Canon Support for PowerShot PICK Active Tracking | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | 1/2.3 CMOS sensor |
Effective Pixels | Approx 11.7MP |
Total Pixels | Approx 12.8MP |
Type | DIGIC 7 |
Focal Length | 19-57mm |
Zoom | 3x (optical) 4x (digital) |
Angle of View (Horzntl, Vertl, Diagnl) | Horizontal: Approx 84.7° (wide angle end) - 33.8° (tele angle end) Vertical: Approx 68.7° (wide angle end) - 25.7° (tele angle end) Diagonal: Approx 97.5° (wide angle end) - 41.6° (tele angle end) |
Pan/Tilt | Pan: Approx -170° (left) to +170° (right) Tilt: Approx -20° (down) to +90° (up) |
Closest Focusing Distance | 20cm (wide), 30cm (tele) |
Still Image Type | JPEG |
RAW+JPEG/HEIF Simultaneous Recording | Full HD (1920 x 1080) 59.94fps, 29.97fps, 23.98fps IPB (Standard) MP4 |
Menu Languages | Japanese, English, Simplified Chinese, French, German, Italian, Spanish, Russian, Korean, Turkish, Portugese (Brazilian) |
Voice Control | English, French, German, Italian, Spanish, Russian |
Wired Connectivity | USB Type-C |
Wireless Connectivity | Bluetooth Specification 4.1 compliant (Bluetooth Low Energy Technology), Wi-Fi IEEE802.11b/g/n 2.4GHz |
Type | MicroSD, MicroSDHC, MicroSDXC. UHS-I supported |
Other | Connect App for Mini PTZ Cam available on compatible
iOS and Android devices. View and transfer images,
control device, change device settings - see app store
for full details Wireless Webcam Utility for Mini PTZ Cam available for Windows. For full details see support pages |
Batteries | Built-in Rechargeable Lithium Ion |
Battery Life | 2/3.5/5 hours (high/mid/low shooting frequency) |
Power Supply & Battery Chargers | USB Type-C, Minimum charging requirement is a USB PD compliant power source providing a minimum of 5V, 1.5A with a USB Type-C output and using the provided USB Type-C to Type-C cable. Minimum for power and operation 9V 2A |
Operating Environment | Temp: 0-40°C Humidity range: 10-90% |
Tripod Mount | Standard CU 1/4" |
Dimensions (W x H x D) | Approx 56.4mm x 81.9mm |
Weight | Approx 170g (including memory card) |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
