Canon Support for PowerShot S70 | Canon U.S.A., Inc.
PowerShot S70
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type of Camera
Type Compact digital still camera with built-in flash and 3.6x Optical/4.1x digital/15x combined zoom
Image Capture Device
Type 1/1.8 inch type Charge-Coupled Device (CCD)
Total Pixels Approx. 7.4 Million
Effective Pixels Approx. 7.1 Million
Lens
Focal Length 5.8-20.7mm zoom Lens (35mm film equivalent: 28-100mm)
Digital Zoom 4.1x
Focusing Range Normal AF: 44cm/1.4 ft.-Infinity
Macro AF: 4-44cm/1.6 in.- 1.4 ft. (WIDE)30-44cm/1.0-1.4 ft. (TELE)
Autofocus System 9-point AiAF (Automatic Focus Point Selection)/1-point AF (Fixed to center)/FlexiZone AF/AE
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 1.8 inch low-temperature polycrystalline silicon TFT color LCD
LCD Pixels Approx. 118,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.8-8.0 (W)
f/5.3-8.0 (T)
Shutter Speed 15-1/2000 sec.
Exposure Control
Sensitivity AUTO*, ISO 50/100/200/400 equivalent *Camera automatically sets the optimum speed
Light Metering Method Evaluative/Center-weighted average/Spot* *Metering frame with Spot mode can be fixed to the center or linked to the AF point.
Exposure Control Method Program AE/Aperture or Shutter-priority AE/Aperture-Priority AE/Manual
Exposure Compensation +/- 2 EV in 1/3 stop increments
Auto Exposure Bracketing (AEB) is available
White Balance
White Balance Control Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash or Underwater), or Custom White Balance (1 position)
Flash
Built-in Flash Operation Modes: Auto, Red-Eye Reduction On/Off, Slow Syncro
Flash Range WIDE: 55cm-4.2m/1.8-14 ft.
TELE: 55cm-2.0m/1.8-6.6 ft.
(When ISO is set to AUTO)
Recycling Time Approx. 10 sec. or less.(battery voltage=3.7V)
Flash Exposure Compensation +/- 2.0 EV in 1/3 stop increments
Shooting Specifications
Shooting Modes Auto, Creative Zone (P, Av, Tv, M), Image Zone (Portrait, Landscape, Night Scene, Fast Shutter, Slow Shutter, Stitch Assist, Movie), Custom
Photo Effects Vivid, Neutral, Low Sharpening, Sepia and Black & White
Self Timer Operates with approx. 2 sec. or approx 10 sec. count-down.
Wireless Control Available (playback is available too)
Continuous Shooting High Speed: Approx. 2.0 shots/sec.
Normal Speed: Approx. 1.5 shots/sec.
(Large/Fine Mode and LCD monitor is Off)
Image Storage
Storage Media CompactFlash (CF) Card Type I or Type II
File Format Design rule for camera file system (DCF*1)
Print Order Format Digital Print Order Format (DPOF) Version 1.1
Image Recording Format Exif 2.2 (JPEG) / RAW
JPEG Compression Mode SuperFine, Fine, Normal
Number of Recording Pixels Still Image: 3,072x2,304 (RAW/Large), 2,592x1,944 (Medium 1), 2,048x1,536 (Medium 2), 1,600x1,200 (Medium 3), 640x480 (Small)
Number of Recordable Images
Image data These figures reflect standard shooting conditions established by Canon.
Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode.
Time of Recordable Movies
Movie data Above-written figures are measured under Canon's standard conditions and may vary depending on the scene, subjects or camera settings. Total length of movie files recordable on specific CF cards; Individual 640 x 480 movie clips are limited to 30 seconds maximum per clip; individual 320 x 240 and 160 x 120 movie clips are limited to 3 minutes maximum per clip.
Playback Specifications
Playback Modes File Single, Index (9 thumbnails), Magnification (Approx. 2.0x to 10x), Slide Show or Movie Magnified, Auto rotate, Rotation, Histogram, Sound memos (up to 60 sec.) / Auto Play
Erasing Specifications
Erase Modes Still Images: Single Image, All Images Movie: Part of Movie, All Movie
Interfaces
Computer Interface Universal Serial Bus (USB) mini-B
Video Out NTSC or PAL
Audio Out Monaural
Other CF card slot (accepts Type I & Type II cards). Direct connection to Canon CP Printers and select BJ Photo Printers (no computer required)
Power Supply 1. Rechargeable Lithium-ion battery (NB-2LH or NB-2L)
2. Compact Power Adapter CA-PS700
3. Car Battery Charger CBC-NB2AA NIMH: LCD On - Approx. 550; LCD Off - Approx. 1200Approx. 280 minutes (Under Canon's standard conditions*2 with fully charged battery)
Power Source 1. Rechargeable Lithium-ion battery (NB-2LH or NB-2L)
Shooting Capacity AA NIMH: LCD On - Approx. 550; LCD Off - Approx. 1200
Playback Time Approx. 280 minutes (Under Canon's standard conditions*2 with fully charged battery)
Physical Specifications
Operating Temperature 32-104&degF/0-40&degC
Operating Humidity 10-90%
Dimensions (W x H x D) 4.49x2.22x1.53 in./114.0x56.5x38.8mm (Excluding protrusions)
Weight Approx. 8.11 oz./230g (Camera body only)
14 languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified Chinese, Japanese, Russian and Portuguese)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
