Canon Support for PowerShot G3 | Canon U.S.A., Inc.
PowerShot G3
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.05.10
File Size 6.07 MB
Date 04.01.07
File Size 2.78 MB
Date 11.14.07
File Size 354.77 MB
Date 03.05.10
File Size 6.23 MB
Date 11.14.07
File Size 685.69 MB
Date 04.01.07
File Size 2.68 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type of Camera
Type Compact Digital Still Camera with Built-in Flash and 4x Optical Zoom Lens. Lens and Flash accessories available.
Image Capture Device
Type 1/1.8-inch Charge-Coupled Device (CCD)
Total Pixels Approx. 4.1 million
Effective Pixels Approx. 4 million
Lens
Focal Length 7.2 - 28.8mm (35mm film equivalent: 34 - 140mm)
Digital Zoom 3.6x (Maximum 14x digital zoom is available when combined with optical zoom.)
Focusing Range Normal AF: 50cm (1.6 ft.) - infinity
Macro AF: 5cm (0.2 ft.) (wide-angle)/ 15cm (0.5 ft.) (telephoto) - 50cm (1.6 ft.)
Manual focus: 5cm (0.2 ft.) (wide-angle)/15cm (0.5 ft.) (telephoto) - infinity
Autofocus System Center AF Point or Flexi Zone AF: user can move AF Point freely around most of picture area
AF lock and Manual focus are available.
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 1.8-inch low-temperature polycrystalline silicon TFT color LCD
LCD Pixels 113,578 dots (521 (H) x 218 (V))
LCD Coverage Approx. 97%
Aperture and Shutter
Maximum Aperture f/2.0 - f/3.0
Shutter Speed 15 - 1/2,000 sec.
Slow shutter of 1.3 sec. and more operates with noise reduction.
Exposure Control
Sensitivity Auto/ISO 50/100/200/400 equivalent.
Light Metering Method Evaluation metering, Center-weighted average metering or Spot metering.
Exposure Control Method Program AE, Shutter priority AE, Aperture priority AE or Manual exposure control; AE lock is available.
Exposure Compensation +/- 2.0EV in 1/3-stop increments.
Auto Exposure Bracketing (AEB) is available.
White Balance
White Balance Control TTL Auto White Balance, Pre-set White Balance (available settings: Daylight, Cloudy, Tungsten, Fluorescent , Fluorescent H or Flash) or Custom White Balance. (read off white objector 18% gray card)
Flash
Built-in Flash Operation modes: Auto/ON/OFF, Red-Eye Reduction Auto, Red-Eye Reduction ON, flash ON or OFF
Flash Range WIDE: 0.7-4.5m (2.3-14.7 ft)
TELE: 0.7-3.6m (2.3-11.8 ft)(When sensitivity is set to ISO 100 equivalent)
Recycling Time Approx. 10 sec. or shorter.
Terminals for External Flash Sync-terminals at accessory shoe.
Automatic E-TTL Flash is possible with EX-Series Speedlites: Canon Speedlite 220EX, 380EX, 420EX, 550EX, and Macro Ring Lite MR-14EX and Macro Twin Lite MT-24EX.
Flash Exposure Compensation +/- 2.0EV (at every 1/3-stop)
Shooting Specifications
Shooting Modes Creative zone: Program, Shutter priority, Aperture priority and Manual Image zone: Pan-focus, Portrait, Landscape, Night Scene, Photo Effect (Black & White, Sepia, Neutral Color, Vivid Color), Stitch Assist and Movie
Self Timer Operates with approx. 10 seconds countdown.
Wireless Control Shooting and playback are available. Computer-connected Shooting Available (Using included "Remote Computer" software. Required USB connection to compatible computer).
Continuous Shooting High Speed: Approx. 2.5 images/sec., Normal: Approx. 1.5 images/sec.(at Large/Fine mode and LCD viewfinder is OFF)
Image Storage
Storage Media CompactFlash (CF) card (Type I or Type II)
File Format Design rule for Camera File system (DCF*1)
Print Order Format Digital Print Order Format (DPOF) Version 1.1
Image Recording Format Still image: JPEG or CCD-RAW Movie: AVI (Image data: Motion JPEG, Audio data: WAVE [monaural])
JPEG Compression Mode Super Fine, Fine or Normal
Number of Recording Pixels Still image: Large: 2,272 x 1,704, Medium High: 1,600 x 1,200, Medium Low: 1,024 x 768, Small: 640 x 480Movie: 320 x 240 or 160 x 120
Number of Recordable Images
Image data These figures reflect standard shooting conditions established by Canon.
Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode.
Time of Recordable Movies
Movie data Above-written figures are measured under Canon's standard conditions and may vary depending on the scene, subjects or camera settings. Total length of movie files recordable on specific CF cards; Individual movie clips are limited to 3 minutes maximum per clip.
Playback Specifications
Playback Modes File Single, Index (9 thumbnail images), Magnification (approx. 2.5x or 5x on built-in LCD monitor) or Slide Show
Erasing Specifications
Erase Modes Single Image, All Images
Interfaces
Computer Interface Universal Serial Bus (USB) v1.1
Video Out Audio/Video Output (NTSC or PAL selectable, monaural audio)
Other CF card slot (accept type I and type II cards). Direct connection to Canon CP Printers and BJ Direct Photo printers (no computer required).
Power Supply 1. Rechargeable Lithium-ion battery (type: BP-511 or BP-512).
2. AC adapter (type: CA-560)
3. Car battery adapter (type: CR-560) (option)Approx. 400 images (under Canon's standard conditions*2 with full-charged battery)Approx. 300 minutes (under Canon's standard conditions*3 with full-charged battery)
Power Source 1. Rechargeable Lithium-ion battery (type: BP-511 or BP-512).
Shooting Capacity Approx. 400 images (under Canon's standard conditions*2 with full-charged battery)
Playback Time Approx. 300 minutes (under Canon's standard conditions*3 with full-charged battery)
Physical Specifications
Operating Temperature 32-104&deg;F (0-40&deg;C)
Operating Humidity 10-90%
Dimensions (W x H x D) 4.8 x 3.0 x 2.5 in. /121 x 73.9 x 69.9mm (excluding protruding parts)
Weight Approx. 14.8 oz./410g (camera body only)
Computer System Requirements
Mac Requirements Hardware: Power Macintosh, PowerBook, iMac or iBook
OS: Mac OS 8.6 through 9.1 (Please see our Mac OS X Compatibility Statement)
CPU: Power PC
Interface: USB: Cable connection via camera's USB port is limited to genuine Apple Computer brand models with a built-in USB interface (Power Macintosh NEW G3/G4, PowerBook G3, iMac, iBook).
RAM: 20MB and over for application
PC Requirements Hardware: IBM PC/AT compatible
OS: Windows 98 (including the Second Edition), Windows 2000, Windows ME,Windows XP (Please see our Windows XP compatibility statement)
CPU: Pentium 150 MHz and over
Interface: USB: Cable connection via camera's USB port is limited to pre-installed Windows 98, Windows 2000 and pre-installed or upgraded Windows ME or Windows XP systems.
RAM: 32MB or more (Windows 98), 64MB or more (Windows 2000/Windows ME), 128MB or more (Windows XP)
*1 "DCF" is an abbreviation of "Design rule for Camera File system" standardized by Japan Electronics and Information Technology Industries Association (JEITA).
*2 Canon's standard conditions of measuring shooting capacity are as follows: Normal temperature (23 Celsius degrees). LCD viewfinder is ON. Shoot images at wide angle end and at telephoto end alternately with 20 seconds intervals. Use flash at every 4-time shootings. Turn camera off and on at every 8-time shootings.
*3 Canon's standard conditions of measuring playback time are as follows: Normal temperature (23 Celsius degrees). Repeat playback automatically at a speed of 1 image per 5 seconds.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
