Canon Support for PowerShot G11 | Canon U.S.A., Inc.
PowerShot G11
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.05.10
File Size 6.07 MB
Date 03.05.10
File Size 6.23 MB
Date 11.12.09
File Size 5.66 MB
Date 08.20.09
File Size 6.05 MB
Date 11.12.09
File Size 6.94 MB
Date 04.02.25
File Size 142.00 B
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
1/1.7-inch type Charge Coupled Device (CCD)
Total Pixels
Approx. 10.4 Megapixels
Effective Pixels
Approx. 10.0 Megapixels
Focal Length
6.1 (W) - 30.5mm (35mm film equivalent: 28 (W) - 140 (T) mm)
Digital Zoom
5x
Focusing Range
Normal: 1.6 ft./50cm-infinity
Macro: 0.4 in.-1.6 ft./1-50cm
Autofocus System
TTL Autofocus
Optical Viewfinder
Real-image optical zoom viewfinder
LCD Monitor
2.8-inch TFT color, with wide viewing angle
LCD Pixels
Approx. 461,000 pixels
LCD Coverage
100%
Maximum Aperture
f/2.8 (W) - f/4.5 (T)
Shutter Speed
15-1/4000 sec. (Total shutter speed range; settable in Tv and M)
Sensitivity
Auto*, ISO 80/100/200/400/800/1600/3200 (Standard output sensitivity. Recommended exposure index. *Camera automatically sets the optimal ISO speed according to shooting mode and subject brightness. The ISO speed also varies according to subject movement and camera shake when the shooting mode is set to Auto.)
Light Metering Method
Evaluative*1, Center-weighted average, spot*2
*1 Facial brightness is also evaluated in Face Detect AiAF.
*2 Fixed to center or linked to the AF frame.
Exposure Control Method
Program AE, Shutter Speed-Priority AE, Aperture-Priority AE, i-Contrast, Manual; AE Lock, Safety Shift, Auto ISO Shift
Exposure Compensation
+/-2 stops in 1/3-stop increments
Shooting standby only (Movies)
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash, Underwater, Custom1, Custom2
*The color of faces is evaluated in Face AiAF
Built-in Flash
Auto, Auto w/Red-eye Reduction, Flash On, Flash On w/Red-eye Reduction, Flash Off; FE lock, Safety FE, Slow Synchro, Second-curtain synchro
Flash Range
1.6 ft.-23 ft./50 cm-7 m (W), 1.6-13 ft./50cm-4.0m (T)
Recycling Time
10 sec. or less (battery voltage: 7.4V)
Flash Exposure Compensation
Shooting Modes
Auto*1, P, Tv, Av, M, C1, C2, Low Light, Quick Shot, SCN*2, Movie
*1 Optimum image processing for each scene.*2 Portrait, Landscape, Night Snapshot, Kids & Pets, Indoor, Sports, Sunset, Night Scene, Fireworks, Beach, Underwater, Aquarium, Foliage, Snow, Color Accent, Color Swap, Stitch Assist
Photo Effects
My Colors
My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Vivid Blue, Vivid Green, Vivid Red, Custom*
*Adjustment of contrast, sharpness, saturation, red, green, blue and skin tone are available.Saving original image is not available.Not available with RAW setting.
Self Timer
Approx. 10-sec. delay/approx. 2-sec. delay/ Custom*1/Face Self-Timer*2
*1 Shooting start time (0-10 sec. (in one-second increments)) can be specified.
*2 When the number of detected faces increases, the shutter is released after 2 sec. delay. However, if no face is detected for 30 seconds or more, the shooting operation starts automatically.
Wireless Control
Not available
Continuous Shooting
Normal: approx. 1.1 fps; AF: approx. 0.7 fps; LV: approx. 0.8 fps (Large/Fine)
Storage Media
SD/SDHC Memory Card, MultiMediaCard, MMCplus card, HC MMCplus card
File Format
Design rule for Camera File system, DPOF (Version 1.1) compliant
Image Recording Format
Normal, Fine, RAW
JPEG Compression Mode
Still Image: Exif 2.2 (JPEG) RAW (CR2 Canon Original))
Movie: MOV (Image: H.264; Audio data: Linear PCM (monaural))Not compatible with AVI
Number of Recording Pixels
Still Image: 3,648 x 2,736 (Large); 2,816 x 2112 (Medium 1); 2,272 x 1,704 (Medium 2); 1,600 x 1,200 (Medium 3); 640 x 480 (Small); 3,648 x 2,048 (Wide); 3,648 x 2,736 (RAW); 1,824 x 1,368 (Medium*)
* Low Light mode
Image data
Movie data
Note: N=Normal F=Fine SF=SuperFine
Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media.
Playback Modes File
Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotate, Resume, My Colors, My Category, Transition Effects, Histogram, Overexposure Warning, Index (4-130 thumbnails can be selected), Slide Show, Red-eye Correction, RAW playback, Trimming, Resize, Image Inspection Tool, i-ContrastMovie: Normal Playback, Special Playback, Editing, Auto Rotate, Resume
Erase Modes
Still Image: single image, select range, select by date, select by category, select by folder, all images
Movie: part of movie, all of movie
Computer Interface
USB 2.0 Hi-Speed (mini-B jack)
Video Out
NTSC/PAL (dedicated connector (female) with unified type of digital, audio and video)
Audio Out
Monaural (dedicated connector (female) with unified type of digital, audio and video)
Other
SD Memory card slot; direct connection to Canon CP and SELPHY Compact Photo Printers, PIXMA Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Supply
1.Rechargeable Lithium-ion Battery NB-7L
2.AC Adapter Kit ACK-DC50Still Image: approx. 390 shots (NB-7L/LCD on)*, approx. 1,000 shots (NB-7L/LCD off)Approx. 420 min. (NB-7L) * LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used.
Power Source
Shooting Capacity
Playback Time
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
4.41 x 3.00 x 1.90 in./112.1 x 76.2 x 48.3mm
Weight
Approx. 12.5 oz./355g (camera body only)26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi)
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
