Canon Support for PowerShot G1 X Mark III | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
Type
Digital camera with built-in flash, 3x Optical, 4x Digital and 12x Combined Zoom with Optical Image Stabilizer
Type
24.2 Megapixel*, APS-C CMOS (sensor aspect ratio 3:2)
* Image processing may cause a decrease in the number of pixels.
Total Pixels
Approx. 25.8 megapixels
Effective Pixels
Approx. 24.2 megapixels
Focal Length
15.0 (W) - 45.0 (T) mm (35mm film equivalent: 24-72mm)
Optical Zoom
3x
Digital Zoom
4x
Focusing Range
Normal/Auto: 3.9 in. (10cm) - infinity (W), 11.8 in. (30cm) - infinity (T)
Macro/Underwater Macro: 3.9 in. - 1.6 ft. (10-50 cm) (W)
Autofocus System
TTL Autofocus, Manual Focus
Optical Viewfinder
Built-in electronic color viewfinder with 0.39-type screen size and approx. 2.36 million dots
LCD Monitor
3.0" TFT color liquid crystal type Vari-angle with electrostatic capacitance touchscreen panel
LCD Pixels
Approx. 1.04 million dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/2.8 (W), f/5.6 (T)
Shutter Speed
1-1/2000 sec. (in Auto mode)
301/2000 sec. (in all shooting modes)
BULB (in M mode only)
1/8 minimum in Manual Movie Mode
Sensitivity
ISO 100-3200 (in Auto mode)
Max. ISO Speed in P mode is ISO 25600
Light Metering Method
Evaluative, Center Weighted Average, Spot
Exposure Control Method
Manual Exposure, Program Shift, AE Lock, AE Bracketing
Exposure Compensation
&plusmn;3 stops in 1/3-stop increments
White Balance Control
Auto, Day Light, Shade, Cloudy, Tungsten, Fluorescent, Flash, Underwater WB, Color Temperature
Built-in Flash
Manual Pop-up Flash (Auto, On, Slow Synchro, Off)
Flash Range
1.6 ft. (50cm) - 29.5 ft. (9.0m) (W), 1.6 ft. (50cm) - 14.8 ft. (4.5m) (T)
Flash Exposure Compensation
&plusmn;2 stops in 1/3 increments
Picture Style
Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Def. 1-3
Self Timer
Off, 2 sec., 10 sec., Custom
Wireless Control
Wi-Fi&reg; / NFC / Bluetooth&reg;
JPEG Compression Mode
Still Image: Exif. 2.3 (JPEG), RAW (Canon original: 14-bit, CR2)
Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC (Stereo))
Storage Media
SD/SDHC/SDXC and UHS-I Memory Cards
File Format
Design rule for Camera File system (DCF) compliant; DPOF (Version 1.1) compatible
Image Recording Format
Fine/Normal
Number of Recording Pixels
Approx. Number of Shots per a Canon Metric 16GB SD Card
Audio Out
Stereo
Wired
Hi-Speed USB (Micro USB), HDMI (Type D)
Wireless
Wi-Fi&reg;*
Specifications: IEEE 802. 11b/g/n
Frequency: 2.4 GHz
Channels: 1-11
Security: WEP, WPA-PSK (AES/TKIP), WPA2-PSK (AES/TKIP)
NFC**
Bluetooth&reg;***
Version: Ver. 4.0
* Compatible with iOS&reg; versions 9.3/10.3, Android&trade; smartphone and tablet versions 4.4/5.0/5.1/6.0/7.0/7.1. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
** Compatible with Android&trade; smartphone and tablet versions 4.4/5.0/5.1/6.0/7.0/7.1.
*** Compatible with select smartphone and tablet devices (Android&trade; version 5.0 or later and the following iOS&reg; devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen. or later) equipped with Bluetooth&reg; version 4.0 or later and the Camera Connect App Ver. 2.1.30. This application is not guaranteed to operate on all listed devices, even if minimum requirements are met.
Other
Direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers
Power Source
Battery Pack NB-13L, Battery Charger CB-2LH
Shooting Capacity
Approx. 200 shots with Screen On (CIPA compliant)
Approx. 250 shots with ECO Mode
Playback Time
Approx. 4 hrs.
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
Approx. 4.5 x 3.1 x 2.0 in. / 115.0 x 77.9 x 51.4mm
Weight
Approx. 14.1 oz. / 399g (including battery and memory card)
Approx. 13.2 oz. / 375g (camera body only)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: Picture Style File Registration
Advisory Type
Date 12.15.19
Title Firmware Notice: PowerShot G1X Mark III: Firmware Version 1.1.0.0
Advisory Type Firmware Notice
Date 05.18.23
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
