Canon Support for PowerShot G7 X | Canon U.S.A., Inc.
PowerShot G7 X
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
20.2 Megapixel*, 1.0-inch CMOS (sensor aspect ratio: 3:2)
*Image processing may cause a decrease in the number of pixels
Total Pixels
Approx. 20.9 Megapixels
Effective Pixels
Approx. 20.2 Megapixels
Focal Length
8.8 (W) - 36.8 (T) mm (35mm film equivalent: 24-100mm)
Optical Zoom
4.2x
Digital Zoom
4x
Focusing Range
Normal/Auto: 2.0 in. (5 cm) - infinity (W), 1.3 ft. (40 cm) - infinity (T)Macro: 2.0 in. - 1.6 ft. (5-50 cm) (W)
Autofocus System
TTL Autofocus (Continuous, Servo AF), Manual Focus
Optical Viewfinder
Not available
LCD Monitor
3.0-inch Tilt, Capacitive Touch Panel LCD with wide viewing angle (3:2)
LCD Pixels
Approx. 1.04 million dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/1.8 (W), f/2.8 (T)
Shutter Speed
1-1/2000 sec.
15*-1/2000 sec. (in Tv mode)
250*1/2000 sec. (in M mode)
*30-1.3 sec is available only at ISO 125-3200, 250-40 sec. is available only at ISO 125.
Sensitivity
Auto*, ISO 125/160/200/250/320/400/500/640/800/1000/1250/1600/2000/2500/3200/ 4000/5000/6400/8000/10000/12800 (When in P mode)
*Optimal ISO speed is automatically set depending on the shooting mode.
Light Metering Method
Evaluative*, Center-weighted average, Spot**
* Facial brightness is evaluated (Face Detect AE) in Face Detect.
** Fixed to Center, linked to AF frame
Exposure Control Method
Manual Exposure, Program Shift, Safety Shift, AE Lock
Exposure Compensation
Still Images: &plusmn;3 stops in 1/3-stop increments
Videos: &plusmn;3 stops in 1/3-stop increments (not available during shooting)
White Balance Control
Auto, Day Light, Shade, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash, Underwater, Custom 1, Custom 2, Multi-area White Balance, White Balance Correction (Underwater mode), White Balance Correction
Built-in Flash
Auto, Flash, On, Slow Synchro, Flash Off
Facial brightness is also evaluated in Face Detect
Flash Range
1.6 ft. (50 cm) -23 ft. (7.0 m) (W), 1.3 ft. (40 cm) - 13 ft. (4.0 m) (T)
Image brightness may diminish depending on the shooting distance
Recycling Time
10 seconds or less (battery voltage: 3.7 V)
Flash Exposure Compensation
&plusmn;2 stops in 1/3-stop increments
Shooting Modes
C, M, Av, Tv, P, Hybrid Auto, Auto, Creative Shot, SCN*1, Creative Filters*2, Movie*3
Shooting movies is done with the movie button
*1 Portrait, Smart Shutter*4, Star*5, Handheld Night Scene, Underwater, Snow, Fireworks
*2 High Dynamic Range, Nostalgic, Fisheye Effect, Miniature Effect, Toy Camera Effect, Background Defocus, Soft Focus, Monochrome, Super Vivid, Poster Effect
*3 Standard, Manual (Movie), iFrame Movie
*4 Smile, Wink Self-timer, Face Self-timer
*5 Star Portrait, Star Nightscape, Star Trails, Star Time-Lapse Movie
Photo Effects
My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Vivid Blue, Vivid Green, Vivid Red, Custom Color*
*Adjustment of contrast sharpness, saturation, red, green, blue and skin tone are available
Self Timer
Approx. 10-sec. delay/approx. 2-sec. delay/custom*
*Delay time (0-15 sec. (in one-second increments), 20/25/30 sec.) and number of shots (1-10 shots (in one-shot increments)) can be specified.
Wireless Control
Not available
Continuous Shooting
Normal: Approx. 6.5 shots/sec (in AUTO and P modes)AF: Approx. 4.4 shots/sec. (in P mode)LV: Approx. 4.4 shots/sec. (in P mode)Under conditions where the flash does not fire automatically. Differs depending on the zoom position.*1 Using an 8 GB, UHS-I compatible memory card that meets Canon's testing standards. The number of shots changes depending on subjects, brands of memory cards, etc. Shooting in RAW (including RAW+JPEG) is excluded.
Storage Media
SD/SDHC/SDXC and UHS-I Memory Cards
File Format
Design rule for Camera File system, DPOF (Version 1.1) compliant
Image Recording Format
Superfine / Fine
JPEG Compression Mode
Still Image: Exif. 2.3 (JPEG), RAW (12 bit, CR2 (Canon Original))
Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC (Stereo))
Number of Recording Pixels
Still Images:16:9 - Large: 5472 x 3080; Medium 1: 4320 x 2432; Medium 2: 1920 x 1080; Small: 720 x 408; 3:2 - Large: 5472 x 3648, Medium 1: 4320 x 2880, Medium 2: 2304 x 1536, Small: 720 x 4804:3 - Large: 4864 x 3648, Medium 1: 3840 x 2880, Medium 2: 2048 x 1536, Small: 640 x 4801:1 - Large: 3648 x 3648; Medium 1: 2880 x 2880; Medium 2: 1536 x 1536; Small: 480 x 4804:5 - Large: 2912 x 3648; Medium 1: 2304 x 2880; Medium 2: 1232 x 1536; Small: 384 x 480; Videos:
Full HD 1920 x 1080: 60 fps*4 / 30 fps*2
Full HD iFrame: 1920 x 1080: 30 fps*2
Full HD Star Time-Lapse Movie: 1920 x 1080: 15 fps*3 / 30 fps*2
HD 1280 x 720: 30 fps*2
640 x 480: 30 fps*2
Miniature Effect: 1280 x 720: 6 fps*1 / 3 fps*1 / 1.5 fps*1
Miniature Effect: 640 x 480: 6 fps*1 / 3 fps*1 / 1.5 fps*1
Digest Movie: 1280 x 720: 30 fps
*1 Playback frame rate is 30 fps*2.
*2 Actual frame rate is 29.97 fps.
*3 Actual frame rate is 14.985 fps.
*4 Actual frame rate is 59.94 fps.
Image data
Note: SF=Superfine / F=Fine
&#8226; The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly.
Movie data
*1 Actual frame rate is 29.97 fps.
*2 Playback frame rate is 30 fps*1.
*5 Only with shooting interval of 30 sec.
Playback Modes File
Stills & Videos:
Auto Rotate, Index Continuous Display, Image Advance (Transition Effects, Scroll Display), Rotate, Favorites, My Category, Smart Shuffle, Group Playback, Slideshow, Erase, Resume, Protect
Still Images:
Single, Index, Magnification (2-10x), Switch to other images while zoomed, Information Display, Photobook Setup, Cropping, Resize, My Colors, Face ID Info, Histogram, RGB Histogram, Location Information, Overexposure Warning
Videos:
Normal Playback, Pause, Slow Motion, Skip Backward, Previous Frame, Next Frame, Skip Forward, Erase Clip, Editing, Movie Transcoding
Erase Modes
Select Image, Select Range, Select All Images
The image data in the memory card stored with the Design rule for Camera File systems formate can be erased (however, protected images cannot be erased).Using the Movie editing function, sections of the movie can be deleted. RAW+JPEG images can be erased individually.
Video Out
Analog: NTSC or PAL, Digital: HDMI (HDMI&trade; micro connector)
Audio Out
Stereo
Other
SD memory card slot; direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers
Power Source
Battery Pack NB-13L, AC Adapter Kit ACK-DC110
Shooting Capacity
Approx. 210 shots
Approx. 310 shots with ECO Mode
Playback Time
Approx. 4 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
4.06 x 2.38 x 1.59 in. / 103.0 x 60.4 x 40.4 mm
Weight
10.7 oz. / 304 g (CIPA standard)
9.84 oz. / 279 g (camera only)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
