Canon Support for PowerShot SD10 | Canon U.S.A., Inc.
PowerShot SD10
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type of Camera
Type | Compact digital still camera with built-in flash and 5.7x Digital Zoom |
Image Capture Device
Type | 1/2.5 inch Charge-Coupled Device (CCD) |
Effective Pixels | Approx. 4.0 million |
Lens
Focal Length | 6.4mm f/2.8 Fixed Focal Length(approximately equivalent to 39mm in 35mm format) |
Digital Zoom | 5.7x Digital Zoom |
Focusing Range | Normal: AF: 4 in. - Infinity/10cm - Infinity, Macro AF: 1.2 - 4 in./3 - 10cm |
Autofocus System | 5-point AiAF/ 1-point AF (Fixed to center) |
Viewfinders
LCD Monitor | 1.5 inch low temperature polycrystalline silicon TFT color LCD |
LCD Pixels | Approximately 78,000 |
Aperture and Shutter
Maximum Aperture | f/2.8 or f/5.6 |
Shutter Speed | 15 - 1/1,500 sec. |
Exposure Control
Sensitivity | Auto/ISO 50/100/200/400 |
Light Metering Method | Evaluative, Center-weighted Average or Spot Metering |
Exposure Control Method | Program AE |
White Balance
White Balance Control | Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H) |
Flash
Built-in Flash | Operation Modes: Auto, Red-eye Reduction On/Off, Slow-sync |
Flash Range | Balance (Available settings: Daylight, Cloudy) |
Shooting Specifications
Shooting Modes | Auto, Manual, Slow Shutter, Quick Shot, Stitch Assist, Movie |
Photo Effects | Vivid Color, Neutral Color, Low Sharpening, Sepia, Black & White |
Image Storage
Storage Media | SD Memory Card |
Print Order Format | Digital Print Order Format (DPOF) Version 1.1 |
Image Recording Format | Still Image: JPEG (Exif 2.2 compliant) |
JPEG Compression Mode | SuperFine, Fine or Normal |
Number of Recording Pixels | Still Image: Large: 2,272 x 1,704, Medium 1: 1,600 x 1,200, Medium 2: 1,024 x 768, Small: 640 x 480 Movie: 320 x 240 or 160 x 120 |
Number of Recordable Images
Image data |  These figures reflect standard shooting conditions established by Canon. Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode. |
Time of Recordable Movies
Movie data |  Above-written figures are measured under Canon's standard conditions and may vary depending on the scene, subjects or camera settings. Total length of movie files recordable on specific SD cards; Individual movie clips are limited to 3 minutes maximum per clip. |
Playback Specifications
Playback Modes File | Single, Index (9 thumbnail images), Magnification (approx. 2.0x to 10x), Slide Show or Movie |
Erasing Specifications
Erase Modes | Still images: Single Image, All Images Movie: Part of movie, All of movie |
Interfaces
Computer Interface | Universal Serial Bus (USB) (mini-B jack) |
Video Out | NTSC or PAL |
Other | SD memory card slot. Direct connection to Canon Card Photo Printers and select Bubble Jet Direct Photo Printers and PictBridge-compliant printers (no computer required), using camera's USB cable. |
Power Supply | Rechargeable Lithium-ion battery (NB-3L)Approx. 190 shots (LCD monitor ON)(At 73°F/23°C, Shoot images with 20 second intervals. Use flash at every fourth shot. Turn camera off and on at every eight shot.)Approx. 140 min (At 73°F/23°C, Repeat replay automatically at a speed of 1 image per 3 seconds. LCD brightness setting by Factory default.) |
Power Source | Rechargeable Lithium-ion battery (NB-3L) |
Shooting Capacity | Approx. 190 shots (LCD monitor ON)(At 73°F/23°C, Shoot images with 20 second intervals. Use flash at every fourth shot. Turn camera off and on at every eight shot.) |
Playback Time | Approx. 140 min (At 73°F/23°C, Repeat replay automatically at a speed of 1 image per 3 seconds. LCD brightness setting by Factory default.) |
Physical Specifications
Operating Temperature | 32 - 104°F (0 - 40°C) |
Operating Humidity | 10 - 90% |
Dimensions (W x H x D) | 3.6 x 1.9 x 0.7 in./ 90.3 x 47.0 x 18.5mm (Excluding protrusions) |
Weight | Approx. 3.5 oz./ 100g (Camera body only) |
Computer System Requirements
Mac Requirements | Computer Model: Power Macintosh, PowerBook, iMac, eMac or iBook OS: OS 9.0 - 9.2 or OSX 10.1 - 10.2. CPU: PowerPC. Interface: USB (Models with Apple genuine USB interface only). |
PC Requirements | Computer Model: IBM PC/AT compatible OS: Microsoft Windows 98 (including Second Edition)/ Me/ 2000/ XP. CPU: Pentium 150MHz or higher processor (Windows 98/ 98SE/ Me/ 2000), Pentium 300MHz or higher processor (Windows XP). Interface: USB (Windows 98/98SE/Me/2000/XP pre-install model only). |
*1 Canon's standard conditions of measuring shooting capacity are as follows: Normal temperature (23 degrees Celsius). LCD viewfinder is ON. Shoot images at wide angle end and at telephoto end alternately with 20 second intervals. Use flash every 4th shot. Turn camera off and on every 8th shot. *2 Canon's standard conditions of measuring playback time are as follows: Normal temperature (23 degrees Celsius). Repeat playback automatically at a speed of 1 image per 5 seconds. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
