Canon Support for PowerShot ELPH110 HS | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
Software Development Kit
SELECT ERROR CODE
Type | 16.1 Megapixel, 1/2.3-inch CMOS |
Total Pixels | Approx. 16.8 Megapixels |
Effective Pixels | Approx. 16.1 Megapixels |
Focal Length | 4.3 (W) - 21.5mm (T) (35mm film equivalent: 24 (W) - 120mm (T)) |
Optical Zoom | 5x |
Digital Zoom | 4x |
Focusing Range | Auto: 1.2 in. (3cm) - infinity (W), 3.0 ft. (90cm) - infinity (T) Normal: 2.0 in. (5cm) - infinity (W), 3.0 ft. (90cm) - infinity (T) Macro: 1.2 in. - 1.6 ft. (W), 3-50cm (W) |
Autofocus System | TTL Autofocus |
Optical Viewfinder | N/A |
LCD Monitor | 3.0-inch TFT Color with wide-viewing angle |
LCD Pixels | Approx. 461,000 dots |
LCD Coverage | Approx. 100% |
Maximum Aperture | f/2.7 (W)-f/5.9 (T) |
Shutter Speed | 1-1/2000 sec. 15-1/2000 sec. (Total shutter speed range) |
Sensitivity | Auto, ISO 100/200/400/800/1600/3200 |
Light Metering Method | Evaluative*, Center weighted average, Spot** * Facial brightness is evaluated in Face AiAF.** Fixed to center. |
Exposure Control Method | AE Lock |
Exposure Compensation | +/-2 stops in 1/3-stop increments |
White Balance Control | Auto, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom |
Built-in Flash | Auto, On, Slow Synchro, Off |
Flash Range | 1.6 - 11 ft. (W), 3.0 - 6.6 ft. (T) (50cm - 3.5m (W), 90cm - 2.0m (T)) |
Recycling Time | 10 sec. or less (battery voltage: 3.6 V) |
Flash Exposure Compensation | N/A |
Shooting Modes | Auto*1, P, Movie Digest, Portrait, Smooth Skin, Smart Shutter*2, High-speed Burst, Handheld Night Scene, Low Light, Fish-eye Effect, Miniature Effect, Toy Camera Effect, Soft Focus, Monochrome, Super Vivid, Poster Effect, Color Accent, Color Swap, Underwater, Snow, Long Shutter, Stitch Assist, iFrame Movie, Super Slow Motion Movie - Shooting movies are possible with the movie button *1 Smart Auto also available for movies *2 Smile, Wink Self-timer, Face Self-timer |
Photo Effects | My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin, Darker Skin, Vivid Blue, Vivid Green, Vivid Red, Custom Color* *Adjustment of contrast, sharpness, saturation, red, green, blue and skin tone are available |
Self Timer | Approx. 10-sec. delay/approx. 2-sec. delay/custom* *Delay time (0-15 sec. (in one-second increments), 20/25/30 sec.) and number of shots (1-10 shots (in one-shot increments)) can be specified. |
Wireless Control | N/A |
Continuous Shooting | Approx. 2.0 shots/sec. (in P Mode) Approx. 5.8 shots/sec. (in High-Speed Burst mode) * Under conditions where the flash does not fire automatically |
Storage Media | SD Memory Card, SDHC Memory Card, SDXC Memory Card |
File Format | Design rule for Camera File system, DPOF (Version 1.1) compliant |
Image Recording Format | Normal, Fine |
JPEG Compression Mode | Still Image: Exif 2.3 (JPEG) Video: MOV (Image: H.264; Audio data; Linear PCM (2 channel monaural)) |
Number of Recording Pixels | Still Images:[16:9]Large: 4608 x 2592, Medium 1: 3264 x 1832,Medium 2: 1920 x 1080, Small: 640 x 360 [3:2]Large: 4608 x 3072, Medium 1: 3264 x 2176,Medium 2: 1600 x 1064, Small: 640 x 424 [4:3]Large: 4608 x 3456, Medium 1: 3264 x 2448,Medium 2: 1600 x 1200, Small: 640 x 480 [1:1]Large: 3456 x 3456, Medium 1: 2448 x 2448,Medium 2: 1200 x 1200, Small: 480 x 480 Video:[iFrame Movie]1280 x 720 (30 fps*1) [Super Slow Motion Movie]640 x 480*2, 320 x 240*3 [Miniature Effect]1280 x 720*4, 640 x 480*4 [Other than the above]1920 x 1080 (24 fps*5), 1280 x 720 (30 fps*1), 640 x 480 (30 fps*1) *1 Actual frame rate is 29.97 fps.*2 Shooting: 120 fps., Playback: 30 fps*1*3 Shooting: 240 fps., Playback: 30 fps*1*4 Shooting: 6 fps, 3 fps, 1.5 fps Playback: 30 fps*1*5 Actual frame rate is 23.976 fps |
Image data | *When in High-Speed Burst or Low Light.*The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly. |
Movie data | *1 Actual frame rate is 29.97 fps *2 Playback frame rate is 30 fps *3 Actual frame rate is 23.976 fps *The approximate recording time on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly. |
Playback Modes File | - Stills & Videos: Auto Rotate (Automatic vertical/horizontal detection), Image Advance (Operation Tools, Transition effects, Scroll Display), Rotate, Favorites, My Category, Smart Shuffle, Filtered Playback, Slide Show (Playback Interval, Repeat, Effect, Playlist) - Still Images: Single, Index (4-100 thumbnails), Magnification (2-10x), Information Display, Red-eye Correction, i-Contrast, Trimming, Resize, My Colors, Focus Check, Histogram, Overexposure Warning - Videos: Normal Playback*, Slow Motion**, Special Playback, Editing, Resume *Auto settings available in 5 levels** 5 levels (including normal playback), sound not available. |
Erase Modes | Select image, select range, all images (all filtered images) - The image data in the memory card stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased). - Using the Movie editing function, sections of the movie (1 sec. increments) can be deleted.- Using the Movie editing function, beginning/end sections of the movie (1 sec. increments) can be deleted. |
Video Out | NTSC/PAL (Dedicated connector (female) with unified type of digital, audio and video)Mini-HDMI connector |
Audio Out | Monaural (Dedicated connector (female) unified type of digital, audio, and video) |
Other | Mini-HDMI cable: connection to high definition monitor; SD Memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-speed cable |
Power Source | 1) Rechargeable lithium-ion Battery Pack NB-11L 2) Compact Power Adapter CA-DC10 (included with AC Adapter Kit ACK-DC90 |
Shooting Capacity | Approx. 170 shots |
Playback Time | Approx. 3 hours |
Operating Temperature | 32-104°F/0-40°C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 3.67 x 2.24 x 0.79 in. (93.2 x 57.0 x 20.0mm) |
Weight | Approx. 4.76 oz. (135g) (Including the battery and memory card) Approx. 4.23 oz. (120g) (Camera only)30 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi, Hindi, Malaysian, Indonesian, and Vietnamese).All data are based on Canon's Standard Test Method. Subject to change without notice.Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
