600 x 1,200, Medium 2: 1,024 x 768, Small: 640 x 480
Movie: 320 x 240 or 160 x 120
Number of Recordable Images
Image data &#160;These figures reflect standard shooting conditions established by Canon.
Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode.
Time of Recordable Movies
Movie data &#160;Above-written figures are measured under Canon's standard conditions and may vary depending on the scene, subjects or camera settings. Total length of movie files recordable on specific CF cards; Individual movie clips are limited to 3 minutes maximum per clip.
Playback Specifications
Playback Modes File Single, Index (9 thumbnail images), Magnification (approx. 2.0x to 10x), Slide Show or Movie
Erasing Specifications
Erase Modes Still images: Single Image, All Images Movie: Part of movie, All of movie
Interfaces
Computer Interface Universal Serial Bus (USB) (mini-B jack)
Video Out NTSC or PAL
Audio Out Monoaural
Power Supply 1. AA-size Batteries (Alkaline, Rechargeable NiMH)(x4)2. Compact Power Adapter (CA-PS500)AA ALKALINE: LCD on - Approx. 250; LCD Off - Approx. 800
AA NIMH: LCD On - Approx. 350; LCD Off - Approx. 1000Approx. 280 minutes (under Canon's standard conditions*2 with full-charged battery)
Power Source 1. AA-size Batteries (Alkaline, Rechargeable NiMH)(x4)2. Compact Power Adapter (CA-PS500)
Shooting Capacity AA ALKALINE: LCD on - Approx. 250; LCD Off - Approx. 800
Playback Time Approx. 280 minutes (under Canon's standard conditions*2 with full-charged battery)
Physical Specifications
Operating Temperature 32 - 104&deg;F (0 - 40&deg;C)
Operating Humidity 10 - 90%
Dimensions (W x H x D) 4.1 x 2.5 x 1.4 in./103.1 x 64.4 x 34.7mm (Excluding protrusions)
Weight Approx. 8.8 oz./250g (camera body only)
Computer System Requirements
Mac Requirements Computer Model: Power Macintosh, PowerBook, iMac, eMac or iBook
OS: OS 9.0 - 9.2 or OSX 10.1 - 10.2.
CPU: PowerPC.
Interface: USB (Models with Apple genuine USB interface only).
PC Requirements Computer Model: IBM PC/AT compatible
OS: Microsoft Windows 98 (including Second Edition)/Me/2000/XP.
CPU: Pentium 150MHz or higher processor (Windows 98/ Me/ 2000), Pentium 300MHz or higher processor (Windows XP).
Interface: USB (Windows 98/Me/2000/XP pre-install model only).
*1 Canon's standard conditions of measuring shooting capacity are as follows: Normal temperature (23 degrees Celsius). LCD viewfinder is ON. Shoot images at wide angle end and at telephoto end alternately with 20 second intervals. Use flash every 4th shot. Turn camera off and on every 8th shot.
*2 Canon's standard conditions of measuring playback time are as follows: Normal temperature (23 degrees Celsius). Repeat playback automatically at a speed of 1 image per 5 seconds.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
