Canon Support for PowerShot ELPH 510 HS | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 08.30.11
File Size 8.48 MB
Date 08.30.11
File Size 8.92 MB
Date 08.30.11
File Size 10.57 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
12.1 Megapixel, 1/2.3-inch CMOS
Total Pixels
Approx. 12.8 Megapixels
Effective Pixels
Approx. 12.1 Megapixels
Focal Length
5.0 (W) - 60.0 (T) mm (35mm film equivalent: 28 (W) - 336 (T) mm)
Digital Zoom
Approx. 4.0x (Up to approx. 48x in combinations with the optical zoom)
Focusing Range
Auto: 0.4 in. (1 cm) - infinity (W), 3.3 ft. (1 m) - infinity (T)
Normal AF: 2.0 in. (5cm) - infinity (W), 3.3 ft. (1m) - infinity (T)
Macro AF: 0.4 in. - 1.6 ft. (1-50cm) (W)
Autofocus System
TTL Autofocus
Optical Viewfinder
N/A
LCD Monitor
3.2-inch wide TFT Color Touch Panel LCD with wide viewing angle
LCD Pixels
Approx. 461,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/3.4 (W) - f/5.9 (T)
Shutter Speed
1-1/4000 sec.
15-1/4000 sec. (Total shutter speed range)
Sensitivity
Auto, ISO 100/200/400/800/1600/3200 (in P mode)
Light Metering Method
Evaluative, Center weighted average, Spot
Exposure Control Method
AE Lock
Exposure Compensation
+/-2 stops in 1/3-stop increments
White Balance Control
Auto, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
Built-in Flash
Auto, Flash On, Slow Synchro, Flash Off
Facial brightness is also evaluated in Face Detect
Flash Range
12 in. - 10.2 ft. (30 cm-3.1 m) (W), 3.3 - 5.6 ft. (1.0 - 1.7 m) (T)
Recycling Time
10 sec. or less (battery voltage: 3.7 V)
Flash Exposure Compensation
N/A
Shooting Modes
Auto*1, P, Movie Digest, Portrait, Kids & Pets, Smart Shutter*2, High-Speed Burst, Best Image Selection, Handheld Night Scene, Low Light, Fish-eye Effect, Miniature Effect, Toy Camera Effect, Monochrome, Super Vivid, Poster Effect, Color Accent, Color Swap, Beach, Foliage, Snow, Fireworks, Long Shutter, iFrame Movie, Super Slow Motion Movie*1 Scenes are automatically determined (Smart AUTO)
*2 Smile, Wink Self-timer, Face Self-timer
Photo Effects
My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin, Darker Skin, Vivid Blue, Vivid Green, Vivid Red, Custom Color**Adjustment of contrast, sharpness, saturation, red, green, blue and skin tone are available
Self Timer
Approx. 10-sec. delay, Approx. 2-sec. delay, custom*
*Delay time (0-15sec. (in one-second increments), 20/25/30 sec.) and number of shots (1-10 shots (in one-shot increments)) can be specified)
Wireless Control
N/A
Continuous Shooting
Normal:
Approx. 3.3 shots/sec. (in P Mode)
Approx. 7.8 shots/sec. (in High-speed Burst mode)AF:
Approx. 0.8 shots/sec. (in P mode)
Approx. 1.2 shots/sec. (in Low Light mode)LV:
Approx. 0.9 shots/sec. (in P Mode)Under conditions where the flash does not fire automaticallyDiffers depending on the zoom position
Storage Media
SD Memory Card, SDHC memory Card, SDXC Memory Card , Eye-Fi
File Format
Design rule for camera file system, DPOF Version 1.1 compliant
Image Recording Format
Normal, Fine
JPEG Compression Mode
Still Image: Exif 2.3 (JPEG)
Video: MOV (Image: H.264; Audio: Linear PCM (stereo))
Number of Recording Pixels
[16:9]
Large: 4000 x 2248
Medium 1: 2816 x 1584
Medium 2: 1920 x 1080
Small: 640 x 360
[3:2]
Large: 4000 x 2664
Medium 1: 2816 x 1880
Medium 2: 1600 x 1064
Small: 640 x 424[4:3]
Large: 4000 x 3000
Medium 1: 2816 x 2112
Medium 2: 1600 x 1200
Small: 640 x 480[1:1]
Large: 2992 x 2992
Medium 1: 2112 x 2112
Medium 2: 1200 x 1200
Small: 480 x 480
Image data
* When in High-speed Burst, Best Image Selection or Low Light
The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly.
Movie data
*Shooting: 120 fps; Playback: 30 fpsThe approximate recording time on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly.
Playback Modes File
Still Images & Video:
Auto Rotate, Transition Effects, Scroll Display, Active Display, Rotate, Favorites, My Category, Smart Shuffle, Group Playback, Movie Digest, Filtered Playback, SlideshowStill Images:
Single, Index (6-130 thumbnails), Magnification (2x-10x), Information Display, Red-eye Correction, i-Contrast, Trimming, Resize, My Colors, Focus Check, Histogram, Overexposure WarningVideos:
Normal Playback*1, Slow Motion*2, Skip Backward*3, Previous Frame*4, Next Frame*4, Skip forward*3Displays playback position and shooting time
Using the software included with the camera (ZoomBrowser EX/ImageBrowser), there are 8 levels (1/8x to 1x) of playback speed possible on a computer*1Audio settings available in 5 levels
*25 levels (including normal playback), sound not available
*3Approximately 4 seconds
*4Rewind and Fast-forward are also available
Erase Modes
Select image, select range, all images (all filtered images)The image data in the memory card stored with the design rule for camera file systems format can be erased (however, protected images cannot be erased).
Computer Interface
USB 2.0 Hi-Speed USB (dedicated female connector with unified type of digital, audio and video) mini-B compatible.
Video Out
NTSC/PAL (dedicated connector (female) with unified type of digital, audio and video)
Mini-HDMI connector
Audio Out
Stereo (dedicated connector (female) unified type of digital, audio, and video)
Other
Memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-speed cable
Power Source
Battery Pack NB-9L, Compact Power Adapter CA-DC10 (included with AC Adapter Kit ACK-DC70)
Shooting Capacity
Approx. 170 shots
Playback Time
Approx. 4 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
3.90 x 2.32. x 0.86 in / 99.0 x 58.9 x 21.9 mm
Weight
Approx. 7.27 oz / 206 g (Including battery and memory card)
Approx. 6.46 oz / 183 g (camera body only)Note: 27 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi, and Hindi).
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: PowerShot ELPH 510 HS: Firmware Update Version 1.0.1.0
Advisory Type
Date 02.18.14
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
