Canon Support for PowerShot G9 X Mark II | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
Type
High-sensitivity CMOS (back illuminated)
Total Pixels
Approx. 20.9 Megapixels
Effective Pixels
Approx. 20.1 Megapixels
Focal Length
10.2 (W) - 30.6 (T) mm (35mm film equivalent: 28-84mm)
Optical Zoom
3x
Digital Zoom
4x
Focusing Range
Normal/Auto: 2.0 in. (5cm) - infinity (W), 1.1 ft. (35cm) - infinity (T)
Macro: 2.0 in. (5cm) - infinity (W), 1.6 ft. (50cm) - infinity (T)
Autofocus System
TTL Autofocus, Manual Focus
Optical Viewfinder
N/A
LCD Monitor
3.0-type TFT color liquid crystal
LCD Pixels
Approx. 1.04 million dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/2.0 (W), f/4.9 (T)
Shutter Speed
1-1/2000 sec. (in Auto mode)
30-1/2000 sec. (in all shooting modes)
BULB (in M mode only)
1/6 minimum in Manual Movie Mode
Sensitivity
ISO 125 - 6400 (in Auto mode)
Max. ISO Speed in P mode is ISO 12800 (When in P mode)
Light Metering Method
Evaluative, Center Weighted Average, Spot
Exposure Control Method
Manual Exposure, Program Shift, Safety Shift, AE Lock
Exposure Compensation
Still Images: &plusmn;3 stops in 1/3-stop increments
Videos: &plusmn;3 stops in 1/3-stop increments
White Balance Control
Auto, Day Light, Shade, Cloudy, Tungsten, Fluorescent, Flash, Color Temperature, Custom
Built-in Flash
Auto, On, Slow Synchro, Off
Flash Range
1.6 (50cm) - 20 ft. (6.0m) (W), 1.6 ft. (50cm) - 7.9 ft. (2.4m) (T)
Flash Exposure Compensation
&plusmn;2 stops in 1/3-stop increments
Shooting Modes
C, M, Av, Tv, P, Hybrid Auto, Auto, Portrait, Panning, Star Portrait, Star Nightscape, Star Trails, Star Time-Lapse Movie, Handheld Night Scene, High Dynamic Range, Fish-eye Effect, Art Bold Effect, Water Painting Effect, Miniature Effect, Toy Camera Effect, Background Defocus, Soft Focus, Grainy B/W, Fireworks, Standard Movie, Short Clip, Manual Movie, Time-Lapse Movie, iFrame Movie
Photo Effects
Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Def. 1-3
Self Timer
Off, 2 sec., 10 sec., Custom
Wireless Control
Wi-Fi&reg; / NFC / Bluetooth&reg;
Continuous Shooting
JPEG
One-Shot AF
High-speed Continuous Shooting Speed: Max. approx. 8.1 shots/sec. (approx. 38 shots)
Low-speed Continuous Shooting Speed: Max. approx. 4.0 shots/sec. (until memory card becomes full)
Servo AF
High-speed Continuous Shooting Speed: Max. approx. 5.3 shots/sec. (approx. 102 shots)
Low-speed Continuous Shooting Speed: Max. approx. 3.9 shots/sec. (until memory card becomes full)
RAW
One-Shot AF
High-speed Continuous Shooting Speed: Max. approx. 8.2 shots/sec. (approx. 21 shots)
Low-speed Continuous Shooting Speed: Max. approx. 4.0 shots/sec. (approx. 27 shots)
Continuous shooting speed may become slower due to the following factors: Tv value, Av value, Subject conditions, Lighting conditions, Use of flash, Zoom position.
Storage Media
SD/SDHC/SDXC and UHS-I Memory Cards
File Format
DCF-compliant DPOF compatible (Version 1.1)
Image Recording Format
Fine / Normal
JPEG Compression Mode
Still Image: Exif 2.3 (DCF 2.0), JPEG/RAW (CR2 a Canon 14-bit RAW format)
Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC [Stereo])
Number of Recording Pixels
  16:9 3:2 4:3 1:1
Large 5472 x 3072 5472 x 3648 4864 x 3648 3648 x 3648
Medium 3648 x 2048 3648 x 2432 3248 x 2432 2432 x 2432
Small 1 (S1) 2736 x 1536 2736 x 1824 2432 x 1824 1824 x 1824
Small 2 (S2) 2400 x 1344 2400 x 1600 2112 x 1600 1600 x 1600
Audio Out
Stereo
Wired
Hi-Speed USB (Micro-B), HDMI (Type D)
Wireless
Wi-Fi&reg;
Specifications: IEEE 802. 11b/g/n
Frequency: 2.4 GHz
Channels: 1-11
Security: WPA-PSK (AES/TKIP), WPA2-PSK (AES-TKIP), Open (WEP-None)
NFC
Bluetooth&reg; Ver. 4.1
Other
Direct Connection to PictBridge compatible printers.
Power Source
Battery Pack NB-13L
Shooting Capacity
Approx. 235 shots with Screen On (CIPA compliant)
Approx. 315 shots with ECO Mode
Playback Time
Approx. 5 hr.
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
3.9 in. x 2.3 in. x 1.2 in. / 99.06 x 58.42 x 30.48 mm
Weight
Approx. 7.3 oz. / 206g (including battery and memory card)
Approx. 6.4 oz. / 182g (camera body only)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: Picture Style File Registration
Advisory Type
Date 12.15.19
Title Firmware Notice: PowerShot G9X Mark II: Firmware Version 1.1.0.0
Advisory Type Firmware Notice
Date 05.18.23
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
