Canon Support for PowerShot SD400 | Canon U.S.A., Inc.
PowerShot SD400
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
5.0 Megapixel, 1/2.5-inch type Charge Coupled Device (CCD)
Total Pixels
Approx. 5.3 Megapixels
Effective Pixels
Approx. 5.0 Megapixels
Focal Length
5.8-17.4mm, f/2.8-4.9 (35mm film equivalent: 35-105mm)
Digital Zoom
4x
Focusing Range
NORMAL: 1.0 ft./30cm-infinity
MACRO: 1.2 in.-1.6 ft./3-50cm (WIDE), 1.0-1.6 ft./30-50cm (TELE)
Digital Macro: 1.2-3.9 in./3-10cm (WIDE)
Autofocus System
9-point AiAF/1-point AF (fixed to center) (Intelligent Orientation Sensor), AF Lock, AF-assist Beam On/Off
Optical Viewfinder
Real-image optical zoom viewfinder
LCD Monitor
2.0 inch low-temperature polycrystalline silicon TFT color LCD
LCD Pixels
Approx. 118,000 pixels
LCD Coverage
100%
Maximum Aperture
f/2.8-5.6 (W), f/4.9-10.0 (T)
Shutter Speed
15-1/1500 sec.
Sensitivity
AUTO, ISO 50/100/200/400 equivalent
Light Metering Method
Evaluative, Center-weighted average, Spot*
*Metering frame with Spot mode is center fixed.
Exposure Control Method
Program AE, AE Lock is available
Exposure Compensation
+/- 2 stops in 1/3-stop increments
White Balance Control
Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H), Custom
Built-in Flash
Operation Modes: Auto*, Flash On*, Flash Off, Slow Synchro* Red-Eye Reduction is available
Flash Range
Normal: 1.6 - 11.5 ft./50cm - 3.5m (W), 1.6 - 6.7 ft./50cm - 2.0m (T)
Macro: 1.0-1.6 ft./ 30-50cm (W/T) (When sensitivity is set to Auto)
Recycling Time
Approx. 10 sec. or less (battery voltage=3.7V)
Flash Exposure Compensation
Not Available
Shooting Modes
Still Images: Auto, Manual, Scene Modes (Digital Macro, Portrait, Night Snapshot, Kids & Pets, Indoor, Underwater), My Colors, Stitch Assist; Movies: Standard, Fast Frame Rate, Compact, My Colors.
Photo Effects
Off, Vivid, Neutral, Low Sharpening, Sepia, Black & White
Self Timer
Activates shutter after an approx. 2-sec. or approx 10-sec. delay, custom
Wireless Control
Not Available
Continuous Shooting
Approx. 2.1 shots/sec.
Storage Media
SD memory card
Print Order Format
Design rule for camera file system Exif 2.2 (JPEG) and DPOF (Version 1.1) compliant
Image Recording Format
Still: Exif 2.2
(JPEG)Movies: AVI (Image data: Motion JPEG; Audio data: WAVE (Monaural))
JPEG Compression Mode
Normal, Fine, SuperFine
Number of Recording Pixels
Still Image: 2592x1944 (Large), 2048x1536 (Medium 1), 1600x1200 (Medium 2), 640x480 (Small), 1600x1200 (Postcard Date Imprint Mode)
Movie: 640x480, 320x240, 160x120
Image data
Movie data
Note: N=Normal F=Fine SF=SuperFine
Storage capacity varies depending on the scene or the subjects. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of SD Memory Card. Individual clips are limited to 3 minutes. The values given above vary depending on the subject, shooting conditions and shooting mode.
Playback Modes File
Single, Index (9 thumb images), Normal Playback, Special Playback, Slow Motion, Movie Editing
Erase Modes
Still Images: Single Images, All Images
Movies: Part of Movie, All of Movie
Computer Interface
USB 2.0 Hi-Speed (mini-B/PTP)
Video Out
NTSC, PAL
Audio Out
Monaural
Other
SD memory card slot. Direct connection to Canon CP Printers and select BJ Printers (no computer required)
Power Supply
1. One Rechargeable lithium-ion battery NB-4L
2. AC Adapter Kit (ACK-DC10)NB-4L: LCD On - Approx. 150 shots (CIPA Test Standard); LCD Off - Approx. 400 shots.Approx. 180 minutes (Under Canon's standard conditions*1 with fully-charged battery)
Power Source
Shooting Capacity
Playback Time
Operating Temperature
32-104&deg F/0-40&deg C
Operating Humidity
10-90%
Dimensions (W x H x D)
3.39 x 2.09 x 0.81 in./86.0 x 53.0 x 20.7mm (Excluding protrusions)
Weight
Approx. 4.59 oz./130g (camera body only)Note: *1 Normal temperature (73° F/23° C). Shoot images at wide angle and at telephoto end alternatively with 20 second intervals. Use flash every fourth shot. Turn camera off and on after every eight shots. LCD brightness setting by Factory default.
21 languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
