Canon Support for PowerShot D30 | Canon U.S.A., Inc.
PowerShot D30
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type | 12.1 Megapixel, 1/2.3-inch CMOS |
Total Pixels | Approx. 12.8 Megapixels |
Effective Pixels | Approx. 12.1 Megapixels |
Focal Length | 5.0 (W) - 25.0 (T) mm (35mm film equivalent: 28-140mm) |
Digital Zoom | 4.0x |
Focusing Range | Auto: 0.4 in. (1 cm) - infinity (W); 3.3 ft. (1 m) - infinity (T); Macro/Underwater Macro: 0.4 in. - 1.6 ft. (1-50 cm) (W); Normal: 2.0 in. (5 cm) - infinity (W), 3.3 ft. (1 m) - infinity (T); Quick: 9.8 ft. (3 m) (W,T) |
Autofocus System | TTL Autofocus |
Optical Viewfinder | Not available |
LCD Monitor | 3.0-inch TFT Color with wide-viewing angle |
LCD Pixels | Approx. 461,000 dots |
LCD Coverage | Approx. 100% |
Maximum Aperture | f/3.9 (W), f/4.8 (T) |
Shutter Speed | 1-1/1600 sec. 15-1 sec. (Shooting long exposures) |
Sensitivity | Auto, ISO 100-3200 |
Light Metering Method | Evaluative*, Center-weighted average, Spot** * Facial brightness is evaluated in Face Detection AF ** Metering frame is fixed to the center |
Exposure Control Method | Manual Exposure, Program Shift, Safety Shift, AE Lock |
Exposure Compensation | Still Images: ±2 stops in 1/3-stop increments Videos: ±2 stops in 1/3-stop increments (not available during shooting) |
White Balance Control | Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Underwater, Custom * Camera automatically sets the optimal ISO speed according to shooting mode. |
Built-in Flash | Auto, Flash On, Slow Synchro, Flash OffFacial brightness is also evaluated in Face Detect. |
Flash Range | 1.0 ft. - 11 ft. (W), 3.3 - 9.8 ft. (T) (30cm - 3.5m (W), (1.0m - 3.0m (T)) Image brightness may diminish depending on the shooting distance |
Recycling Time | 10 sec. or less (battery voltage: 3.7 V) |
Flash Exposure Compensation | Not available |
Shooting Modes | Auto, P, Movie Digest, Portrait, Smart Shutter*1, Handheld Night Scene, Low Light, Fisheye Effect, Miniature Effect, Toy Camera Effect, Monochrome, Super Vivid, Poster Effect, Color Accent, Color Swap, Underwater, Underwater Macro, Snow, Fireworks, Long Shutter, Stich Assist, iFrame Movie, Super Slow Motion Movie *1 Smile, Wink Self-timer, Face Self-timerShooting movies is possible with the movie button |
Photo Effects | My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin, Darker Skin, Vivid Blue, Vivid Green, Vivid Red, Custom Color* * Adjustment of contrast, sharpness, saturation, red, green, blue and skin tone are available. |
Self Timer | Approx. 10-sec. delay/approx. 2-sec. delay/custom* * Delay time (0-15 sec. (in one-second increments), 20/25/30 sec.) and number of shots (1-10 shots (in one-shot increments)) can be specified. |
Wireless Control | Not Available |
Continuous Shooting | Normal: Approx. 1.9 shots/sec. (in P mode) Normal: Approx. 1.9 shots/sec. (in Low Light mode) Under conditions where the flash does not fire automaticallyDiffers depending on the zoom position. |
Storage Media | SD Memory Card, SDHC Memory Card, SDXC Memory Card |
File Format | Design rule for Camera File system, DPOF (Version 1.1) compliant |
JPEG Compression Mode | Still Image: Exif. 2.3 (JPEG) Video: MOV (Image: MPEG-4 AVC/H.264; Audio: Linear PCM (Monaural)) |
Number of Recording Pixels | Still Images: 1) 16:9 - Large: 4000 x 2248; Medium 1: 2816 x 1584; Medium 2: 1920 x 1080; Small: 640 x 360 2) 3:2 - Large: 4000 x 2664; Medium 1: 2816 x 1880; Medium 2: 1600 x 1064; Small: 640 x 424 3) 4:3 - Large: 4000 x 3000; Medium 1: 2816 x 2112; Medium 2: 1600 x 1200; Small: 640 x 480 4) 1:1 - Large: 2992 x 2992; Medium 1: 2112 x 2112; Medium 2: 1200 x 1200; Small: 480 x 480 * 1984 x 1488 (M) when in Low Light mode. Videos: Full HD 1920 x 1080: 24 fps (23.976) iFrame Movie 1280 x 720: 30 fps (29.97) HD 1280 x 720: 30 fps (29.97) Miniature Effect 1280 x 720*1: 6 fps, 3 fps, 1.5 fps Miniature Effect 640 x 480*1: 6 fps, 3 fps, 1.5 fps Super Slow Motion 640 x 480*1: 120 fps Super Slow Motion 320 x 240*1: 240 fps Digest Movie 640 x 480: 30 fps (29.97) 640 x 480: 30 fps (29.97) *1 Playback: 30 fps (29.97) |
Image data | Note: F=Fine * When in Low Light. • The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly. |
Movie data | *1 Playback frame rate is 30 fps*2. *2 Actual frame rate is 29.97 fps. *3 Actual frame rate is 23.976 fps. |
Playback Modes File | Stills & Videos: Auto Rotate (Automatic vertical/horizontal detection), Image Advance (Transition Effects, Scroll Display), Rotate, Favorites, Smart Shuffle, Group Playback, Slideshow (Repeat, Interval, Effect) Still Images: Single, Index (4-100 thumbnails), Magnification (2-10x), Information Display, Red-eye Correction, i-Contrast, Resize, My Colors, Histogram, Overexposure Warning Videos: Normal Playback*1, Skip Backward*2, Previous Frame*3, Next Frame*3, Skip Forward*2 Displays playback position and shooting time *1 Audio settings available in 5 levels *2 Approximately 4 seconds *3 Slow motion available |
Erase Modes | Select Image, Select Range, Select All Images The image data in the memory card stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased). Using the Movie editing function, sections of the movie can be deleted. |
Video Out | Analog: NTSC or PAL, Digital: HDMI (HDMI™ mini connector) |
Audio Out | Monaural (dedicated connector (female) with unified type of digital, audio and video) |
Other | SD memory card slot; direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers |
Power Source | Battery Pack NB-6L/NB-6LH, AC Adapter Kit ACK-40 |
Shooting Capacity | Approx. 300 shots |
Playback Time | Approx. 6 hours |
Operating Temperature | 14-104°F/10-40°C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 4.31 x 2.68 x 1.08 in. / 109.4 x 68.0 x 27.5mm |
Weight | 7.69 oz. / 218g (CIPA standard) 6.84 oz. / 194g (Body only)Note: 30 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi, Hindi, Malaysian, Indonesian, and Vietnamese).All data are based on Canon's Standard Test Method. Subject to change without notice.Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
