Canon Support for PowerShot ELPH 530 HS | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
10.1 Megapixel, 1/2.3-inch CMOS
Total Pixels
Approx. 16.8 Megapixels
Effective Pixels
Approx. 10.1 Megapixels
Focal Length
4.0 (W) - 48.0mm (T) (35mm film equivalent: 28 - 336mm)
Optical Zoom
12x
Digital Zoom
Approx. 4x
Focusing Range
Normal: 2.0 in. (5cm) - infinity (W), 3.3 ft. (1m) - infinity (T)
Auto: 0.4 in. (1cm) - infinity (W), 3.3 ft. (1m) - infinity (T)
Macro: 0.4 in. - 1.6 ft. (1-50cm) (W)
Autofocus System
TTL Autofocus
Optical Viewfinder
N/A
LCD Monitor
3.2-inch TFT Touch Panel Color LCD with wide viewing angle
LCD Pixels
Approx. 461,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/3.4 (W) - f/5.6 (T)
Shutter Speed
1-1/4000 sec.
15-1/4000 sec. (Total shutter speed range)
Sensitivity
Auto*, ISO 100/200/400/800/1600/3200 (in P mode)
*Camera automatically sets the optimal ISO speed according to shooting mode
Light Metering Method
Evaluative*, Center weighted average, Spot**
* Facial brightness is evaluated in Face AiAF.
** Fixed to center.
Exposure Control Method
AE Lock
Exposure Compensation
+/-2 stops in 1/3-stop increments (not available when shooting movies)
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
* Facial color is evaluated in Face Detect (Face Detect WB)
- Adjusts the white balance separately for the main subject and the background when the flash fires.
Built-in Flash
Auto, Flash On, Slow Synchro, Flash Off
- Facial brightness is also evaluated in Face Detect.
Flash Range
1.6 - 8.2 ft. (W), 3.3 - 4.9 ft. (T), (50cm - 2.5m (W), 1.0 - 1.5m (T))
* Image brightness may diminish depending on the shooting distance
Recycling Time
10 sec. or less (battery voltage: 3.7V)
Flash Exposure Compensation
N/A
Shooting Modes
Auto*1, P, Movie Digest, Portrait, Smooth Skin, Smart Shutter*2, High-Speed Burst, Handheld Night Scene, Low Light, Fisheye Effect, Miniature Effect, Toy Camera Effect, Soft Focus, Monochrome, Super Vivid, Poster Effect, Color Accent, Color Swap, Snow, Fireworks, Long Shutter, iFrame Movie, Super Slow Motion Movie
- Shooting movies is possible with the movie button
*1 Smart Auto also available for movies
*2 Smile, Wink Self-timer, Face Self-timer
Photo Effects
My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin, Darker Skin, Vivid Blue, Vivid Green, Vivid Red, Custom Color*
*Adjustment of contrast, sharpness, saturation, red, green, blue and skin tone are available
Self Timer
Approx. 10-sec. delay/approx. 2-sec. delay/custom*
*Delay time (0 - 15 sec. (in one-second increments), 20/25/30 sec.) and number of shots (1-10 shots (in one-shot increments)) can be specified.
Wireless Control
N/A
Continuous Shooting
Normal:
Approx. 2.6 shots/sec. (in P mode)
Approx. 6.1 shots/sec. (in High-Speed Burst mode)
AF:
Approx. 0.8 shots/sec. (in P mode)
Approx. 0.8 shots/sec. (in Low Light mode)
LV:
- Under conditions where the flash does not fire automatically.
- Differs according to zoom position.
Storage Media
microSD memory card, microSDHC memory card, microSDXC memory card
File Format
Design rule for camera file system, DPOF Version 1.1 compliant
Image Recording Format
Superfine, Fine
JPEG Compression Mode
Still Image: Exif 2.3 (JPEG)
Video: MOV (Image: H.264; Audio: Linear PCM (2-channel Stereo))
Number of Recording Pixels
Still Images:
[16:9]
Large: 3648 x 2048, Medium 1: 2816 x 1584
Medium 2: 1920 x 1080, Small: 640 x 360
[3:2]
Large: 3648 x 2423, Medium 1: 2816 x 1880
Medium 2: 1600 x 1064, Small: 640 x 424
[4:3]
Large: 3648 x 2736, Medium 1: 2816 x 2112
Medium 2: 1600 x 1200, Small: 640 x 480
[1:1]
Large: 2736 x 2736, Medium 1: 2112 x 2112
Medium 2: 1200 x 1200, Small: 480 x 480
Video:
[iFrame Movie]
1280 x 720 (30 fps*1)
[Super Slow Motion Movie]
640 x 480*2, 320 x 240*3
[Miniature Effect]
1280 x 720*4, 640 x 480*4
[Other than the above]
1920 x 1080 (24 fps*5), 1280 x 720 (30 fps*1), 640 x 480 (30 fps*1)
*1 Actual frame rate is 29.97 fps.
*2 Shooting: 120 fps., Playback: 30 fps*1
*3 Shooting: 240 fps., Playback: 30 fps*1
*4 Shooting: 6 fps, 3 fps, 1.5 fps Playback: 30 fps*1
*5 Actual frame rate is 23.976 fps.
Image data
*When in High-speed Burst or Low Light.
The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly.
Movie data
Playback Modes File
Stills & Videos:
Auto Rotate (Automatic vertical/horizontal detection), Image Advance (Operation Tools, Transition Effects, Scroll Display, Active Display), Rotate, Favorites, My Category, Smart Shuffle, Group Playback, Image Search, Movie Digest, Slideshow (Playback Interval, Repeat, Effect, Playlist)
Still Images:
Single, Index (6-130 thumbnails), Magnification (4-10x), Information Display, Red-eye Correction, i-Contrast, Trimming, Resize, My Colors, Focus Check, Histogram, Overexposure Warning
Videos:
Normal Playback*1, Skip Backward*2, Previous Frame*3, Next Frame*3, Skip Forward*2
- Displays playback position and shooting time
Using the software included with the camera (ImageBrowser EX), there are 8 levels (1/8x to 1x) of playback speed for Super Slow Motion Movies possible on a computer.
*1 Audio settings available in 5 levels
*2 Approximately 4 seconds
*3 Slow motion available
Erase Modes
Select*1, Select Range, Select All Images*2
- The image data in the memory card stored with the design rule for camera file systems format can be erased (however, protected images cannot be erased).
*1 Movies can be erased individually.
*2 When images have been selected in image search, only those images will be erased.
Computer Interface
Hi-Speed USB (Dedicated connector (female) with unified type of digital, audio and video
Video Out
NTSC/PAL (dedicated connector (female) with unified type of digital, audio and video)
Audio Out
2-channel Stereo (dedicated connector (female) unified type of digital, audio, and video)
Other
Mini-HDMI cable: connection to high definition monitor; microSD memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-speed cable
Power Source
Battery Pack NB-9L, Compact Power Adapter CA-DC10 (included with AC Adapter Kit ACK-DC70
Shooting Capacity
Approx. 190 shots
Playback Time
Approx. 3 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
3.38 x 2.11 x 0.78 in. / 85.8 x 53.5 x 19.8mm
Weight
5.75 oz. / 163g (including the batteries and memory card)
5.01 oz. / 142g (camera only)Note: 30 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi, Hindi, Malaysian, Indonesian, and Vietnamese).
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
