Canon Support for PowerShot S5 IS | Canon U.S.A., Inc.
PowerShot S5 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.05.10
File Size 6.07 MB
Date 04.01.07
File Size 2.56 MB
Date 03.05.10
File Size 6.23 MB
Date 04.01.07
File Size 5.90 MB
Date 04.01.07
File Size 508.86 KB
Date 06.23.08
File Size 1.73 MB
Date 04.01.07
File Size 12.00 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type of Camera
Type Compact digital still camera with built-in flash, 12x Optical/4x Digital/48x Combined Zoom with Optical Image Stabilizer (IS) System
Image Capture Device
Type 8.0 Megapixel, 1/2.5 inch type Charge Coupled Device (CCD)
Total Pixels Approx. 8.3 Megapixels
Effective Pixels Approx. 8.0 Megapixels
Lens
Focal Length 6.0-72.0mm f/2.7-3.5 (35mm film equivalent: 36-432mm)
Digital Zoom 4x
Focusing Range Normal: 1.6 ft./50cm-infinity (WIDE), 3.0 ft./90cm-infinity (TELE)
Macro: 3.9 in.-1.6 ft./10-50cm (W)
Super Macro: 0-3.9 in./0-10cm (W)
Autofocus System TTL Autofocus
Viewfinders
Optical Viewfinder 0.33-inch low-temperature polycrystalline silicon TFT color LCD electronic viewfinder
LCD Monitor 2.5-inch low-temperature polycrystalline silicon TFT color LCD screen, Vari-angle type with wide viewing angle
LCD Pixels Approx. 207,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.7 (W) - f/3.5 (T)
Shutter Speed 15-1/3200 sec. (settable in Tv and M)
Exposure Control
Sensitivity Auto, High ISO Auto, ISO 80/100/200/400/800/1600 (Standard Output Sensitivity. Recommended Exposure Index)
Light Metering Method Evaluative*, Center-weighted average, Spot**
* Control to incorporate facial brightness in Face Detection AF
** Metering frame is fixed to the center
Exposure Control Method Program AE, Shutter Speed-Priority AE, Aperture-Priority AE, Manual; AE Lock available
Exposure Compensation +/-2 stops in 1/3-stop increments
White Balance
White Balance Control Auto, Preset (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash), Custom
Flash
Built-in Flash Auto, Auto w/ Red-eye Reduction, Flash On, Flash On w/Red-eye Reduction, Flash Off; FE lock, Safety FE available
Flash Range Normal: 1.6-17 ft./50cm-5.2m (W), 3.0-13 ft./90cm-4.0m (T)
Macro: 1-1.6 ft./30-50cm (W) (when sensitivity is set to ISO Auto)
Recycling Time 12 sec. or less (battery voltage=6.0V)
Flash Exposure Compensation +/-2 stops in 1/3-stop increments
Shooting Specifications
Shooting Modes Auto; Creative: P, Av, Tv, M, C; Image: Portrait, Landscape, Sports, Special Scene (Foliage, Snow, Beach, Fireworks, Aquarium, Indoor, Night Scene, Color Accent, Color Swap), Night Snapshot, Super Macro, Stitch Assist, Movie
Self Timer Activates shutter after an approx. 2-sec./10-sec. delay, Custom
Wireless Control Not available
Continuous Shooting Approx. 1.5 fps; AF/LV: approx. 0.9 fps
Image Storage
Storage Media SD Memory Card, SDHC Memory Card, MultiMediaCard
File Format Design rule for camera file system, DPOF Version 1.1
JPEG Compression Mode Still Image: Exif 2.2 (JPEG)
Movie: AVI (Image: Motion JPEG; Audio: WAVE (Stereo))
Number of Recording Pixels Still Image: 640 x 480 (Small), 1,600 x 1,200 (Medium 3), 2,048 x 1,536 (Medium 2), 2,592 x 1,944 (Medium 1), 3,264 x 2,448 (Large), 3,264 x 1,832 (Widescreen)
Movie: 640 x 480 (30 fps/30 fps LP), 320 x 240 (60 fps/30 fps) available up to 4GB or 60 minutes
Number of Recordable Images
Image data
Time of Recordable Movies
Movie data Note: N=Normal F=Fine SF=SuperFine
Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media.
Playback Specifications
Playback Modes File Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotate, Resume, My Colors, My Category, Histogram, Index (9 thumbnails), Sound Memos, Slide Show, Red-eye Correction
Movie: Normal Playback, Special Playback, Editing, Auto Rotate, Resume
Erasing Specifications
Erase Modes Still Image: single image, select by date, select by category, select by folder, all images
Movie: part of movie, all of movie
Interfaces
Computer Interface USB 2.0 Hi-Speed (mini-B jack)
Video Out NTSC/PAL
Audio Out Stereo
Other Memory card slot; direct connection to Canon CP and SELPHY Compact Photo Printers, PIXMA Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Supply 1.AA-size Alkaline Battery (x4)
2.Rechargeable AA-size NiMH Battery (x4)
3.Compact Power Adapter CA-PS700Still Image: approx. 170 shots (AA-size Alkaline Battery); approx. 450 shots (AA-size NiMH Battery)*Approx. 12 hours (AA-size Alkaline Battery); approx. 15 hours (AA-size NiMH Battery)** LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used.
Power Source 1.AA-size Alkaline Battery (x4)
Shooting Capacity Still Image: approx. 170 shots (AA-size Alkaline Battery); approx. 450 shots (AA-size NiMH Battery)*
Playback Time Approx. 12 hours (AA-size Alkaline Battery); approx. 15 hours (AA-size NiMH Battery)** LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used.
Physical Specifications
Operating Temperature 32-104&deg;F/0-40&deg;C
Operating Humidity 10-90%
Dimensions (W x H x D) 4.60 x 3.15 x 3.06 in./117.0 x 80.0 x 77.7mm
Weight Approx. 15.9 oz./450g (camera body only)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
